Old 09-18-2012, 12:33 PM   #4176
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Here is my oil cooler sandwich, the biggest problem I'm having is finding any hardware I can thread into it. I believe its a m10x1.0 size, just ordered some set screws to plug the holes with while I can come up with a better solution.
Also, the jdm downpipe I got is shorter than my usdm, I was under the impression that it was going to be longer.
What do you say Vlad ?
Thanks.
D-Rodman is offline   Reply With Quote
Old 09-18-2012, 12:35 PM   #4177
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Thanks.
Get a thread and pitch gauge or take it to a hardware store and they should be able to measure it and tell you what size you need.
iNfEk is offline   Reply With Quote
Old 09-18-2012, 02:09 PM   #4178
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
Does anyone know somewhere/someone who is selling a camshaft sensor??? i've been looking for one for quite some time now.
thanks,
dolosolow is offline   Reply With Quote
Old 09-18-2012, 02:24 PM   #4179
D-Rodman
Member#: 110078
05 saabaru artc gr
I saw some sensors on ebay
Old 09-18-2012, 02:31 PM   #4180
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yes, jdm downpipes are all shorter until later v9 years i believe. you will have to make something to mate the two for the time being.
WhiteBgeye02 is offline   Reply With Quote
Old 09-18-2012, 03:34 PM   #4181
25rsti
Member#: 166324
Did anyone else have this plug with their jdm motors??
Old 09-18-2012, 03:41 PM   #4182
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
I didn't for sure.
Old 09-18-2012, 03:45 PM   #4183
25rsti
Member#: 166324
I wonder if its a v8+ thing or v9+ thing....
Old 09-18-2012, 04:56 PM   #4184
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
import sandwich plates usually have 1/8 PT holes
fastnoypi is offline   Reply With Quote
Old 09-18-2012, 05:14 PM   #4185
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
thanks,
I have a set from my 14.5k mile Spec-C motor.
Old 09-18-2012, 06:08 PM   #4186
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i had that plug. i ground it to a new wire off the passenger side.
Old 09-18-2012, 06:30 PM   #4187
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
I don't believe you is your wagon done yet?
Old 09-18-2012, 06:49 PM   #4188
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The sandwhich adapter is aftermarket, and you could just run the OEM cooler below it, without the sandwhich.
They either just run the cooler or only the radiator, not both from the factory, it is not necessary.
Also, you have the twinscroll headers in the way over there, they are bigger than the single scroll ones.
Old 09-18-2012, 07:20 PM   #4189
D-Rodman
Member#: 110078
05 saabaru artc gr
Yeh, thanks Vlad, I was thinking of doing that but I have to change the bolt the sandwich bolt threads into because it is way too long. I'm going to try using the usdm bolt off my stock engine, I think it'll work. We are just about done, just got to finish the oil filter deal, extend my intermediate pipe and wire the avcs. Thanks again.
Doug
Old 09-18-2012, 08:36 PM   #4190
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Any tips on getting the wires in/ out of the ECU connector for AVCS... i'm trying to use sewing needle, but no luck at all. Plus the five wires that I am suppose to add from the new harness, don't want to go in either. The wires in the engine bay was much easier! I hope i don't have to splice these up
Torquey is offline   Reply With Quote
Old 09-18-2012, 09:34 PM   #4191
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
You'll need to follow the directions. It's been a while since I did mine. Post a pic. I think you lift the black area on the plug
Old 09-18-2012, 11:10 PM   #4192
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
There is a .zip file posted on page 3 of the thread linked below that has some helpful videos. The Evo 8 ones are very similar. I just did these 2 weeks ago and the first one took forever, but once figured out the rest were easy.
http://forums.evolutionm.net/ecuflas...how-tos-3.html
OppositeLock is offline   Reply With Quote
Old 09-19-2012, 12:40 AM   #4193
JDM_Thompson914
Member#: 307835
Hey guys I plan on going with a bigger turbo, I have one already but would rather keep things quiet until its all done. Who should I talk to about running certain set ups?
JDM_Thompson914 is offline   Reply With Quote
Old 09-19-2012, 12:41 AM   #4194
JDM_Thompson914
Member#: 307835
V8 ej207 6spd vf37..
Old 09-19-2012, 12:46 AM   #4195
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
You shouldn't have to take any out of the wires going into the ECU connectors, just putting the extra ones in. Just make sure you pull the little locking mechanism up and they should pop on in, maybe use a needlenose plier and be careful and push them in till they click.
K1WRC is offline   Reply With Quote
Old 09-19-2012, 10:41 AM   #4196
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Before someone says search and read..define your goals (HP/TQ levels) and style of driving you want to maintain or do.
Are you asking what your mystery turbo will do under certain setups? Or justifying your purchase before setting everything up?
Old 09-19-2012, 10:57 AM   #4197
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
there might be some useful info here from the subaru harness repair kit
http://techinfo.subaru.com/proxy/607...4760668812.pdf
Old 09-19-2012, 01:07 PM   #4198
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
this is some awesome info
Old 09-19-2012, 01:33 PM   #4199
JDM_Thompson914
Member#: 307835
I already have an idea of what I'm doing, just wondering if there's any better/more efficient way of doing it with the set up I'm running now. Aiming for 450-480whp, 430+wtq. I do know what's going on in my bay before people jump on me but I want to talk to someone who has seen things happen that can actually give me a really helpful tip on my future, spring time, configuration.
Old 09-19-2012, 01:34 PM   #4200
D-Rodman
Member#: 110078
05 saabaru artc gr
Just about done, engine sitting looking at home.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
