Old 05-02-2012, 10:36 AM   #3326
WRick
Member#: 86107
Anyone running Speed density on their 207's ?
Where have you mounted the iat ?
I planned on putting it between the bpv and throttle on the lower end tank of the I/C. I'm trying to think of solutions to prevent it from heatsoaking, and/or assploding the engine.
I'm also having difficulty finding a compressor map for the Td05h-18g, ( MHI did not make one public from my understanding ) and only found one based off the 20g.
20-22 psi should be realisticly within this turbo's efficiency range ?
WRick is offline   Reply With Quote
Old 05-02-2012, 11:05 AM   #3327
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
if i was pushing 22psi on my td04 without problems you should be able to run a 20G at 20psi nearly to redline. why dont you use the stock location found on the V8 manifolds. under the throttle body there is one. if you dont i think my friend used one of the flat circle locations under the throttle body on the intake mani. tapped a hole for give intake sensor. the GM iat sensor is widely used and the scaling is pretty commonly found as well. figure out what threads it uses. tap it. install. change scaling in rom to match the Voltage and temps of the GM sensor. run the wires that are on the maf that run iat to the new sensor lines. might need to add a few feet of wire but no big deal.
WhiteBgeye02 is offline   Reply With Quote
Old 05-02-2012, 11:07 AM   #3328
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
its a good idea to check the avcs banjo bolts too. they might also have a filter but i dont recall. i want the same turbo as well but TS version from blouch. its too bad its 1700 dollars.
Old 05-02-2012, 12:24 PM   #3329
WRick
Member#: 86107
yeah thats the plan.
I found a gm iat with pigtail for 30 something bucks.
I hadn't noticed under the TB but the casting scares me for the heatsoak on the sensor, and that's its really close to the engine block.
Old 05-02-2012, 04:28 PM   #3330
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
get phenolic spacers, the airflow inside will overcome with little bit of radiant heat the sensor body see's. otherwise cover it in aluminum foil.
Old 05-02-2012, 05:03 PM   #3331
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
Same price (basically) as the single-scroll version... but if I wanted twinscroll, Id need everything else too....
Im trying so damn hard to go to work for the rest of the week and wait until Sunday to install it.
Zaider is offline   Reply With Quote
Old 05-02-2012, 05:34 PM   #3332
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
no way i could wait. take the week off and do some wrenching! too bad i got finals and end of semester exams all within a 2 week stretch here. no time until after except for work and school.
Old 05-02-2012, 08:47 PM   #3333
Zaider
Member#: 154281
MBP
It helps that Im still waiting for my spark plugs and a couple backup bolts/nuts from Subaru.
Old 05-03-2012, 10:23 AM   #3334
Special
Member#: 145585
2002 S202 [email protected]
Yellow
Hi, my braided oil cooler line was pressing against my headers and burst. I need to order more lines but just wanted to confirm that the EJ207 Spec C oil cooler lines and fittings are Dash 10 in size. I have searched all over to find the answer and haven't been able to.
Thanks
Mike
Special is offline   Reply With Quote
Old 05-03-2012, 04:31 PM   #3335
25rsti
Member#: 166324
My motor (v9) didnt come with any intake. Wondering what you guys like on your jdm motors. Should I look for a stock one, aftermarket short ram intake, cold air intake or get what I've been eyeing for a few days (arc shortram airbox)??? Much appreciated guys!
Old 05-03-2012, 05:09 PM   #3336
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
get a stock one with the snorkel and a nice filter. or get a CAI. a sri just leads to high iat and heatsoak on the intake in general. fresh cool air is the best!
Old 05-03-2012, 05:29 PM   #3337
25rsti
Member#: 166324
I just hate risking and worrying about water getting into the intake.
Old 05-03-2012, 07:34 PM   #3338
mike280
Member#: 161437
02 WRX Wagon
EJ207
I have an APS 65mm CAI. no problems with water in 4 years or so.
