Old 04-03-2007, 12:31 AM   #1
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Default 2006 290HP EJ20 Dual AVCS - Mini autopsy :)
Hey guys,
I'm sure some of you guys have seen this engine before. Others of you may not have so I thought I would share for those who are interested.
This motor is pulled from the limited edition JDM Legacy GT B4
It's rated at 287HP in 2.0 liter format.
1. Right off the bat you'll notice that this is a dual AVCS engine with AVCS sprockets on both the intake and exhaust side.
2. You'll also notice that the head casting looks surprisingly similar to the USDM 06 STI, but with the exhaust side AVCS components.
3. After taking the valve covers off I was surprised to find instead of the JDM STI 2.0 chilled cast cams, cams that use the USDM 2.5 STI base cores. The lobes have less lift than the STI or WRX cams, but more duration. They are also WAY lighter than the chilled cast WRX / JDM 2.0 STI units.
4. The head casting is very very similar to the USDM STI 2.5 heads. And Of course shimless buckets.
5. Finally I was really expecting to see a semi-closed decked, and rather dissapointed when I didn't. At least forged pistons and forged rods were present. I'll get a pic of the crankshaft later - it is similar to the JDM 2.0 STI unit. On the left is the OEM 2.0 WRX cast piston.
Thanks for looking
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 04-03-2007, 12:39 AM   #2
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
i want it
vipernj is offline   Reply With Quote
Old 04-03-2007, 12:46 AM   #3
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
Yeah, you can donate that to me if you'd like.
sc00ter is offline   Reply With Quote
Old 04-03-2007, 01:14 AM   #4
AnthonyA182
Member#: 59990
2011 WRX Hatch
nice motor. what is this going in?
AnthonyA182 is offline   Reply With Quote
Old 04-03-2007, 01:28 AM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hehe no candidates right now - had a bad intake valve so we're redoing the heads. It is basically a good candidate for 2.0 cars looking for a beefed up high revving 2.0.
Thanks,
Gary
Gruppe-S
Old 04-03-2007, 01:38 AM   #6
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Interesting setup. Is it possible to tune the intake and exhaust side now?
DoctorNick is offline   Reply With Quote
Old 04-03-2007, 09:27 AM   #7
controler
Member#: 100271
It looks like it has 100 miles on it... how could an intake valve be bad already?
controler is offline   Reply With Quote
Old 04-03-2007, 03:01 PM   #8
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Does the open deck design severely limit the power potential of this engine? I know high boost wouldn't be desired in the open deck but what about peak power?
CoolRex is offline   Reply With Quote
Old 04-03-2007, 04:14 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Doctornick - I don't know of any aftermarket ECU's that can accomodate both.
Controler - usually intake valves fail from valve float / high revs, although I didn't see any impact on the pistons, so maybe just a bad valve guide?
Coolrex - I would say that the open deck design does limit the top end capability of this motor, but short of 2 bar + I don't think there will be any serious problems with the open deck design. One has to keep in mind that "semi closed" on a Subaru engine is merely just a small piece of aluminum no deeper than 0.5".
Thanks,
Gary
Gruppe-S
Old 04-03-2007, 04:21 PM   #10
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Hmm how much would a swap donor of this motor plus it's ECU run?
Old 04-03-2007, 04:52 PM   #11
MasterKwan
Member#: 98961
2003 WRX
Do JDM Suby ECU's talk OBD2? I know honda ECU's don't.
MasterKwan is offline   Reply With Quote
Old 04-03-2007, 05:22 PM   #12
hondaeater69
Member#: 60324
EcuTeK has the most advanced JDM OEM ECM tuning, if anyone can do i would imagine it's them.
hondaeater69 is offline   Reply With Quote
Old 04-05-2007, 11:35 AM   #13
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Gary, what is the engine code?
wrxfactor is offline   Reply With Quote
Old 04-05-2007, 08:06 PM   #14
Displaced
Member#: 142459
C6 Z06
EJ20R, but dont quote me.
Displaced is offline   Reply With Quote
Old 04-05-2007, 10:46 PM   #15
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
oh wow, will you get more? how much?
djerickd is offline   Reply With Quote
Old 04-06-2007, 04:55 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Have no clue what the engine code is, sorry.
We have this one engine available, it's in great condition except the #1 intake valve is leaking a bit, either from debris getting in or maybe a valve guide. We're letting this go for real cheap (please see our vendor section) so it would be worthwhile for someone to rebuild it if they had the time. Keep in mind most JDM 2.0 forged engines go for over $3k.
Thanks,
Gary
Gruppe-S
Old 04-06-2007, 05:25 PM   #17
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
u have the ECU for this also?
Old 04-06-2007, 10:13 PM   #18
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Thanks,
Gary
Gruppe-S
Isn't the code on the white sticker on the timing belt/cam cover? I will try and contact someone over in Japan to see if I can find out what it is.
Old 04-07-2007, 09:51 AM   #19
Jasper
Member#: 80136
2006 Ford F-150
what makes you so sure they're forged pistons?
i have a v.8 EJ207 Spec C shortblock, and my pistons look nearly identical to those (assuming they're stock pistons), and AFAIK, they're "hypercast" or something like that (stronger than USDM pistons, but not quite @ the forged level)
Jasper is offline   Reply With Quote
Old 04-10-2007, 04:14 PM   #20
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Bump for answers to my question and Jasper's.
Old 04-12-2007, 09:48 AM   #21
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Bumperooski.
Old 04-12-2007, 05:34 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Jasper - I'm fairly certain they are forged units (or an incredibly good cast) as close up they look nothing like the casting on the WRX or STI units.
WRXFactor - Didn't we send you one of these engines?
Thanks,
Gary
Gruppe-S
Old 04-12-2007, 05:58 PM   #23
Jasper
Member#: 80136
2006 Ford F-150
is there any well to tell for certain. if i have forged pistons, 28psi might not be such a bad idea
Old 04-13-2007, 09:58 AM   #24
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
I don't believe so. Is the sticker still on the cam cover?
Old 04-13-2007, 05:08 PM   #25
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hmm ok sorry about that. No the sticker is smudged on the cam cover. I believe it's an EJ208 but I could be wrong.
Thanks,
Gary
Gruppe-S
EJ257 USDM STI Dual AVCS long block Dugansti Engine/Power/Exhaust 7 03-30-2009 11:59 AM
DUAL AVCS 2.0 wiring??? saab-on-the-cobb Subaru Conversions 4 04-25-2007 10:45 AM
New JDM spec EJ20 w/AVCS longblock obtainable? BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-06-2001 11:38 AM
