Old 09-25-2012, 07:27 AM   #4251
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
So they're thinking 18 PSI actuator vs 14PSI?
The wastegate door with the Twinscroll is larger.
Old 09-25-2012, 10:04 AM   #4252
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i just put a spring i had around the end arm and to the body of the turbo. holds an extra few psi and spool increased by 150rpms. bit ch was leaking on me!
WhiteBgeye02 is offline   Reply With Quote
Old 09-25-2012, 08:31 PM   #4253
N-Bomb
Member#: 309465
1999 GC + ver 9 swap
Silverish
Finally got my dyno charts. This is for my ver 9 into GC swap. Any comments/issues?
All stock except for a Perrin inlet pipe, maybe upgraded intercooler y hoses, GC splitter/duct for the smaller GC intercooler (although mine has the bigger STi one. Fabbing a proper one at the moment). Tuned for 91 octane.
HP / Boost (blue is pre-tune, red is post. Dotted line is boost, solid is HP)
HP / Torque (blue is pre-tune, red is post. Dotted line is torque, solid is HP)
N-Bomb is offline   Reply With Quote
Old 09-25-2012, 08:41 PM   #4254
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
Does anyone happen to have engine harness diagrams for a v5/6 ej207 around? I've been looking for days with no luck. I need the TPS and IACV pinouts, specifically.
onesicksoob is offline   Reply With Quote
Old 09-26-2012, 12:40 AM   #4255
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Finally figured out how to use ecuflash to turn off the tgv related check engine light on my usdm ecu. No more check engine light, I can go get my inspection sticker and start learning how to log. First thing I want to do is make sure the avcs is working properly. Would the check engine light go on if the avcs is not working ? I have the wire harness connected with the jdm ecu but I had a friend do the installation and I'm wondering if it's done the right way. Didn't trust myself with the wiring but it'll be me fixing it if it ain't right.
D-Rodman is offline   Reply With Quote
Old 09-26-2012, 06:42 AM   #4256
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
You should go back and do couple things to the USDM ECU at minimum, to make it safe fo your car with the new engine.
Look at the injector scaling, take the same number that is in the tuned ROM for the JDM and use it in the ROM for the USDM.
Do the same with the MAF scaling.
You have to try to bring closer the boost control tables in the USDM to the tuned tables of the JDM. If you want to skip this part, then drive your car off boost as you use the USDM ECU, it's a chance you can take.
Old 09-26-2012, 08:39 AM   #4257
D-Rodman
Member#: 110078
05 saabaru artc gr
I'm driving it on the Jdm ecu, will swap the ecu to the usdm when I get to the shop where I'm having the inspection done. Thanks for the suggestion, something ill do after I have the tune done on the Jdm ecu.
Old 09-26-2012, 09:26 AM   #4258
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Not necessarily, the only situation i've run into where there was a CEL that was avcs related was when i threw a camshaft position sensor code that eventually cleared itself out due to weather.
There are a handful of other situations which will cause AVCS not to work which do not throw a CEL.
fastnoypi is offline   Reply With Quote
Old 09-26-2012, 11:19 AM   #4259
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Have you ever seen P1306 OCV Solenoid Valve Signal 1 Circuit Malfunction (Open). If I reset the ECU, it comes back after 5 minutes of driving... sounds AVCS related (which is still not active yet ). Wondering where to start looking. I've read about people unplugging/ checking the solenoid connections... where exactly are the physically located? TIA
Good news is I replaced my 130k old front O2 sensor with brand new Denso one yesterday, and that cleared the P0031 CEL.
Torquey is offline   Reply With Quote
Old 09-26-2012, 11:35 AM   #4260
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
I was getting that code before I hooked up avcs (for both sides)
Impreza WR Rex is offline   Reply With Quote
Old 09-26-2012, 12:22 PM   #4261
pgrily
Member#: 333354
Having issues with stuttering/hesitation under wot in 4k+ rpm in 3rd gear (well, 4th and 5th too--doing pulls in 3rd gear). Currently keeping me from finishing my tune properly.
Running a v8 ej207 swap in a gc8. Harness merged by iwire.
Fuel filter was replaced in the past 2-3k miles or so.
Spark plugs replaced (bkr7eix) in the past couple months, so 1k miles tops
New MAF sensor
DW 850cc injectors
GrimmSpeed ebcs
Only other mod is aftermarket cat back exhaust (at work, can't recall the name)
Tuning with Romraider
Trying to tune it to e85 (just installed the GS ebcs last night), but it also stuttered some with a 93 octane tune and the stock injectors. No check engine light. Last night it was stuttering pretty bad all through 4-5k before I cut it and called it a night.
