Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 04-09-2012, 08:49 PM   #3126
WRick
Member#: 86107
Originally Posted by 25rsti View Post
you assploded one what?
a V7 spec C
saved it before doing any major damage.
I rehauled it just in time.
I'm at 2000 miles now
Driving it like I stole it.
WRick is offline   Reply With Quote
Old 04-09-2012, 08:57 PM   #3127
WRick
Member#: 86107
Originally Posted by fastnoypi View Post
..says the guy who wanted to set fire to his ride 2 months ago
I signed it up for soooo many track days ( and long ass ones ) if it survives summer I'll let it sleep in the living room hahaha
deep down, I still hate it lol
Old 04-09-2012, 09:04 PM   #3128
25rsti
Member#: 166324
I wanted v7 for the pistons, but I also didnt want a motor that has been sitting alot longer. I opted for the v9 because it's newer, twin scroll, heads and condition.
Old 04-09-2012, 10:23 PM   #3129
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Originally Posted by jjasonn View Post
got it! thanks vlad. anyway. did u check out the PM i sent to you?
I did. Let me know if/when you get a tactrix cable, let's see what kind of ROM you have. You can use that cable for logging anyway.
Old 04-09-2012, 10:37 PM   #3130
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Looks like I might be going V9 with a V8 ecu, so I won't need to deal with the immobilizer stuff.
So, I took a look in the wrinkleboi thread about swapping an EJ257.
Looks like:
-ECu
-Immobilizer ECU
-Key with transponder
-The antenna is in the light ring arround the key. It may be separated from the ignition key cylinder.
These have to be all matching, the swap vendor would have to provide them.
Then, the USDM has an immobilizer pass-through, through the gauge cluster. This meas that the cluster does not hold any immobilizer components but has a blinking light and such.
In the wrinkleboi thread, one guy skipped the cluster and was able to get the combo to work just fine.
You tape the key to the antenna under the dash, this way you never have to go to the dealer to ask for a spare transponder key for a Japanese model, which they are not likely to ever get done.
http://forums.nasioc.com/forums/show...ht=immobilizer
I do have a connectivity diagram for the immobilizer, that I could post, but it's in Japanese ...
One thing which I was reading is that they flop the pins for the fuel pump controller at the ECU so that you cannot start an immobilizer car with an older ECU.
Of course, you could run the V9 with a reflashed earlier ECU.
Here's a link to a thread where the forum member runs an S204 (which is a V9)with a V7 ECU.
http://forums.nasioc.com/forums/show...2230372&page=2
So basically it's time to move to the V9, guys .
Old 04-09-2012, 10:43 PM   #3131
25rsti
Member#: 166324
Yup! Thanks for all the help throughout the day.
After I finally got home from work I spent a few hours researching here on nasioc and the www. I figured out that stuff and some other stuff.
I spoke with my jdm vendor. They only had the immobilizer and ecu so I decided to go with the V9 and V8 ecu. Plug n play with the IAP kit (which I will be ordering tomorrow)
Old 04-09-2012, 10:45 PM   #3132
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
True true. Most likely I will only be using the longblock and reusing all my other stuff.
Deciding not to use the 30r now?
fastnoypi is offline   Reply With Quote
Old 04-09-2012, 10:53 PM   #3133
25rsti
Member#: 166324
Negative, I still will be. No problem not to. Clark even said he's tuned many v7-v9 with 30Rs, even some 35s.
Old 04-09-2012, 11:06 PM   #3134
25rsti
Member#: 166324
Vlad, Do you know if the V9 Spec C cams are the same as the V9?
Old 04-09-2012, 11:09 PM   #3135
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
ok, thought you weren't since you mentioned twinscroll, you wont be using that twinscroll uppipe then.
Old 04-09-2012, 11:17 PM   #3136
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
if you were good and depending on what flange the turbo has, you could possibly get a twin scroll exh side in t3/4 and then bring each of the v8 up pipes to each inlet on the flange. weld the inside then a cover piece on each outside part and it would tech be twin scroll t3/4 flange. should help down low! i am currently in the process of trying out a new style quickspool valve we prototyped and machine up in the next week. should help the big basketball turbo my friend has spool before 4500rpms.
WhiteBgeye02 is offline   Reply With Quote
Old 04-09-2012, 11:20 PM   #3137
25rsti
Member#: 166324
haha not on this car. I have two bugeyes. I will using the v9 longblock, p.steering and a few other little things then swapping all my other bits onto it. Then whatever comes off the v9 will be going on my hybrid longblock for the other car.
