Old 02-20-2012, 10:38 PM   #2651
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
do u have good afr gauge like a innovate wideband? that should tell the story if its getting too much fuel because it will be super rich. the afr gauge doesnt lie unless u didnt install it right of coarse lol.
WhiteBgeye02 is offline   Reply With Quote
Old 02-21-2012, 11:09 AM   #2652
azscooby
Member#: 115297
2002 ej207 vf34
Wrick
I'm by no means an expert at any of this, but have you tried running your usdm ECU?
I would swap it in just to see if it runs fine, that way you can see if it hardware or software related.
If it runs fine you know its the jdm ECU and tune problem. If it still runs like crap you know its hardware.
azscooby is offline   Reply With Quote
Old 02-21-2012, 11:14 AM   #2653
WRick
Member#: 86107
I'll pull the map later on today. I've been trying to diagnose with the crappy Subaru select monitor, that works half assed. I'll post a log later on...
WRick is offline   Reply With Quote
Old 02-21-2012, 01:18 PM   #2654
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
wideband^???? a swap like this requires the purchase of a tactrix cable as well with all the possible problems that can arise.
Old 02-21-2012, 02:38 PM   #2655
WRick
Member#: 86107
Have all that.
Got my ecuedit pro licence back. I'll pull the map in a minute.
In the meantime, I think ( again ) I found the ''coupable''.
A/F sensor is giving me crap, and I think the ecu is trying to enrich it for no reason.
Here's a log : https://docs.google.com/open?id=0BxF...E2ZDc3YWExNDEx
and another one ( longer )
https://docs.google.com/open?id=0BxF...MzOGI3MDMzZmRm
Someone has to tell me I'm not wrong and that the AF sensor is %$#$@#$%
Damn I missed ecuedit , good to have you back.
Old 02-21-2012, 03:13 PM   #2656
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i cant see the logs. idk why but what is ur afr at idle or cruising? ur running off a non stock one correct? i guess i never thought of including that in my question. at startup u should see like 11.5afr and then it will quickly go up to 14.7 if the car is warm. seeing ur in canada its prob cold so if the car is cold then it will slowly go up until it starts to warm up a bit then 14.7 all day crusing. idling etc. do u have a different set of injectors you could try? is ur stock upstream wideband o2 sensor good? idk if u have v8 or 7 but its either right next to the turbo on the dp or in the up pipe if you are v7. a bad sensor will mean the ecu doesnt know the real reading.
Send me the logs to [email protected] and ill look at them on my school computer via excel or however u have them on ur pc saved as.
Old 02-21-2012, 03:19 PM   #2657
WRick
Member#: 86107
Allright buddy, thanks for the help. In google docs all you have to do is click on download up top. It's a .csv file.
I read them with ecu edit, ( I told you I suck at logging lol )
But it's idle. like 16-17afr all across. At 900 rpm. NO LOAD.
Old 02-21-2012, 05:12 PM   #2658
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Engine Load (Calculated) (g/rev) Engine Speed (rpm) Injector Duty Cycle (%) Manifold Relative Sea Level Pressure (Direct)* (psi relative sea level) A/F Sensor #1 (Direct)* (AFR) Mass Airflow (g/s) CL/OL Fueling* (status)
0.28 934 1.59 -7.7 16.75 4.41 8
0.27 904 1.54 -7.66 16.6 4.01 8
0.27 933 1.59 -7.77 16.56 4.13 8
0.27 928 1.58 -7.73 16.35 4.19 8
0.26 944 1.61 -7.73 16.42 4.06 8
0.26 932 1.6 -7.66 16.41 4.01 8
0.27 934 1.59 -7.62 16.74 4.24 8
0.28 936 1.58 -7.6 16.89 4.33 8
0.26 929 1.62 -7.68 16.67 4.08 8
0.27 930 1.79 -7.56 16.57 4.22 8
0.28 942 1.61 -7.72 17.05 4.38 8
0.27 927 1.58 -7.64 16.52 4.16 8
0.27 948 1.82 -7.58 16.39 4.44 8
0.25 957 1.63 -7.73 17.35 4.06 8
0.25 962 1.64 -7.73 17.31 4.03 8
0.26 947 1.62 -7.72 17.61 4.03 8
replace front o2 sensor. it looks like it doesnt know wtf to do.
Old 02-21-2012, 08:10 PM   #2659
WRick
Member#: 86107
it's exactly what I did and it fixed the problem.
