Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-26-2012, 05:14 PM   #4276
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Originally Posted by WhiteBgeye02
well these engines like .026" gap is it? not sure what the equiv millimeter width is but a few guys get spark blow out in the upper rpms range which causes misfires and such problems.
Yes 0.26. It sounds similar to the issue I had. Ended up being spark blowout caused by a bad coil. I would try new coils.
mrxr250rider is offline   Reply With Quote
Old 09-26-2012, 05:14 PM   #4277
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Originally Posted by Impreza WR Rex
Just got back from my tuning session post wastegate arm change. Gained 75 ft lbs of boost down low and hit just over 400 hp. More potential up top but my intake MAP and fuel pump voltage reg are all maxed out.
Turbo?
Old 09-26-2012, 05:20 PM   #4278
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Originally Posted by WhiteBgeye02 View Post
OVER HEAD CAM VALVE SOLENOID runs the avcs so it woudl cause the one to be open which means no oil to the cams i believe to adv the avcs. atleast on that side.
Thanks man.. I rechecked the ones in the engine bay... will check the one on the ECU.
Here's a good article I found on the swap, especially people with wiring question:
http://www.importtuner.com/tech/0311it_sti_conversion/
Torquey is offline   Reply With Quote
Old 09-26-2012, 05:52 PM   #4279
pgrily
Member#: 333354
Yep, gonna pull a known working coil pack from another wrx and start the guess/check process. I may as well take a look at the plugs--should I bother with gapping the iridium plugs?
pgrily is offline   Reply With Quote
Old 09-26-2012, 06:02 PM   #4280
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
Turbo?
I was referring to an earlier post...
http://forums.nasioc.com/forums/show...postcount=3983
I'll put up the new dyno chart once I get it from the shop.
Impreza WR Rex is offline   Reply With Quote
Old 09-26-2012, 06:02 PM   #4281
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Yes gap them to .026 that may be your issue if not then it may be a coil. If not its not ignition related
Old 09-26-2012, 06:09 PM   #4282
pgrily
Member#: 333354
Hopefully one of those two solutions will fix it. Otherwise I'm pretty well stumped.
Old 09-26-2012, 06:10 PM   #4283
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
Originally Posted by navydub View Post
Finishing up what I hope are the last odds and ends on my swap.
What upper heater core hose are you all using(those of you who are swapped into an 02-07 wrx). The stock wrx hose most definitely doesn't fit so, just made something custom or what?
I'm curious about this as well? Is the hose just too short or in which way does it not fit?
To the guy that said he got one at autozone, did you just take the old one in with you and have them give you a longer hose the same size?
simon021 is offline   Reply With Quote
Old 09-26-2012, 06:57 PM   #4284
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Originally Posted by Impreza WR Rex View Post
I was getting that code before I hooked up avcs (for both sides)
Finally AVCS SUCCESS!!
Retraced my wiring trying to find the cause of P1306... and sure enough, had pins 10 & 11 backwards on the ECU. After switching them back, resetting the ECU... took the car for a drive and not only is the CEL gone... car now has VVT on both sides!
Here's latest log I just pulled. You guys take a look and tell me what you think (not sure if I logged ALL necessary parameters). There were some "Knock correction advance" activity in lower RPMs... should I be concerned? Thanks again as always!
https://docs.google.com/open?id=0B4I...HppTTVrcm11QU0
Old 09-26-2012, 07:02 PM   #4285
25rsti
Member#: 166324
Yes. My shell didnt have any heater core hoses so I took the cut peice off the JDM motor and got that same size one.
Old 09-26-2012, 07:52 PM   #4286
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
Feedback and Fineline are the ones you want to be concerned with.
Old 09-26-2012, 08:20 PM   #4287
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Did the spool improve?
Old 09-26-2012, 09:07 PM   #4288
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
considerably!
Old 09-26-2012, 09:11 PM   #4289
JDM_Thompson914
Member#: 307835
Hey quick question. The lower radiator hose connects to a fitting with 2 smaller black hoses on them w/ clamps. What are those hoses called? Anybody have a diagram on it? V8 ej207
JDM_Thompson914 is offline   Reply With Quote
Old 09-26-2012, 09:21 PM   #4290
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
12.9@103MPH EJ205 4EAT
The water pump
iNfEk is offline   Reply With Quote
Old 09-26-2012, 09:47 PM   #4291
JDM_Thompson914
Member#: 307835
Yeah it's the elbow bend hose.. Best replacement? Get a look alike hose from autozone/home depot or are there any other brands out there for a better quality than this flimsy rubber?