Old 04-09-2012, 11:38 PM   #3138
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
sure, you can do almost anything with custom fabrication, you can even run the uppipe to your trunk to run your turbo rear mount mustang style if you want
Old 04-09-2012, 11:49 PM   #3139
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I think moore posted recently about making some custom uppipes in the stock location twinscroll thread.
Old 04-09-2012, 11:55 PM   #3140
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
really? ill have to go check them out. i am more or less really intersted to see how the improve quick spool valve will work. anyone on here try them yet? or do you guys just leave it up to the supra guys with beach ball sized turbo's lol.
Old 04-10-2012, 12:03 AM   #3141
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Talking about other communities, the 3000gt guys moved (after garrett ballbearing cartridges and after machined compressor wheels) to medium sized Titanium Aluminide turbine and shaft.
According to a coworker, apparently they can spin wheels by flooring from cruising rpm's.
We have them in the Borg Warners, but that's a big turbine-shaft unit and that denies the weight savings, I think.
There are the VF42, but too rare and too expensive, probably not long lasting either and I don't think they can touch 300whp on pump gas.
Old 04-10-2012, 12:05 AM   #3142
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i've only seen the supra guys run them, and i doubt many do because they can sit on the line to build up boost when they want to spool for 1/4 mi or Texas mile type events on their big turbos. That is if you are talking about that valve Sound Performance has to sit inbetween the exhaust manifold(uppipe) and turbo hotside inlet.
Since they are actuated off of boost pressure, i'm skeptical if it would be practical rather than just getting a smaller hotside for your application. If you do try it out, share the results!
Old 04-10-2012, 10:51 AM   #3143
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
its mainly for building boost faster. yes the valve placed between the up pipe and turbo hot side. it should help accelerate the air into the single scroll. we are going to try it to see the difference with it always closed to when it will open prob around 15psi. my friend is going for 450whp on pump and prob pushing it to 600whp on 113 octane leaded fuel. if its too big he is going to downsize to a borg warner 200 series so its more street friendly.
Old 04-10-2012, 12:46 PM   #3144
25rsti
Member#: 166324
I was running an idea through my mind this morning. I have two bugeyes. A Black one with an 03 wrx harness and ecu, the other, white, with an 05 sti harness and ecu. Could I swap the jdm v9 engine in the white one, install in the jdm v8 ecu and be ok or would the usdm immobilizer issue come up?
Old 04-10-2012, 05:05 PM   #3145
azscooby
Member#: 115297
2002 ej207 vf34
Have an of you guys bought or are you familiar with the downpipe option from Tomioka Racing? Sold through EDO Performance.
It is supposed to be twinscroll flanged and usdm length.
However someone on the boards here says that is is not usdm length and not 3" as advertised.
Are any of you guys familiar with this pipe?
I'm looking for a TS downpipe that is plug and play.
azscooby is offline   Reply With Quote
Old 04-10-2012, 05:15 PM   #3146
25rsti
Member#: 166324
Can I ask, what's the sense of a twinscroll downpipe? It's all going out one pipe throught the exhaust.
Old 04-10-2012, 06:09 PM   #3147
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
If you have a twinscroll turbo you need a twinscroll dp as the flange is different.
LIQUIDSK8S is offline   Reply With Quote
Old 04-10-2012, 06:42 PM   #3148
25rsti
Member#: 166324
ooo. Here I am thinking I know stuff. haha
I thought it was only twin scroll header, uppipe and turbo.
Well, I will be seeing mine Fridy-Monday
Old 04-10-2012, 06:57 PM   #3149
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
I know tomei makes a twinscroll dp but its jdm length. I was looking at cutting up a usdm length dp and having the kiquwara or w/e their name is twinscroll flange welded on
jhenry1983 is offline   Reply With Quote
Old 04-10-2012, 07:24 PM   #3150
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Does anyone have a v7 spec C or v8 ECU they want to sell. Heres the catch, it CANT have the ECUTEK software on it. The JDM ECU I have currently in my car has ECUTEK and as such, its locked. I can't get it tuned open source unless it's through ECUTEK. I plan to do some mods in a few months, and would like an ECU that I can tune with without any problems. Thanks!
Jubert39 is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
