Welcome to the North American Subaru Impreza Owners Club Sunday April 20, 2014
Old 04-10-2012, 06:41 PM   #3151
WRick
Member#: 86107
Originally Posted by Jubert39 View Post
Does anyone have a v7 spec C or v8 ECU they want to sell. Heres the catch, it CANT have the ECUTEK software on it. The JDM ECU I have currently in my car has ECUTEK and as such, its locked. I can't get it tuned open source unless it's through ECUTEK. I plan to do some mods in a few months, and would like an ECU that I can tune with without any problems. Thanks!
Pm'd.
WRick is offline   Reply With Quote
Old 04-10-2012, 07:27 PM   #3152
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Here are some info on JDM ecu #s and Engine Codes I was able to find yesterday...Not sure if it's 100% correct.
ECU
V7 AF480 AF481
V7 Spec C AG970 AG971
V8 AH580 AH581
V8 Spec C AH590 AH591
V9 AJ810 AJ811
Engine Codes
GC
MY99 STi5-EJ207DW1PR
MY00 STi6-EJ207DW2PR
BUGEYE
MY01 STi7-EJ207DW3CR
MY02 STi7-EJ207DW4CR
PEANUT/BLOBEYE
MY03 STi8-EJ207DW5CR
MY04 STi8-EJ207DW6CR
MY05 STi8-EJ207DW7CR
HAWKEYE
MY06 STi9-EJ207DG8CR
MY07 STi9-EJ207DG9LE
MY07 STi9-EJ207DG8TR-S204
Old 04-10-2012, 07:31 PM   #3153
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
just get the kinguanga turbo company downpipe elbow for 115 bucks. buy a cheap ebay stainless downpipe, cut the downpipe and bam. 3" catless downpipe that bolts up and correct length.
then sell your expensive downpipe to some noob that needs one!
WhiteBgeye02 is offline   Reply With Quote
Old 04-10-2012, 07:37 PM   #3154
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
as far as getting a ecu, contact a vendor and ask them if they got extra's. prob your best bet.
now for the tuners professional and at home guys. i have a few questions with your setups and how its running.
As far as timing goes i know the ej207's like timing and not tons of boost. what are you guys running for peak timing and timing at 7k rpms and 8k rpms. I think mine is way high but I have yet to see any flkc or iam drop or anything. i need to check to make sure the knock sensor is working correctly this weekend.
next is avcs. does anyone have different maps? like group n, or s203/4, spec c's v8/9? i would love to see a stock rom off one of those ecu's.
lastly how fast does everyones v8 vf37 spool in a third gear pull starting at 2500 rpms. say 20psi. it seems like mine is only simular to single scroll vf34 setups now and I would just like an HONEST comparison. not a pissing match who spools faster.
oh one more thing. how in the hell do you guys tune avcs to get any performance gains. i know alot of these tunes lie in the avcs maps. mine is stock still and looks like a cluster! it switches around so fast around small accelerations around town i wonder how the af learning keeps up with the different loads and different rpms.
Old 04-10-2012, 07:52 PM   #3155
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Old 04-10-2012, 08:24 PM   #3156
Vlad
Member#: 46135
02 WRX
Powered by Sti V9 Spec C
I say continue to monitor the knocking conditions and draw your own conclusion, based on what you see.
If you look around, you'll find the ROM for all the versions.
The S cars will have more aggressive AVCS. Some had success running AVCS based on that.
Some that made AVCS tests showed results in curves that seemed to indicate in this direction as well.
Old 04-10-2012, 08:30 PM   #3157
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by 25rsti View Post
do you understand what they are saying on that site cause i sure as shi t dont.
Old 04-10-2012, 08:42 PM   #3158
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well i found these a while back but they dont include the special roms i listed.... search continues.
http://www.romraider.com/forum/viewt...hp?f=35&t=7591
edit! they are hidden within this list, now i just need to find them.
as far as timing goes. it scares me because im running more timing than stock on 93 octane with no knock. i have not even seen false knock or shift knock. i really need to get a different knock sensor to see if its just mine or what. for how much I have been ripping around on it ie on ramps and drifting in the rain. it pulls very hard and shows no signs of stopping. if someone could just throw a number out there of what they see at peak hp and 7 or 8k rpms for timing i would appreciate it. even if its in a pm. i dont want your timing map or anything. just two numbers from an aggressive tune. specifically the veterans of tuning these engines.
i am running about 10.8/9 right now until i get my 08 sti tmic and splitter setup. maybe the extra fuel is helping prevent knock since its too rich/wet to ignite "too" early in the stroke causing knock.
Old 04-10-2012, 09:01 PM   #3159
WRick
Member#: 86107
I have an s202 ecu, I'll look up my CalID and we'll compare the maps tomorrow... I don't think my ecu has any thing different than any other 01/02 jdm sti...
