Old 09-14-2012, 07:28 AM   #4126
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Originally Posted by 561wrx View Post
Hi. I asked this question before about the hubs, but Im trying to understand if I use 5x100 stubs which are on the five speed I don't have to change hubs. But if I keep the stubs that on the six speed I would have to change the hubs? An what size are the stubs on the six speed, or the stubs the same size on the 5 and 6 speed.
You're best off asking this question in the transmission forum. I saw an answer that although the stubs are similar, the one from the WRX, in order to be removed requires the casing to be split, while in the Sti, this does not happen.
Old 09-14-2012, 08:01 AM   #4127
25rsti
Member#: 166324
Correct, I was able to remove my jdm sti stubs out by removing the dials without having to take apart the trans.
Old 09-14-2012, 08:53 AM   #4128
i2cou4u2
Member#: 246455
2004 WRX Wagon
But if you have an early 2004 WRX or a 02-03 WRX and want to use your stock front axles, the STi stubs work perfect and do not need to be removed.
Tom
i2cou4u2 is offline   Reply With Quote
Old 09-14-2012, 12:30 PM   #4129
boombie391
Member#: 201496
02 Wrx wagon
I have a quick question, I just installed a v8 207 and my tuner won't be available for about 2 months. I know that i shouldn't run U.S. gas(93 in my area) but there is a gas station near me that has 100 octane unleaded. will i be safe to run this till my tuner is available? also i stay out of boost at all cost since this is my daily driver.
boombie391 is offline   Reply With Quote
Old 09-14-2012, 12:39 PM   #4130
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
What mods are on the car: intake, exhaust, boost control?
Which ECU is running this? V8 JDM?
Old 09-14-2012, 12:52 PM   #4131
boombie391
Member#: 201496
02 Wrx wagon
aem intake, 3" inch exhaust, fmic, greddy boost controller, stock v8 ecu.
Old 09-14-2012, 12:55 PM   #4132
Clark Turner
Member#: 178047
02 WRX STI Spec C
Not with the aem intake and fmic. The calibration will be way off.
C
Clark Turner is offline   Reply With Quote
Old 09-14-2012, 01:00 PM   #4133
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
If 100 octane doesn't break the bank on fill ups..enjoy!
you'd be fine with 93 for a few months but stay out of boost or better yet, just run wastegate boost till you get a hold of your tuner.
edit: missed the intake and fmic..Clark beat me
fastnoypi is offline   Reply With Quote
Old 09-14-2012, 01:07 PM   #4134
boombie391
Member#: 201496
02 Wrx wagon
Well that sucks guess I will need to find a new tuner. so don't drive it till i get tuned?
Last edited by boombie391; 09-14-2012 at 01:11 PM. Reason: adding another question
Old 09-14-2012, 01:16 PM   #4135
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
basically. put a line from the compressor nipple to the wg actuator nipple to run for now. maybe put a few gallons of 100 in with 93 every fill up. 2 gallons puts you at 94.3 octance approx so 3 gallons would work good for a 13 gal fill up. stay off the throttle and closed loop fueling trims will take over and add fuel as needed. avoid forcing the car to drive in a gear while cruising up a hill and downshift instead. get an innovate lc-1 wideband installed so you can verify afr's. 14.7 afr is good for cruising.
WhiteBgeye02 is offline   Reply With Quote
Old 09-14-2012, 01:18 PM   #4136
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
ordered the TCKWP328RB kit for my version 7. should be fun times I think I still might have a oem water pump gasket... I usually order more than one everytime I order gaskets and such. thermostat and seal will be ordered as well. can't wait for all this maintenance stuff to be done
iNfEk is offline   Reply With Quote
Old 09-14-2012, 01:38 PM   #4137
boombie391
Member#: 201496
02 Wrx wagon
thanks guys for all the info.
Old 09-14-2012, 02:27 PM   #4138
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Edit: IPhone created weird double post.
Old 09-14-2012, 03:17 PM   #4139
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
What are you guys using to hold the gasket onto the valve cover? I've read on iwsti that we need a certain fujibond?
Old 09-14-2012, 04:36 PM   #4140
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
I used a dab of assembly lube to keep the gasket in the grooves to temporarily hold the gasket untill i tightened down all the 10mm bolts. i didnt notice any fujibond being used from the factory when i removed the original gaskets.
Old 09-14-2012, 05:40 PM   #4141
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Isn't assembly lube oil based? Oil never evaporates and can cause premature failure?
Old 09-14-2012, 06:04 PM   #4142
azscooby
Member#: 115297
2002 ej207 vf34
At least on the usdm wrx/sti's the factory service manual specifies fujibond in at least two (maybe three, can't remember) locations. Though I as well dis not notice any of it from the factory.
I used HondaBond that I bought on Amazon, though I've heard the Permatex "Ultra Gray" is close to the same formula.
azscooby is offline   Reply With Quote
Old 09-15-2012, 12:16 AM   #4143
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
yes it is, i figured its safe since it is holding back oil anyways. No leaks yet after 6k+ miles.
IIRC the use of fujibond was just sparingly around the cam caps, you might be right but i don't remember the FSM at the moment. Spreading it on the flat side of the gasket "should" be fine but i opted not to for the reason of not seeing any from the factory.
Old 09-16-2012, 01:05 PM   #4144
uberspeed
Member#: 87871
I need a new RH AVCS Cam Sprocket for my V7 EJ207. Where can I purchase one of these? They are different than the USDM AVCS Cam Sprockets.
uberspeed is offline   Reply With Quote
Old 09-16-2012, 04:31 PM   #4145
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Motor is going in tomorrow. Samco inlet, Gates Timing belt kit is in... will be installing a new Exedy OEM clutch kit. Managed to get a JDM length midpipe... so no hacking of the exhaust will be necessary. Planning to replace the vacuum lines, turbo studs/bolts, gaskets etc.
Is pulling the fuel pump relay before the first start, and cranking the engine a few times, good way to lubricate the internals, or if I do a compression test... it'll do the same thing? Any other last minute advice from you guys, to make the reinstall easier? TIA!
Torquey is offline   Reply With Quote
Old 09-16-2012, 05:11 PM   #4146
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
I pulled the ign fuse and cranked the motor a few times before I started it up for real. It started up right away with no hesitation. I think it's a good idea to do that for turbo or motor swaps to get the oil system primed
K1WRC is offline   Reply With Quote
Old 09-16-2012, 06:12 PM   #4147
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Yeah I just want 'something' to hold the gasket in place a little but more than a recessed area you know? I'm not trying to use it for additional seal.
Old 09-16-2012, 06:31 PM   #4148
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
idk if this is dumb but wouldnt something a bit thicker than water like dawn dish soap work?
Old 09-16-2012, 06:45 PM   #4149
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
No. Think about your question before I respond
fujibond is similar to RTV and is a sealant.
Old 09-16-2012, 10:00 PM   #4150
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
My ver 8 is going in tuesday, planing on using the stock downpipe, stock ecu, stock airbox, stock turbo inlet but will be using an aftermarket 3" catback. Will be using 93 octane fuel, will I need the ecu remaped or will it be safe to daily drive ? would using a stock usdm wrx catback be a safer way to go ? Thanks.
Doug
D-Rodman is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
