Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-07-2012, 09:34 AM   #2501
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
The 5sp (at least the 02 5sp) deserves a little more credit than it has gotten, but again its a crap shoot of which ones will handle power. Mine was at or about the 280~290+hp level with tons of 1/4 mile passes. I swapped in a new clutch disc at 40k at the time of the v7 swap, even though it had lots of meat. I ended up selling it close to 100k miles to recoup some $ from a 6sp swap. Last I heard the 2nd owner is still on the board driving it today.
I believe its a touch of luck and slipping the clutch with the 5sp will keep it alive (at least to a reasonable power level)
I found the original clutch disc a few years back and sold it to a friend with a 2.5L hybrid swap with a APS SR40, somehow it lasted almost 2 more years!
fastnoypi is offline   Reply With Quote
Old 02-07-2012, 09:40 AM   #2502
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i broke my original 5mt with 250whp and 260wtq approx. torque is what breaks the gears after a hard gear drop or launch. they do deserve credit though. i heard that the gears in them actually vary some because in 02 they built like 2x as many bugeyes as they thought they would need. hence the various brake calipers they used, possibly different gears from older impreza's. and a few other small things i cant remember.
WhiteBgeye02 is offline   Reply With Quote
Old 02-07-2012, 09:42 AM   #2503
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
oem clutch disc helps a LOT with that too.
i'm on my third clutch, but i still have my original gearbox.
Old 02-07-2012, 10:38 AM   #2504
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
yeah i've heard some 5sp cases had RA gears in them, its rumored that US demand was pretty high at the time for the wrx and the factory basically dipped into their extra parts bin to meet the demand.
Old 02-07-2012, 10:50 AM   #2505
mt1101
Member#: 291990
2003 BUGEYE WAGON
Thanks as always for details vlad. Well I am not launching or dropping gears like some mad man...probably just some nice highway pulls though. My 160k original clutch is finally going bye bye but it definitely held up its end of the deal.
mt1101 is offline   Reply With Quote
Old 02-07-2012, 12:04 PM   #2506
efiniluvr
Member#: 107170
2002 ver 7 EJ207 WRX
Default Thanks for all the feedbacks
Glad to see I'm being pointed toward the right direction. I am actually pulling the motor right now, and will prep the new motor with belts, tensioner, pulleys since it's out. Changing out the timing belt with the motor in the car was not fun.
I'm glad people don't give me heat about keeping the 5 spd. If money wasn't a cost issue, sure who wouldn't want a 6 spd swap, right? The clutch that's currently on the car is the original and has 160K miles on it, so it was a blessing in disguise I guess that the motor blew. In terms of the clutch, will those two I listed suffice? If in fact I can keep the new clutch for a 6 spd, I guess I can look at other alternatives that is daily-driver friendly. I am only looking to upgrade to Stage 2 afterwards, and the car may see about 2 HPDE's per year, so what ~whp am I looking at?
Again, if some of you have personal experience with some of the vendors, please PM me if you don't feel comfortable posting it public.
Thanks
-Jeff
efiniluvr is offline   Reply With Quote
Old 02-07-2012, 12:41 PM   #2507
WRick
Member#: 86107
what's the rear 02 sensor part number for a V7 spec C...
mine borked
WRick is offline   Reply With Quote
Old 02-07-2012, 02:30 PM   #2508
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
rear O2 sensors are not even needed. have someone go in and delete the code. the car runs off of the front O2 sensor that is in the top of the downpipe. if you got a tactrix and can pull the tune via opensource i can delete it for you via email.
Old 02-07-2012, 02:35 PM   #2509
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Thanks
-Jeff
at the risk of derailing this thread a bit more, i would stick with an oem replacement clutch. it will hold up to around 115-120mph trap. they're cheap, they have great pedal feel, and they are easier on the gears.
Old 02-07-2012, 02:40 PM   #2510
WRick
Member#: 86107
O2 on top of downpipe ??
That would be the wideband A/F.... or the front factory A/F, before the up-pipe...
correct me if I'm wrong...
My ecu has an ecutek lock. I figured a way around it, but my tuner has the software
So, I really don't need it ?
I have an old one I can use to plug the hole. Would that do ?
Old 02-07-2012, 02:45 PM   #2511
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
from what i understand the up stream O2 sensor that goes in the up pipe in a usdm car is now right behind the turbo? and then the rear one is way down at the end of the downpipe. a wideband is a O2 sensor. it just tells us if its made to read a wide range of afr's or narrow range hence the name narrowband. the rear one is narrowband and i am 90% sure the car doesnt even use it... once in open loop it relies on past tune information as it is
thats why i dislike ecutek. cant do **** on your own
Old 02-07-2012, 02:47 PM   #2512
WRick
Member#: 86107
The rear one is a narrowband.
There is no factory o2 right behind the turbo....
Old 02-07-2012, 02:54 PM   #2513
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
this were is the factory wideband O2 located?
http://www.ebay.com/itm/SUBARU-Impre...#ht_2295wt_952
ive seen this location on the oem downpipes that are jdm. atleast the twin scroll. maybe single scroll is different....
Old 02-07-2012, 02:57 PM   #2514
WRick
Member#: 86107
every aftermarket DP has that bong, for tuning purposes.
Factory mount isnt there, Subaru would be replacing sensors every 5 minutes
Old 02-07-2012, 02:58 PM   #2515
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i think you need to brush up on your twinscroll knowledge.
Old 02-07-2012, 02:58 PM   #2516
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
The JDM v.8 has the O2 sensor right behind the turbo at the top of the downpipe. I think it is the same for all twin scroll STi setups.
LIQUIDSK8S is offline   Reply With Quote
Old 02-07-2012, 03:03 PM   #2517
WRick
Member#: 86107
Kk, thanks for the info.
Mine's a V7 spec C
Newly built !
Old 02-07-2012, 03:12 PM   #2518
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yeah they moved it for two reasons. one there is no way to combine the seperated exh tubes before the turbo and the second you get better readings in this location anyways because of the lesser pressure compared to the up pipe pressure. as far as v7 your on your own then. i have no clue lol prob same as usdm stuff. i realize that bung is there for tuning purposes for aftermarket widebands. just go to your tuner and get that rear o2 sensor codes deleted and plug the darn hole
Old 02-07-2012, 03:23 PM   #2519
WRick
Member#: 86107
yeah I can take care of that myself
Following up on my recent installing of wossner pistons ;
they sound like a stock 2.0 wrx !
Hope they last. We'll see.
Old 02-07-2012, 03:34 PM   #2520
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
why wouldnt it sound like a stock wrx? as far as tuning wise if you can get another bung welded on the downpipe and move the stock wideband to the dp. works much better for closed loop tuning accuracy! good luck!
Old 02-07-2012, 03:48 PM   #2521
WRick
Member#: 86107
Meh, I was expecting a little slap!
smooth as butter.
Old 02-07-2012, 03:57 PM   #2522
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
do the pistons have longer skirts? some ppl try getting the shorter skirt pistons and then they have too much rotational room and slap like a sob. better to get the longer skirts so they can spin. whats a little extra mass compared to a horrible sounding engine.
Old 02-07-2012, 04:16 PM   #2523
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
afaik oem t/s headers are equal length.
Old 02-07-2012, 04:26 PM   #2524
WRick
Member#: 86107
Haven't built it myself.
Couldn't answer this one...
I just started it. I think my plugs are gapped too tight. It's a little rough at idle, even dies down.
Old 02-07-2012, 05:12 PM   #2525
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i know. saw its a v7 so assumed single scroll.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
