Old 03-06-2012, 03:29 PM   #2801
WRick
Member#: 86107
Originally Posted by Clark Turner View Post
I had no idea the 725s where the same price as the 1000s. I think you made the right choice though. It is very important to have the right size injector. The current trend today is to buy oversize injectors because they are available. However, the car will run much much better with correctly sized injectors. With 1000s. you would never get much past 50% duty. Now you have to make the car idle, cruise, return good mileage and make power with HALF the injector MS timings. Not a good thing.
C
Well, the car is a DD and an occasionnal track car. But before everything, it's a DD.
Just your feedback on this here... the tuner came last week ( car runs like a champ btw, I think he did a great job ) and scaled down the injector flow rating instead of scaling the MAF for the 70 mm APS intake. First time I heard of that. Besides, it's all chinese to me. ( no offence here lol )
Every done that clark ?
WRick is offline   Reply With Quote
Old 03-06-2012, 04:02 PM   #2802
Clark Turner
Member#: 178047
02 WRX STI Spec C
WTF? Get your money back. You just got licked man. Why do you guys mess around with fly by night parking lot tuners?
C
Clark Turner is offline   Reply With Quote
Old 03-06-2012, 04:13 PM   #2803
WRick
Member#: 86107
C
I took references, don't worry. I've been in the business long enough. When a name comes around ( well, just like yours ) usually it's a good sign. I've seen his work before, and the guy has hundreds ( thousands ? ) done before mine. I trust his competance just like I would trust yours. He's coming back for the 725's. I'll inquire about that.
He did mention two ways of doing things. I guess it's the easier way. There's no point in killing the guy for a result that's there.
Old 03-06-2012, 04:17 PM   #2804
Clark Turner
Member#: 178047
02 WRX STI Spec C
Its your car man. But there is not two ways of tuning injectors and a 70mm intake. Only one. Sorry but its not possible to tune every load calculation by changing a monolithic setting.
C
Old 03-06-2012, 04:26 PM   #2805
WRick
Member#: 86107
C
I'll mention it next time.
I guess he knew it was temporary also. I'll let you know.
Old 03-06-2012, 10:13 PM   #2806
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
C
very true. i just did the bigger intake and larger injectors all at once. by changing the scaling of the injectors you may get it close but the intake will flow much differently through its design than a stock maf housing. air is kinda like a river. its considered a fluid even though its nearly invisible. more can flow around turns on the outside than the inside and the maf needs to be scaled for that intake. the only time i changed injector scaling was to go e85. i just knocked the size of the inject scaling down 28ish% and worked off that. the maf then had to be slightly adjusted again to compensate for the changed in injector flow at that given rate and change of fuel.......
idk if its worth it for you but i think you might want to invest some time in understanding the basic tune to get the car on the road. no need to worry about timing maps. avcs maps, or all that jazz but how the general set of systems work together. then if something goes wrong you have a better idea of what it might be.
WhiteBgeye02 is offline   Reply With Quote
Old 03-07-2012, 09:51 AM   #2807
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
so i pulled a learning view this morning and have no codes but my cel is flashing very fast. the only codes i disabled in the ecu were the rear o2 sensor and the evap system which i deleted. its got no memorized or temp codes. no knock. the afr's are like 1-6% off but i need to scale the maf in a bit better today/tomorrow.
the other thing i noticed is the iam is zero.... my initial starting point is 12. after driving 20 miles it down to zero. is that flashing cel knock? wouldnt it show up on the large table somewere and not be zero's everywere?
Old 03-07-2012, 09:53 AM   #2808
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Did u unplug the intake temp sensor at the back of the intake manifold/throttle bpdy
Jubert39 is offline   Reply With Quote
Old 03-07-2012, 09:53 AM   #2809
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
I thought that a flashing cel was knock...
I once forgot to undo the green connectors once... well.. not exactly. I had a toggle switch connected and flipped it with my foot. I took that toggle switch out that day.
