Old 01-01-2009, 10:54 PM   #301
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Yeah, mine are 2 and 4, both girls, and usually ask or tell really..."go fast daddy" a short first or second gear pull keeps um sayin "that was fast daddy" for the entire car ride.
Lol...and you had asked about aggressive and the tune, honestly, I don't tune my car any other way but aggressive. Basically if the car will take it, I tune it that way. I am sitting at the 24psi for the 93 octane now, but I'm still running the stock map sensor, so I think thats my limit at the moment. I pretty much always have a laptop with me, so If the tune needs a change, I'll do it then. Usually end up making most of the changes at the track since the street tunes although they work at the track, always show there limits there...mostly small timing changes.
lol...lemme run man my kids are going bezerk, and the wife is giving me those stares...lol
ttyl
Trey
treystoys is offline   Reply With Quote
Old 01-04-2009, 06:17 PM   #302
treystoys
Member#: 97436
03 toyota tundra
Hey guys...been working on the tune a bit, and wanted to post a few things. First, I incorrectly stated the other day that I see full boost 24 psi at 3900rpm, while on that log, I did infact see full boost at 3900, I started that pull at just over 3000rpms, while I normally start at 2k. So the engine was already in a meatier part of the powerband and it hit 24psi at a few rpm over 3900. My first statement with spool in the 42-4300rpm range is correct, and what I am seeing consistantly starting a 3rd gear pull at 2k.
Another positive note would be that I have been able to run a good 2-3 degrees total timing between 5400 and redline over my stock location 2.5r set up. I guess that would be a given to guys who do this for a living, but myself being relatively new to tuning it wasn't. I'm guessing its an efficiency thing being the same boost levels between the 2 set ups, the 3076 rotated kit is providing a cooler charge at the same boost levels and allowing the extra timing.
Anyways, figured I'd update, and bump the thread. The track is opening back up this wednesday, so I'll have some numbers then, given the weather cooperates of course.
ttyl
Trey
Old 01-05-2009, 05:12 AM   #303
yods
Member#: 157748
Just finished through this thread and wow, so much info. My gen3 outback just got its V7 transplant and I've been having a lot of fun since. The only time I ever pondered "what if I'd gone the 257/255 route" was when I was driving in peak hour, up a hill (an hour to go 5k's) with an engine crane in the back" - Had to slip the clutch til about 2-2.5 grand and gradually release. Every other time the EJ207 gets to 3 or 4 grand (and then 8!) so quickly it barely feels like theres no spool up time at all. Funnily enough, on my old EJ20G it felt like an eternity..
yods is offline   Reply With Quote
Old 01-05-2009, 12:18 PM   #304
Special
Member#: 145585
2002 S202 [email protected]
Yellow
Are there any members who have the EJ207 and the Dom 3 with a C16 race gas tune? If so, what were your numbers? How much boost were you running?
Special is offline   Reply With Quote
Old 01-13-2009, 10:08 AM   #305
93240sx
Member#: 137052
9102 chukibug
silblue
great thread (i just found it). i'm pretty set on getting a v7 207 motor for my 02 wrx. i just have one question that i don't think has been answered yet....
i won't destroy my 5spd tranny with the 207 will i? i know how to drive pretty well and haven't had any drivetrain issues. when i pulled the tranny to replace my stock clutch (15k miles on the clutch), it barely had any wear around the outer edge of the disc.
advice please? thanks ahead of time.
93240sx is offline   Reply With Quote
Old 01-13-2009, 11:43 AM   #306
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
should be ok if your not throwing a good turbo on, just take it easy, but eventualy if your pushing lots of power you will probably break something
seanathanq83 is offline   Reply With Quote
Old 01-13-2009, 11:55 AM   #307
Clark Turner
Member#: 178047
02 WRX STI Spec C
Thats something that nobody can answer. I did it and never had an issue with the gearset itself. I broke everything else though.
Clark
Clark Turner is offline   Reply With Quote
Old 01-13-2009, 02:20 PM   #308
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
I'm thinking about heading this direction. Found myself a v7 motor with v8 heads for a really good price. Now I just gotta talk myself into purchasing a motor.