If you have a stock box just run that unless you are changing anything major engine wise.
mike280 is offline   Reply With Quote
Old 05-03-2012, 07:38 PM   #3339
25rsti
Member#: 166324
I dont have any intake. That's why I want opinions, on just get stock or what people like on their jdm motors. Thanks for your opinion, Mike.
Old 05-03-2012, 07:56 PM   #3340
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
run a dry sock over the filter. i have one and have never had an issue with it preventing air flow. you can run a sink over them and no water goes through.
Old 05-03-2012, 09:19 PM   #3341
kaj
Member#: 290109
2005 WRX
without reading 134 pgs... are people able to pass smog with the 207s in Kalifornia? it sounds like a REALLY nice engine, if i end up keeping my car.
kaj is offline   Reply With Quote
Old 05-03-2012, 09:27 PM   #3342
Clark Turner
Member#: 178047
02 WRX STI Spec C
207 ECUs are not obd2 compliant. They will not pass the IM240 test
C
Clark Turner is offline   Reply With Quote
Old 05-03-2012, 10:03 PM   #3343
kaj
Member#: 290109
2005 WRX
C
yeah. wasn't sure if someone had found a way around that. meh. i can't wait to get out of this state. we can't do anything fun to our cars. not even tint the side windows to keep the 110*+ heat out.
Old 05-03-2012, 10:25 PM   #3344
Clark Turner
Member#: 178047
02 WRX STI Spec C
Some of us got lucky in the past and the computer would pass even though it could not read. But with the latest tests, They fail you. You can of course use the US ECU
Old 05-03-2012, 10:54 PM   #3345
kaj
Member#: 290109
2005 WRX
but i won't be able to control the AVCS? sorry to ask as i'm sure these are the same old questions that have been asked a million times.. is there a thread i can read so you don't have to keep reiterating all the info? LOL
i'm very curious about this swap. it sounds like i would be extremely happy with the engine. MIVEC made a huge difference on my Evo, compared to the non-MIVEC engines... so the idea of AVCS and an 8k rev limit is RIGHT up my alley.
Old 05-04-2012, 07:18 AM   #3346
mike280
Member#: 161437
02 WRX Wagon
EJ207
it will run without avcs. Search just this thread for the info, it's here.
Old 05-04-2012, 12:27 PM   #3347
azscooby
Member#: 115297
2002 ej207 vf34
Kaj,
You won't find anyone here who's disappointed with this engine.
Yes the avcs does help quite a bit in the low to mid-range. I can always tell when its not working (before it reaches 180)
Read this thread from start to finish, all of your questions will be answered, any lingering questions feel free to ask.
The swap is a no brainer for any 02-05 wrx, it can actually be cheaper than most other options. Mine ended up costing me about $1500 after I sold most of my old engine parts (my ej205 was still in good working condition.)
Get the whole front clip if you can swing it, it will end up being cheaper if you plan to upgrade the tranny and brakes down the road.
I wish I would have bought it all at once, it would have saved me a couple thousand.
azscooby is offline   Reply With Quote
Old 05-04-2012, 03:36 PM   #3348
kaj
Member#: 290109
2005 WRX
Originally Posted by azscooby View Post
Kaj,
Excellent, brother. Thanks!
Old 05-05-2012, 01:35 PM   #3349
chucha
Member#: 306870
2003 WRX STI 2.0
Advise me how to put a turbine on 2.2 Stroker 207 EJ ?
Between VF 43 and VF 48 a big difference?
chucha is offline   Reply With Quote
Old 05-07-2012, 10:31 AM   #3350
Zaider
Member#: 154281
MBP
After doing my turbo swap yesterday to a Dom 1.5XTR, I'll confirm that the V7 EJ207 has that oil filter in the Oil Feed Banjo bolt at the back of the block. It looked perfectly clean to me but with the size of that mesh, its easy to see how it would get clogged.
Why would you waste an engine like that with those turbos?
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