Old 04-10-2012, 10:06 PM   #3160
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
As far as timing goes i know the ej207's like timing and not tons of boost. .
how did you get this conclusion?
fastnoypi is offline   Reply With Quote
Old 04-10-2012, 10:08 PM   #3161
Clark Turner
Member#: 178047
02 WRX STI Spec C
Good question.
Clark Turner is offline   Reply With Quote
Old 04-10-2012, 10:11 PM   #3162
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
i have the same S202 ecu, it is physically different than my v7 ecu when i pulled the cover, but functionally the same. Perhaps there are some other pins utilized for that specific car.
Old 04-11-2012, 12:32 AM   #3163
i2cou4u2
Member#: 246455
2004 WRX Wagon
Originally Posted by Clark Turner
Good question.
Hey Clark, have you had a chance to look at my logs of my Ver. 8 I emailed to you?
Thanks
i2cou4u2 is offline   Reply With Quote
Old 04-11-2012, 05:37 AM   #3164
jjasonn
Member#: 208653
2004 V-Limited
Spec C
i do because i'm japanese. lol
its a 2007 STi ECU.
Engine Code:EJ207DG8CR
Transmission Code:TY856WB7KA
Distance Traveled: 49945KM
jjasonn is offline   Reply With Quote
Old 04-11-2012, 07:27 AM   #3165
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
You sure it' not 2006? Wouldn't 07 be a GR?
Old 04-11-2012, 07:31 AM   #3166
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Yes Im 100% sure.
USDM year models and JDM models are different.
JDM produced what u called Hawkeye up to 2007 and rolled out the GRB on 2008. Thats why u could see alot of 2007 STi EJ207 is pretty much the same as 03-07. Starting from 08 onwards, It's what we called the GR engine that comes with a plastic manifold instead of the red ones with a bigger STi TMIC.
Based on the model codes above, I knew that this was a GDB-F. Which us Japanese called it the version F or USDM market that called it the Version 9. GRB was produced in 2007 but if i didnt remember it wrongly, Subaru rolled them out on July 07 and continued the sales of GDB-F up till 12/2007.. Thats why you have Hawkeye on 2007. :-))
You can see the Start of Sales date here for GR, http://cars.jpn.org/body/mdl0070007.html
and here for GD, http://cars.jpn.org/body/mdl0070023.html
Bugeye - 01 - 02
Blobeye - 03 -05
Hawkeye - 06 - 07
GRB - 08 onwards.
Hope the above can clear your doubts.
Old 04-11-2012, 07:41 AM   #3167
mike280
Member#: 161437
02 WRX Wagon
EJ207
How much boost is everyone running on their EJ207 with VF30?
I'm running 17-18 PSI with EWG. thinking of going hybrid with the manual boost controller and ebcs I have never liked the way boost is handled by the stock ECU
mike280 is offline   Reply With Quote
Old 04-11-2012, 08:47 AM   #3168
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I'm gettin tuned soon. I was at 21psi on the ebcs. I upgraded to an avo adjustable actuator. And it holds boost to redline and response is better. Not sure if that helps any since I need a tune but I'm getting tuned the 21st.
mrxr250rider is offline   Reply With Quote
Old 04-11-2012, 02:12 PM   #3169
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I posted ecu codes a few post up but found out this is my ecu code and havent seen this one. Any insight?
AL300
Also, a different ecu code, AH190 (pretty sure v7-v8)
Old 04-11-2012, 02:25 PM   #3170
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i forget but im pretty sure someone reputable on this thread said it a long time ago. i know there are i guess you could say so called ratios, larger turbo means you can run higher boost levels blowing less hot air. in turn possibly running more timing in the same cells.
anyways anyone want to share two numbers with me. even if its in a pm?
Old 04-11-2012, 04:53 PM   #3171
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
please dont flame me for asking this- it may have been asked
I have a v7 spec C type RA engine. My current ECU is ecutek locked. Anyone know if a regular v7, v8, or v9 ECU will work? I can get a v9 ECU, but not sure if it will be compatible with my car. Thanks!
Jubert39 is offline   Reply With Quote
Old 04-11-2012, 05:18 PM   #3172
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Dont get the v9. Get a v7 or v8. The v9 has avcs but will, if not spec c, have the immobilizer issue.
Old 04-11-2012, 06:11 PM   #3173
Clark Turner
Member#: 178047
02 WRX STI Spec C
Thanks
All my email is done so if you dont have a response, It went to spam or I did not get them.
C
Old 04-11-2012, 06:13 PM   #3174
Clark Turner
Member#: 178047
02 WRX STI Spec C
You likely do not have a Spec C RA engine. But you can use the RA ecu or any V7 ECU. There are issues with 8, and 9 ecus. Some can be worked around but you likely cannot run the correct rom for your engine. Order a V7 STI or RA ECU as a replacement. It really sucks that ECUtek did that to you man.
C
Old 04-11-2012, 06:17 PM   #3175
WRick
Member#: 86107
C
Engine # would help.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain 21 10-17-2005 01:56 AM