02aspenwrx is offline   Reply With Quote
Old 01-13-2009, 04:01 PM   #309
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
do it daniel, just do it. i want a v7 motor with v8 heads..
ownnij is offline   Reply With Quote
Old 01-13-2009, 08:06 PM   #310
sti_02
Member#: 179470
Clark
Can I ask what were the things that you did break?
sti_02 is offline   Reply With Quote
Old 01-13-2009, 08:45 PM   #311
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i had my 5sp for close to 100k miles on the V7 before i sold it for a 6sp. nothing was wrong with it when it was pulled. If you shift smooth and dont' plan to shock your tranny with launches it should last quite a long time.
fastnoypi is offline   Reply With Quote
Old 01-14-2009, 12:10 PM   #312
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
Yeah, I'm gonna go take a look at the motor sometime this week and see what's up with it. I will finally be a all out bugeye sti if I get this.
Old 01-15-2009, 08:26 PM   #313
treystoys
Member#: 97436
03 toyota tundra
http://forums.nasioc.com/forums/show....php?t=1678349
Some results for you guys to cehck out!
About the tranny, if your a big drag racer, you may tear up the tranny. I went though one clutch, one rear end, and about 220 drag strip passes before my 05s tranny lost second gear.
ttyl
Trey
Old 01-16-2009, 12:03 AM   #314
scoobyauSTIn
Member#: 171025
'98 Forester L
andrewp724's wagon has a v8 207 with a blouch dom 3.0 and it is effin fast. Check it out.
http://forums.nasioc.com/forums/show....php?t=1536323
scoobyauSTIn is offline   Reply With Quote
Old 01-16-2009, 08:04 AM   #315
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
I've got a EJ207 V7 in my wagon and i love it. i'm hoping to get around 300awhp with a few extra mods at the moment.
What's on the car (that i remember):
JDM ECU
VF30 Turbo
STi 565 Pink Injectors
Catless 3" HKS downpipe
3" XR1 Borla Cat-Back
STi fuel pump
custom tune
The plans (for sure):
255 Walboro
External Wastegate
New Up pipe
New Tune
Possible Mods:
Bigger Injectors (not sure what size i'd bump to, or if it'd be overkill though)
FMIC or Bigger TMIC to keep sleeper status
Some sort of cold air intake
I love the power the car has in near stock form, so i can't wait to see what happens with some more power mods.
Here's a pic of my wagon:
~Alex
Xcelr8to1320 is offline   Reply With Quote
Old 01-16-2009, 11:38 AM   #316
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
if anyone is willing, please toss in some advice in this thread, thanks.
http://forums.nasioc.com/forums/show....php?t=1679145
~Alex
Old 01-16-2009, 10:10 PM   #317
Wanarex
Member#: 173034
It was asked already but not answered. What are the differences between a V7 ej207 and the 207 RA Spec-c? Why can the Spec-c rev to 8500?
Wanarex is offline   Reply With Quote
Old 01-16-2009, 10:18 PM   #318
treystoys
Member#: 97436
03 toyota tundra
Alex, I'd go for a tdo6 18g, and some 650cc injectors...that and about 20-22psi should land you right north of 300whp external gate or not.
Trey
Old 01-16-2009, 10:29 PM   #319
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Ver7 RA-C has bigger port heads and better cams than the regular 207 (although it's the same heads as the regular Ver 8 207). The RA-C also came with a silicon inlet, vf34 turbo, and different ecu. There was another version of the RA-C called the limited that had aircon and the regular intake/vf30, but still had the trick ECU and nicer heads.
Both versions can rev to 8,500, but I'm guessing that the RA-C would be better off due to the better heads.
subydude is online now   Reply With Quote
Old 01-17-2009, 12:16 AM   #320
Wanarex
Member#: 173034
Thank you much subydude!
Old 01-25-2009, 09:00 PM   #321
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
Trey
Im currently running a v8 EJ207 with a VF39 and when i flashed the computer with a v7 map (280ps) last time i was on the dyno i put down 275ps to the wheels. after that i flashed it to a S202 map(320ps) havent been back to the dyno yet but i can tell that there is more power after the flash. next is 16g td05.
wopdeeze is offline   Reply With Quote
Old 01-25-2009, 09:57 PM   #322
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
Were are you all getting your full EJ207 longblocks? I need to get one soon
Can someone PM me where you can get them? Thanks!
emsmap is offline   Reply With Quote
Old 01-26-2009, 11:48 AM   #323
Special
Member#: 145585
Yellow
JdmRacingMotors sells them if you are interested. PM them.
Old 01-26-2009, 07:24 PM   #324
561wrx
Member#: 166427
03 wrx
first question how long dose it take to put in ej207.
the next thing is how is the wiring.
and what tunning program u all r using for ecu.
561wrx is offline   Reply With Quote
Old 01-26-2009, 07:26 PM   #325
561wrx
Member#: 166427
03 wrx
Can someone PM me where you can get them? Thanks![/quote]
they good with the pricing
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
