Old 01-27-2009, 06:36 PM   #326
Special
Member#: 145585
2002 S202 [email protected]
Yellow
Originally Posted by 561wrx View Post
first question how long dose it take to put in ej207.
the next thing is how is the wiring.
and what tunning program u all r using for ecu.
I don't know what tuning program you would use, but I have a JDM version 7 ECU for sale if anyone is interested.
Special is offline   Reply With Quote
Old 01-27-2009, 06:47 PM   #327
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Originally Posted by subydude View Post
Ver7 RA-C has bigger port heads and better cams than the early V7 207 (although it's the same heads as the regular Ver 8 207). The RA-C also came with a silicon inlet, vf34 turbo, and different ecu. There was another version of the RA-C called the limited that had aircon and the regular intake/vf30, but still had the trick ECU and nicer heads.
Both versions can rev to 8,500, but I'm guessing that the RA-C would be better off due to the better heads.
Fixed.
And Subaru marks the redline at 8000rpms on Ej207's. Fuel cut is ~8250, and people round up to 8500. Thats why some times you hear about EJ207's revving higher than 8krpms.
eastcoastbumps is offline   Reply With Quote
Old 01-27-2009, 06:52 PM   #328
561wrx
Member#: 166427
03 wrx
do u know were i can get a long block or short block. maybe a block and if u can get a block can i use the stock heads
561wrx is offline   Reply With Quote
Old 01-27-2009, 06:57 PM   #329
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
No wiring necessary if you're replacing an EJ205, unless you want AVCS to work. IAperformance used to sell a wiring kit. I haven't heard from them in a long time, but I'd check there first. For AVCS, you will also need a V7 or V8 ECU, or a standalone like a Link, Autronic, Hydra*, AEM*, ViPec or Simtek to also get the AVCS working (All make a PnP EJ205/7 ECU). Otherwise you can use your regular WRX ECU flashed to run the larger injectors. Rev. 6b UTEC will also work on top of a WRX or V7/8 ECU. Earlier revisions don't.
*I'm not 100% positive they have AVCS mapping, but I'm pretty sure.
Old 01-27-2009, 07:01 PM   #330
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
illmatic is offline   Reply With Quote
Old 01-27-2009, 10:42 PM   #331
561wrx
Member#: 166427
03 wrx
so were can i get a motor for a good price.
Old 01-27-2009, 10:49 PM   #332
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Less than ten posts up
#323.
Or Ebay (where I got mine, but I was lucky), or private FS ads, or a few other vendors. I think you should read about the swap a bit more before buying it. There is LOTS of info in the subaru conversions forum. It will give you a good idea of what all is involved.
subydude is online now   Reply With Quote
Old 01-27-2009, 10:58 PM   #333
subydude
Member#: 80649
Originally Posted by eastcoastbumps View Post
Fixed.
Actually, as far as I've ever seen ALL regular Ver 7 STi engines had the same heads/cams. It was only the higher line cars that had the different heads. I've read the parts list for these cars and, unless my memory is already failing (which is happening more and more often), there was one part # for the regular Ver 7 cams, and another part # for the Spec-C.
The 8k redline is correct, as is fuel cut (what I consider to be the true redline since that's where forward momentum actually stops), but a lot of people will change where the fuel cut is to 8,500 when they get tuned. So it's not really rounding up, people just do it
Old 02-06-2009, 04:38 PM   #334
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
I have a few questions about swapping in a v7/v8 into my 2004 wrx.
1. I read I was able to use my stock wiring harness with the v7 setup? Is this true with a v8 setup as well? Will my 04 wrx harness plug into the jdm ecu?
2. Additional wiring for the v7/v8 setup consists of the avcs harness, I read I am able to buy this from a vendor ready to plug and play, anyone used this?
3. How is the reliability with these two setups?
007WRX is offline   Reply With Quote
Old 02-07-2009, 04:01 PM   #335
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Anyone?
Old 02-07-2009, 04:09 PM   #336
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
02-03 WRX front bulk head harness has 5 plugs for the ECU
04+ WRX front bulk head harness has 4 plugs for the ECU
you won't be able to use your 04 WRX harness for a Version 7 ECU but you will be able to use it for a Version 8.
when I did my swap I used this so that my AVCS system will work: http://www.iaperformance.com/product...oducts_id=2580
I think you need to do a lot more searching and research before doing anything since your questions states you know nothing about what you're getting into.
iNfEk is offline   Reply With Quote
Old 02-07-2009, 04:44 PM   #337
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Thanks for your help.
I just wasn't sure about the harness working for the v8. Thanks for the link, thats what I was looking for.
Old 02-08-2009, 10:07 AM   #338
ottawarex
Member#: 111248
2004 WRX
I have a 2004 WRX with a V9 swap. The harness works with V8-V9. It also works with V7.
Very reliable, unless its damaged when you get it (like mine).
ottawarex is offline   Reply With Quote
Old 02-08-2009, 02:30 PM   #339
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
So I have two conflicting answers now, it can and it can't.
Did you purchase yours from andre and the crew?
Old 02-08-2009, 02:52 PM   #340
ottawarex
Member#: 111248
2004 WRX
100% positive V7 to V9 (V9 Spec-C) will be a direct plug-in (with some mods for AVCS, neutral position...)
Got mine from JDM-Place in Toronto, terrible to deal with for warranty (ie, no warranty). Andre @ SwapShop is fantastic to deal with. He will confirm that the swap WILL work.
Old 02-08-2009, 08:43 PM   #341
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Thanks for confirming that.
Old 02-08-2009, 08:43 PM   #342
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Looks like you aren't too sure either
Old 02-15-2009, 12:06 PM   #343
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
does v7 and v8 have the same harnes? or are the motor plugs the same?
i'm asking because if i get v7 clip can i pull the engine only and replace with v8 and not mess with harness?
or could i get twin scroll set up from v8 with ecu and replace it on v7?
slava from goshen is offline   Reply With Quote
Old 02-15-2009, 12:23 PM   #344
slava from goshen
Member#: 152176
BRP/SRP
can someone help me out please.
i want to know as much as possible about this motor, i'm thinking of buying it.
thanks
Old 02-15-2009, 02:48 PM   #345
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
it's an early model regular V7
could be a very tired motor considering how old it is...
Hyper is online now   Reply With Quote
Old 02-15-2009, 04:07 PM   #346
slava from goshen
Member#: 152176
BRP/SRP
из интереса сколко стоит v7-9 sti/wrx двигатель в Москве?
Я скучаю за Москвой
Old 02-15-2009, 04:16 PM   #347
slava from goshen
Member#: 152176
BRP/SRP
does it not have dccd?
Old 02-16-2009, 02:24 AM   #348
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
по моему коробка без дссд
в Москве по разному... проблема найти живой двигатель
Old 02-16-2009, 07:29 PM   #349
Blackaxela
Member#: 145673
2002 Impreza WRX
subscribed
Blackaxela is offline   Reply With Quote
Old 02-22-2009, 01:09 PM   #350
slava from goshen
Member#: 152176
BRP/SRP
well i was going to buy this myself but I got a different set up.
I have pics in my email of the dash if anyone is interested and cluster is additional $300
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
its $4800 obo plus $950 freight to a nearest port.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