Computersare8ad is offline   Reply With Quote
Old 03-07-2012, 09:54 AM   #2810
WRick
Member#: 86107
looks like you forgot your green ( test ) connector
Old 03-07-2012, 10:08 AM   #2811
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
**** i was going to do that when i got the tmic off yesterday but totally forgot. is that the cel flashing?
no green connectors were not together.
i did read that iam dropping is from knock as well and the car doesnt have to do fine learning knock correction.... it makes it own decisions i guess
Old 03-07-2012, 10:09 AM   #2812
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
its non stop like as soon as i turn the key to the on position it starts a flashing and will do so with the car off. and until i get to were i am going.
Old 03-07-2012, 10:32 AM   #2813
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Yep thats it then. Unplug it. The usdm harness is diff and he intake temp isnt supposed to connected. I had the same flashing cell issue. Shld go away then.
Old 03-07-2012, 10:34 AM   #2814
Clark Turner
Member#: 178047
02 WRX STI Spec C
Flashing cell without engine running means the ecu is in error state. Did you read my post to you about this?
If the flashing cell is when the engine is running, Then one cyl is not firing.
Unplugged coil pack
Bad or damaged plug.
Low compression
Injector unplugged
With the IAM at 0 you had SEVERE knock so a damaged plug or cyl would be likely.
C
Old 03-07-2012, 10:52 AM   #2815
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
If he's using an 03 harness in his swap then he should unplug the IAT sensor under the throttle body . There's several posts about this doesn't mean his engine is bad yet , if it continues then you can look into clarks post. The main thing is its doing it while the car is off but in the on position.
jhenry1983 is offline   Reply With Quote
Old 03-07-2012, 11:31 AM   #2816
Clark Turner
Member#: 178047
02 WRX STI Spec C
I posted this last week. I guess he missed it.
You will get those codes if the maf is unplugged. Make sure its plugged in and seated. Also. If your v7 has an intake temp sensor under the manifold, unplug it. Your 05wrx is not wired for it. The last thing you need to make sure of is that you do not have your Blow by connector installed or shorted out. Some Turbo inlets came with a shorting plug for the blow by connector as there was no place for the sensor. The JDM ecu does not use this sensor.
Old 03-07-2012, 12:13 PM   #2817
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
you want me to unplug the iat sensor only when the car is off but in the on position?
its a 05 wrx. complete v8 long block with harness and inlet and everything
maybe ill take an hour and put in the plugs i used in my last engien for 2k miles. will ngk bkr7eix work?
Old 03-07-2012, 12:42 PM   #2818
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Those are the plugs clark suggests, I used them they work great. As far as the IAT sensor , I was just saying the flashing check engine light if it keeps flashing even when the car is turned off but in the on position on the ignition is usually a strong sign its the IAT sensor plug under the throttle body causing the cel also the cel has no code when you check it. Usually because the usdm harness uses the IAT in the maf sensor where as the JDM uses the throttle body IAT for temp and automatic intercooler sprayer.
You can run your IAT wires from the sensor near the MAF to the one in the throttle body , much better for readings and tuning I'm told.
All this info I've read from vlad and other posts with similar problems. If the cel continues after the IAT throttle body unplug I would read into clarks post on the flashing cel.
Old 03-07-2012, 01:05 PM   #2819
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Listen to this guy. The flashing cel was nightmare for me. Impossible to get info. But i found a post from DS1 buried inside a thread and figured it out. Im almost certain this simple thing will fix ur issue
Old 03-07-2012, 01:10 PM   #2820
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
I actually found
Old 03-07-2012, 01:11 PM   #2821
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
http://forums.nasioc.com/forums/show....php?t=2148803
Lol not to beat a dead horse, but here u go whitebug02
Old 03-07-2012, 01:12 PM   #2822
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
My first info from you jubert39 thanks for your post when you and your brother figured it out, helped me a bunch
Old 03-07-2012, 01:13 PM   #2823
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Weird the moble nasioc app split my post
Old 03-07-2012, 01:21 PM   #2824
Clark Turner
Member#: 178047
02 WRX STI Spec C
If maf based tuning is used. DO not rewire the intake temp sensor to the intake manifold sensor. Leave it on the MAF sensor itself.
C
Old 03-07-2012, 01:26 PM   #2825
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Don't speed density tunes require the iat relocated? I know on the carberry rom for 16bit ecus its required
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
