Old 04-28-2012, 11:53 AM   #3301
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Anyone know if the OCV solenoid is the same on a vers 8/9 as any other usdm model or do I need to special order a part?
Thanks!
Computersare8ad is offline   Reply With Quote
Old 04-28-2012, 12:12 PM   #3302
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Old 04-28-2012, 01:41 PM   #3303
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Ocv??
WhiteBgeye02 is offline   Reply With Quote
Old 04-28-2012, 03:10 PM   #3304
Erik
Member#: 168774
Thanks!
You can buy the JDM ones here:
http://www.iaperformance.com/product...oducts_id=2540
Erik is offline   Reply With Quote
Old 04-28-2012, 04:02 PM   #3305
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
hahaha makes sense now!
Old 04-28-2012, 05:26 PM   #3306
Erik
Member#: 168774
ocv=oil control valve
Old 04-28-2012, 06:39 PM   #3307
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Any idea which side is bank 2?
Old 04-28-2012, 07:36 PM   #3308
Erik
Member#: 168774
I believe it's the drivers side.
Old 04-28-2012, 08:07 PM   #3309
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Thanks! Very helpful!
Old 04-29-2012, 05:50 PM   #3310
rstinut
Member#: 143993
2011 wrx
white
Originally Posted by WRick View Post
yeah I've seen worse than canadian fuel.
94 oct oump is nice up here, but at 1.58 / L this morning ( it's cheap this week ) that brings it to 3.79L ( 1 US GAL ) = 5.99 $ CAD
5.99 CAD = 6.09 $ USD per gallon. Do the math.
I call it rape fuel.
Last week I filled @ 1.68 CAD / L for 94 oct.
Lol! petrocan FTL I find shell 91 vpower is a lot more consistant since it doesnt contain any ethanol!
John
rstinut is offline   Reply With Quote
Old 04-29-2012, 05:58 PM   #3311
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
John
"all shell gasoline products contain atleast 10% ethanol"
Quoted from my local gas station.
I still ONLY get shell gas though. Definetly better than rutters.
ManualOverAuto is offline   Reply With Quote
Old 04-29-2012, 06:33 PM   #3312
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
Shell 91 here in Calgary contains no ethanol.
Zaider is offline   Reply With Quote
Old 04-30-2012, 10:04 AM   #3313
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
About fuel pressure regulators:
V7, (rev A & B) had the same part number with USDM WRX, EJ255 and rev F EJ257. This is on the passenger side (right US).
V8 & 9 (rev C-G) have the fpr on the driver's side (left US). There is no US equivalent for this.
Clark was posting a long time ago that some OEM regulators provided increased static fuel pressure, by 10 PSI.
At the time he was writing about a deeper dimple and sti mark.
Clark, which side of the engine were the uprated fpr that you found, was it the driver's side (left US) configured regulator?
Old 05-01-2012, 10:17 PM   #3314
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
turbo upgrade? help me out guys
any good turbos that will work with my sti pinks and 255 pump? looking for a bolt on better replacement for my vf30
mrxr250rider is offline   Reply With Quote
Old 05-01-2012, 10:18 PM   #3315
Clark Turner
Member#: 178047
02 WRX STI Spec C
You are out of fuel now. Upgrading the turbo would make matters worse.
C
Clark Turner is offline   Reply With Quote
Old 05-01-2012, 10:31 PM   #3316
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
mrxr250rider!:
i got 800 cc injectors for sale. A dom1.0xtr or something would bring good gains. just need a set of larger injectors! fuel pump should be good for a lot more power!
Old 05-01-2012, 10:34 PM   #3317
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
opps!
Old 05-01-2012, 10:38 PM   #3318
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
thanks clark. my injectors will prob be maxed with 21psi.
C
mrxr250rider!:
ill keep that in mind. injectors,plus turbo plus install would prob cost alot though so maybe in the future. i put down 298whp/264tq with 18psi and going back for a 21psi tune. i had a weak coil pack before. 330whp would be nice
Old 05-01-2012, 10:48 PM   #3319
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
what kinda dyno you putting those numbers down on? i am arond 300whp right now at 20psi but i had it taper off up top so i didnt push the vf37 too hard. honestly i dont know what kinda psi pushes this turbo too hard. I need to track down a compressor efficiency map and see what it shows.
just install the parts yourself and save the money. its super easy to do. first time you could prob do a turbo and injectors in three hours.
Old 05-01-2012, 11:17 PM   #3320
Clark Turner
Member#: 178047
02 WRX STI Spec C
You guys are not making 300 and over with your pinks and V7 motors. Wishfull thinking.
Old 05-01-2012, 11:34 PM   #3321
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
its all i got for now. im sure after some correction factor from temp/pressure its prob around 285. im on 850 inj with a vf37 V8 engine but not much difference.
Old 05-02-2012, 12:22 AM   #3322
Zaider
Member#: 154281
MBP
Picked this up today...
Untitled by zcherniawsky, on Flickr
Dom 1.5XTR
Looking forward to seeing how it does on my V7 EJ207 swap.
Couple of questions before i begin the turbo swap:
1) Does the V7 EJ207 have that stupid oil filter sitting in the banjo bolt that clogs? For the life of me, I cant remember if I took care of this while I was doing the swap.
2) Does the EJ207 use the STI or WRX oil feed line? Im 99% sure its the STI line but I'd like to be sure. I have both (Blouch uses the same line, just different fittings on one end) but want to know in advance.
Thanks in advance.
Old 05-02-2012, 06:56 AM   #3323
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I deffinatly am it was on a mustang dyno at efi logics which is a low reading dyno so I trust that number. I'm full bolt on
Old 05-02-2012, 07:51 AM   #3324
mike280
Member#: 161437
02 WRX Wagon
EJ207
Dom 1.5XTR
Thanks in advance.
Please keep us updated on your progress. I want that turbo.
1. probably has filter but I think it was figured out earlier in the thread.
2. STI type.
mike280 is offline   Reply With Quote
Old 05-02-2012, 08:56 AM   #3325
Zaider
Member#: 154281
MBP
2. STI type.
Yeah. I'll post up the results when I get it tuned.
Thanks. I'll check the banjo bolt for the filter just in case.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