Old 09-26-2012, 10:05 PM   #4292
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
I use this for diagrams:
http://opposedforces.com/parts/impreza/en_g11/type_23/
It's the RHD Europe 2.0L STi. Not sure what differences there are between this and the JDM, but I figured it's closer than the USDM...
Old 09-27-2012, 12:37 AM   #4293
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
What spark plugs are you guys getting?
Can't find an equivalency list for the pfr7g
D-Rodman is offline   Reply With Quote
Old 09-27-2012, 01:08 AM   #4294
pgrily
Member#: 333354
Well the coil packs solved my stuttering problem
I'm tuning for e85 and my boost seems somewhat low. Running a completely stock setup (vf37 ver 8 ej207) with 850 cc injectors and Grimmspeed ebcs
My boost is at 13 psi at 6400 rpm (where I cut off the pull). I'm reaching full boost (19 psi) around 3900 and then it tapers off around 5200 rpm. My boost doesn't seem to increase anymore in the higher rpms by increasing the wastegate. I guess there might be a leak, but I'd think I would have trouble building up to 19 psi if that were the case. Any ideas?
Old 09-27-2012, 02:00 AM   #4295
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
NGK Iridium BKR7EIX
Here's where I got mine from:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=150905765765
Old 09-27-2012, 02:33 AM   #4296
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Boost is going fall off upto...no way around that and you wouldnt want to if you could
Old 09-27-2012, 06:13 AM   #4297
D-Rodman
Member#: 110078
05 saabaru artc gr
well if you had stock injectors on the usdm ecu then its set for 440cc. your jdm engine has 565cc so if your out of boost and using the same maf scaling or stock scaling it should be rich but a wideband will tell the story for you.
That makes sense, in order to clear all the drivers in the computer for the inspection I was sent out to drive my car. I had no choice, drove the car 45 miles on the usdm ecu. Came back, everything cleared, got my inspection sticker, happy. Car ran fine keeping off boost under 60 mph. I then swapped to the Jdm ecu and drove home, 20 miles away from my friend's inspection shop. When I got home I noticed that the engine seemed to get really hot and sounded like it was knocking from just bleeping the throttle lightly, not happy. No such condition with the usdm ecu, engine seemed to work healthier. I have a long drive to EFI Logics, thinking of swapping the usdm ecu back on for that drive. At that point I'll have a walbro fuel pump, aftermarket catback and Perrin turbo inlet installed. Not feeling confident driving the car on the Jdm ecu from here on, specially once I install mods. I'm going to pull a rom and contact you, perhaps you could tweak a safe map for me. I don't have wide band yet so, no logging for now. Avcs wires you made me work well, thank you.
Doug
Old 09-27-2012, 06:19 AM   #4298
D-Rodman
Member#: 110078
05 saabaru artc gr
NGK Iridium BKR7EIX
Cool, ordered a set, are you gaping those plugs or are they properly gapped out of the box?
Thank you sir.
Doug
Old 09-27-2012, 08:44 AM   #4299
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
What I was trying to tell you and white too is that your car will run rich, with the USDM.
While in closed loop this is compensated to a degree. In open loop not really.
Then the MAF, air table was wrong too.
With this combo, the car could have run some high exhaust temperatures, it's almost impossible to predict. This is probably the heat you noticed.
I wanted to go into more details yesterday, but it's upto you to make the right decisions for your car, you have the info now...
I'll add this:
We know that rich running carburetor cars can get fuel into the oil. Well... I have personally experienced in my personal old Mercedes Bosch K Jetronic fuel injected, it dumping fuel into the oil, as I was trying to adjust the mechanical fuel distributor pump.
While this was a more extreme situation, small amounts of fuel could thin the oil.
This was before my current old diesel Mercedes.
Running very rich, cranking rich, etc, can have effects.
Old 09-27-2012, 10:27 AM   #4300
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
I was having issues with my knocklite detecting knock in upper rpm's . Pulled the plugs and they were gapped to around .030 so I installed new stock heat range ngk iridium plugs with the gap around .027 and no more knocklite flashes. I also cleaned my maf at the same time
666stars is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