I need to have the tune checked, when I feather the throttle, it hesitates a bit. I'll check the bypass valve and clean it up...
thanks gaise
Old 02-21-2012, 08:12 PM   #2660
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
so problem fixed?^ usually the sensors are good for 100k miles and then need to be replaced.
Old 02-21-2012, 09:19 PM   #2661
Eveline198029
Member#: 310983
whats the readline onthe 207?
Eveline198029 is offline   Reply With Quote
Old 02-21-2012, 09:26 PM   #2662
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
7500 on the v7 and 8k on the v8 i believe.
Old 02-21-2012, 10:26 PM   #2663
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
8200 on the v8 =p
jhenry1983 is offline   Reply With Quote
Old 02-21-2012, 10:39 PM   #2664
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
good, ill run my to 8200 then! one week from drop in day. cant wait!
Old 02-21-2012, 11:39 PM   #2665
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Mine has started to idle really rich for no reason, wonder if the sensor needs to be replaced. I thought maybe the timing was off, but it seems to be o.k., see video.
OppositeLock is offline   Reply With Quote
Old 02-21-2012, 11:42 PM   #2666
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
its prob the sensor. they get really hot being closest to the engine and have irratic readings when they get older. more or less go richer because they dont know what to do. its a tell tale sign when doing closed loop on romraider when you get spots all over the damn place. interpolate and redo it and its all over again in new spots. given you have no post maf leaks or boost leaks.
Old 02-21-2012, 11:55 PM   #2667
WRick
Member#: 86107
We killed the sensor when we put the engine in...
All good now! Just need to figure out how i can write over the e**tek lock. I got the map out at least,,,
Finally driving around... Yay!!!
Old 02-22-2012, 10:49 AM   #2668
WRick
Member#: 86107
check the AFR at idle.
solved my problem.
should be around 14.7 , no throttle.
Old 02-22-2012, 01:23 PM   #2669
WRick
Member#: 86107
god dammit I think the MAF died AGAIN ( think... I have another spare, will check )
this is insane
the car ran fine YESTERDAY
new log : https://docs.google.com/open?id=0BxF...VkYWMxMDJkODQw
( click file -- download )
afr's are high, idles horribly, and MAF puts in too much air...
correct me if I'm wrong....
Edit :
I realize I'm hogging this thread alot. I'll start up a new post, hopefull to get some extra feedback...
carry on discussing EJ207'S.
My issues are now here : http://forums.nasioc.com/forums/show....php?t=2314581
Thanks for your time guys.
EDIT # 23525345
nice website to display .csv files : http://csv_display.byethost4.com/?
upload my file into the website and enjoy.
Old 02-22-2012, 06:44 PM   #2670
azscooby
Member#: 115297
2002 ej207 vf34
Hey has anyone done any port and polishing on the TS headers and uppipe?
There are these little ridges just inside each pipe, looks like the welds themselves.
Has anyone sanded these down and smoothed out the welds? Seems like you could see some gains if these were taken down or removed, I just wouldn't want to take them down entirely...?
Old 02-22-2012, 06:53 PM   #2671
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
If you're reaaaaally bored, do it, but I can't see it making a measurable difference on a already highly tuned engine.
n2xlr8n is offline   Reply With Quote
Old 02-22-2012, 07:05 PM   #2672
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
I noticed that on mine as well, not every pipe has the little bump from the weld but one is pretty noticeable. I may try to file it a little, but it is probably pretty hard from all the heat cycles by now.
K1WRC is offline   Reply With Quote
Old 02-22-2012, 08:14 PM   #2673
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
die grinder and dual tip tooth carbide bit works wonders! i do porting work on tgv's and stuff for people and this tool is my best friend! on that note if anyone has down time and wants some port work send me what you got and i can make it look smooth! also gasket match stuff, throttle body, y pipes on tmic. etc.
Old 02-22-2012, 11:55 PM   #2674
azscooby
Member#: 115297
2002 ej207 vf34
Just got my car tuned tonight!
Wow.....nice. Full boost at 3200 rpms (20lbs) and it pulls hard all the way to 8K.
That's quicker spool than my TD04 with 19T wheel - it hit full boost at 3600rpms and the small 16g didn't spool until 4100 on the ej205 of course.
Power is smooth and instant - gotta love this setup.
I really wonder what a vf37 would do....??
Old 02-23-2012, 07:48 AM   #2675
WRick
Member#: 86107
Now im jealous!!
Road tune or dyno?
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
