Old 03-16-2012, 09:58 AM   #2901
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Originally Posted by WhiteBgeye02
you could make a log of your injector duty cycle right now to see how much injector your actually using....
Thanks man
mrxr250rider is offline   Reply With Quote
Old 03-16-2012, 10:23 AM   #2902
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by Z0rr0 View Post
So the other tuners in phoenix are hacks?
No, Clark. you are the hack, and ripoff artist.
I remember a certain tune you did, that ran like ****, would not pull through 1st gear without breaking up, and got horrible mileage.
even on E85, there is NO REASON to have 25 degrees of timing at peak torque, and 30 degrees at redline no wonder the car kept eating head gaskets.
i'll post the timing map as soon as we can find it, but the $2200 that was paid, was thrown away when we took the car to another tuner.
if i remember correctly, you told me to **** myself, only because i told you the tune was not done.
we came away from the other tuner with not only a more powerful tune, but one that RAN CORRECTLY.
and the other car, was my car. you told me that my MAF was maxed out @ 15psi.. well i hate to inform you, without changing a damn thing, the car is perfectly happy @ 23psi, 4.8v maf voltage.
i was waiting for this to happen..... i have been warned but keep my mouth shut.
WhiteBgeye02 is offline   Reply With Quote
Old 03-16-2012, 11:20 AM   #2903
biodude
Member#: 271720
Originally Posted by mrxr250rider View Post
Thanks man
I grabbed IDC when we did those logs. I checked the 3rd grear pull, your at 90-97% IDC from 4800RPM to redline...
wanna buy my 650's?
biodude is offline   Reply With Quote
Old 03-16-2012, 11:58 AM   #2904
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Thanks man.I'm gonna say my cars a bit rich and I plan to get retuned at efi logics. Won't be upgrading my turbo unless it goes out.
Old 03-16-2012, 12:12 PM   #2905
biodude
Member#: 271720
As another option for you , i plan to have Mikey (phatbotti tuning) to come down soon to tune my car.
Old 03-16-2012, 12:25 PM   #2906
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Originally Posted by azscooby View Post
So I finally got my gauges installed so I can see what's going on.
When I do a 3rd gear pull everything looks perfect and all my stats look good, tuner says logs look perfect.
However, when I'm in 5th gear and go wot or mostly wot my boost spikes up to 25 (tuned for 20) and oscillates up and down. It also makes a chirping noise, almost sounds like a leak.
Any other gear seems to be fine.
Any ideas?
This is in my 2002 wrx with v8 ej207 swap w/vf34.
Originally Posted by Clark Turner View Post
The boost system is not tuned correctly man.
C
+1
Definitely overboosting and if you are actually hearing chirping and the car is hesitating/stuttering you might be seeing compressor surge. In either case, boost control needs work and in the mean time drive differently to not have that problem show itself. If it is actual compressor surge that has the potential to cause damage.
Get it looked at.
RexFTW is offline   Reply With Quote
Old 03-16-2012, 12:51 PM   #2907
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Nice he tuned my friends car. Area 1320 does road and dyno tuning. I heard really good things about efi from a lot of people in the tri state. I wanna see what numbers it puts down too on there "dream killer" dyno
Old 03-16-2012, 01:38 PM   #2908
azscooby
Member#: 115297
2002 ej207 vf34
Ok,.thanks for the updates. I will drive it carefully until I can figure it out.
It only does it in 5th gear at low rpm and wot, otherwise it runs great.
azscooby is offline   Reply With Quote
Old 03-16-2012, 01:51 PM   #2909
Clark Turner
Member#: 178047
02 WRX STI Spec C
I emailed you back this morning.
Clark Turner is offline   Reply With Quote
Old 03-16-2012, 03:37 PM   #2910
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
then from how its tuned boost wise its prob not far off!
Old 03-16-2012, 09:31 PM   #2911
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Like others have said, don't go WOT at low rpm's in higher gears. Drive in your power band, downshift!
elevenpoint7five is offline   Reply With Quote
Old 03-17-2012, 09:51 AM   #2912
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Oops Double post
Old 03-17-2012, 09:54 AM   #2913
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I think my car does the same thing low rpms in 4th and 5th. Used to do it earlier but I fixed a turbo inlet leak. Turning the boost down on my actuator would probably fix the problem untill I go for a retune.
Old 03-17-2012, 01:19 PM   #2914
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
if i have an 05 wrx trans and the 03 v8 engine. avcs wont work. so i unplugged it and still get nothing. ma is stuck at .09 and % is at 9.41 and stuck for ovc. think i missed somethig here because the reverse lights still work so i know i didnt unplug the reverse sensor on the trans.
Old 03-17-2012, 01:37 PM   #2915
azscooby
Member#: 115297
2002 ej207 vf34
Make sure you are actually at speed when you are viewing the avcs advance angle, it wont show any advance unless you are moving.
We figured that out the hard way.
Did you get the corresponding NPS?
You also have to be at operating temp...
Stuff you probably already know, but easily overlooked.
Old 03-17-2012, 02:18 PM   #2916
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i just unplugged the nss. when you refer to nps you mean the same rear sensor on the trans im talking about I assume. I have tried at warmed up temps and def moving. third gear pulls specifically dialing in afrs last night.
i guess if you unplug it you still need to jump the plugs with something from the ecu side of the harness to complete the circuit.
Old 03-17-2012, 02:48 PM   #2917
Clark Turner
Member#: 178047
02 WRX STI Spec C
You need to data log the neutral sensor and see if its in the correct polarity. If its backwards, you need to change the sensor.
C
Old 03-17-2012, 03:59 PM   #2918
azscooby
Member#: 115297
2002 ej207 vf34
Yep, what he said.
I believe you can reverse polarity in ECU with certain ROMs, carberry for sure.
But most likely you will need to buy the matching NPS, or use a relay to reverse polarity.
But I'd put money on it being a mismatched NPS/ecu problem.
You've double checked your avcs wiring? I know its very easy to install the wiring "backwords."
Old 03-17-2012, 04:03 PM   #2919
Clark Turner
Member#: 178047
02 WRX STI Spec C
Yes. Some roms do have a switch hacked in.
Old 03-17-2012, 04:32 PM   #2920
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Jun 272's , won't have to worry about avcs anymore, problem solved
fastnoypi is offline   Reply With Quote
Old 03-17-2012, 05:13 PM   #2921
Clark Turner
Member#: 178047
02 WRX STI Spec C
exactly.
Old 03-17-2012, 05:19 PM   #2922
maximus88
Member#: 99103
2003 WRX STI ej207
Yellow
I have a V7 motor, the Power steering pump went bad. What U.S. pumps are compatible with the v7 Sti motor. I am asking because I had a 2003 PS pump laying around but it looks visibly different than the JDM one.
maximus88 is offline   Reply With Quote
Old 03-17-2012, 05:26 PM   #2923
Clark Turner
Member#: 178047
02 WRX STI Spec C
THe pump is smaller as it is later. The US pump will work.
C
Old 03-17-2012, 05:33 PM   #2924
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
C
The us pump is smaller? Im wondering in advance- say i need a new alternator for my v7, can i use a usdm alternator? If so, would i go with a wrx one or sti one?
Jubert39 is offline   Reply With Quote
Old 03-17-2012, 05:37 PM   #2925
Clark Turner
Member#: 178047
02 WRX STI Spec C
You can swap in the US WRX alternator also. Its lower amp rating but works ok. The JDM one was higher rating as the car had Avcs, dccd and HID lights.
C
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