I'm thinking a bad coil pack maybe? Do these sound like the symptoms of a bad coil pack? Any other suggestions? Trying to make a list of things to check when I get home.
pgrily is offline   Reply With Quote
Old 09-26-2012, 12:46 PM   #4262
WRick
Member#: 86107
New MAF sensor
DW 850cc injectors
GrimmSpeed ebcs
got a log we can take a look at ?
WRick is offline   Reply With Quote
Old 09-26-2012, 01:04 PM   #4263
pgrily
Member#: 333354
I don't have one of the most recent logs. This one is from a 93 octane tune before I switched injectors, but it should work since it still had some hesitation issues. The pull starts at around time = 4500 or so and ends at about 11300.
Let me know if this link doesn't work:
https://docs.google.com/spreadsheet/...mTTJGZ0E#gid=0
Old 09-26-2012, 01:06 PM   #4264
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Originally Posted by Torquey View Post
Have you ever seen P1306 OCV Solenoid Valve Signal 1 Circuit Malfunction (Open). .
Not related to AVCS that i'm aware of. Impreza WR Rex seems to confirm.
the one I had was P0365 Camshaft Position Sensor "B" Circuit (Bank 1).
I'm sure any related CEL codes for sensor A or B circuits would disable AVCS.
Old 09-26-2012, 01:26 PM   #4265
WRick
Member#: 86107
alot of a/f learning...
is your maf scaled correctly ?
I'm no pro, but I see alot of timing up there, but it aint knocking. hmm. no wideband ?
edit
MAP went down 5 psi while at WOT, I guess that would be your hesitation. Misfire ? What's the gap on your plugs ? I'd pull one or two out to see.
Old 09-26-2012, 01:32 PM   #4266
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well if you had stock injectors on the usdm ecu then its set for 440cc. your jdm engine has 565cc so if your out of boost and using the same maf scaling or stock scaling it should be rich but a wideband will tell the story for you.
Old 09-26-2012, 01:34 PM   #4267
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
OVER HEAD CAM VALVE SOLENOID runs the avcs so it woudl cause the one to be open which means no oil to the cams i believe to adv the avcs. atleast on that side.
Old 09-26-2012, 01:43 PM   #4268
pgrily
Member#: 333354
edit
I'm not the tuner (my brother does the tuning), so my knowledge is a bit limited. The log is a bit old, but the only one available to me at the moment since they're the only ones uploaded. I'm not familiar with maf scaling, myself, but the MAF is brand new and I'm running a stock air box. This log may be a bit irrelevant at this point due to its age :/
I am using a wideband right now, this log may have been back when I wasn't using it.
Plugs are NGK bkr7eix iridium, so I haven't gapped them at all since the manufacturer says not to.
Old 09-26-2012, 02:11 PM   #4269
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well these engines like .026" gap is it? not sure what the equiv millimeter width is but a few guys get spark blow out in the upper rpms range which causes misfires and such problems.
Old 09-26-2012, 02:47 PM   #4270
navydub
Member#: 242585
2005 Saabaru
Finishing up what I hope are the last odds and ends on my swap.
What upper heater core hose are you all using(those of you who are swapped into an 02-07 wrx). The stock wrx hose most definitely doesn't fit so, just made something custom or what?
navydub is offline   Reply With Quote
Old 09-26-2012, 02:58 PM   #4271
25rsti
Member#: 166324
I just bought one @ Autozone.
Old 09-26-2012, 03:16 PM   #4272
25rsti
Member#: 166324
I hope this is not a stupid Q. Does anyone know/or have experience with RomRaider and Windows7 or newer OS'??
I was going to use my old laptop with Vista, downloaded everything needed got it up and running but as soon as I unplug my laptop from the outlet it dies (will not work on the road)
Old 09-26-2012, 03:32 PM   #4273
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
A car charger for the laptop would probably be cheaper than a new laptop. Unless you already have one...
Just sayin...
Romraider seems to open up and work fine on my home PC with Win7 64bit, but my car pc that does the flashing is xp so I can't comment on that side of things.
simon021 is offline   Reply With Quote
Old 09-26-2012, 03:36 PM   #4274
navydub
Member#: 242585
2005 Saabaru
Yeah but what I'm getting at is, the EJ205 hose obviously doesn't work and autozone isn't going to stock EJ207 parts. Does the EJ257 hose work? If so, done deal I'll just run down to NAPA or Autozone later this evening.
Any other gotchas like this I'm about to run into as I finish final assembly
Old 09-26-2012, 03:57 PM   #4275
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
Just got back from my tuning session post wastegate arm change. Gained 75 ft lbs of boost down low and hit just over 400 hp. More potential up top but my intake MAP and fuel pump voltage reg are all maxed out.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
