Old 10-15-2012, 04:12 PM   #4601
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Originally Posted by 25rsti
I still can't figure out why mine isn't starting, been almost 4 weeks now. Just won't crank.
That sucks man. Did you get a properly working starter yet?
todeswalzer is offline   Reply With Quote
Old 10-15-2012, 04:20 PM   #4602
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Originally Posted by tjdonovan View Post
if u want power and reliability they make a full blown race engine with a rev limit of 9500 to 10k for under 10k. Its a ej271 special built bored and stroked block from the ej257 with the heads right u can keep the stock boost level and see double the power and 100 times the dependability
What are you talking about? There is no EJ271. Stop posting non-sense.
EDIT: Are you talking a 2.71L block? That's not an EJ271 and you exaggerate it's benefits.
Originally Posted by WRick View Post
I just learned today that the pistons the shop put in my 207 are in fact 9:1 CR instead of the factory 8:1
That explains alot.
What are the implications ?
High compression motors can be super fun, but they require very high quality/octane fuel with high boost. My last motor was a 2.5L at around 8.9:1 or 9.0:1. It was a beast on e85, but ultimately it was a pretty sloppy motor due to a questionable builder. The off-boost power/torque will be fun and you'll see very nice spool characteristics. Just watch that knock.
Also, the 9.0:1 pistons they put in... is that what the manufacturer claims? Because many manufacturers like JE base their values on a theoretical head gasket thickness (like 1mm or something) which is usually considerably thicker than OEM. If they assume this, then their pistons when used with OEM thickness gaskets will result in even higher CR. Just some food for thought.
Old 10-15-2012, 04:36 PM   #4603
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
9-1 CR in a 207 would be tons of fun, just make sure your tuner knows what they are doing. since you have changed the position of the piston relative to the head you may have to limit avcs to prevent valves hitting your pistons and it will require a significant reduction in timing since baseline cylinder pressures are higher.
lukeskywrx is offline   Reply With Quote
Old 10-15-2012, 04:47 PM   #4604
WRick
Member#: 86107
yeah well tuner had no clue, as I had no idea either.
It's on the carberry rom, and was dyno tuned. The top end was spot on.
Everything else was ****.
So, I sought help and a friendly ( and very advanced I might add ) member @ romraider walked me through tuning it spot on.
I'Ve put around 50 flashes, and probably 50/60 hours into the tune. It's pretty spot on now, and everywhere for that matter ( thanks AndyA )
It takes ALOT of low end timing, and just LOVES IT. It spools the 18g in no time. we have 94 oct. here so it's all it gets. And up top, actually, less timing makes more HP in my case... ( we tried on the dyno )
WRick is offline   Reply With Quote
Old 10-15-2012, 06:58 PM   #4605
25rsti
Member#: 166324
I had my original v7 starter, bought a usdm sti starter here on the boards then bought a reman from advanced auto. None made a difference. I'm going ballistic.
Old 10-16-2012, 11:54 AM   #4606
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well then tis not the starter but some sort of other issue? i didnt see the original post but whats the problem 25rsti?
congrats on the fun tune Wrick!
WhiteBgeye02 is offline   Reply With Quote
Old 10-16-2012, 11:58 AM   #4607
WRick
Member#: 86107
I don't deserve the merit, Andya does.
I'm happy to say I did ( mostly ) my own tune and it's amazing.
Old 10-16-2012, 12:09 PM   #4608
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
you learn a lot about the car that way though. its one thing to have someone to tell you what to do but gong and doing it yourself is another task. so many finiky things with romraider sometimes makes it a pita to work with.
Old 10-16-2012, 12:13 PM   #4609
WRick
Member#: 86107
I've had quite some fun learning the ecuedit tool ( I have no choice, cannot flash with ecuflash )
The map tracing/log tracing tool is fabulous and helps ALOT to fine tune the fueling and timing. Love it !
Old 10-16-2012, 12:35 PM   #4610
kpluiten
Member#: 120273
06 WRBWRXWGN
Maybe I missed it, but does it click or something? Or does it just not do anything?
Two past experiences come to mind:
1) we installed a motor and one of the guys I was working with put the ground cable on the back of the starter and forgot the positive cable all together. That was a silly mistake, but we were stumped for a few minutes.
2) I installed a motor in a kids car and when it came time to fire it I told him to do so while I stood over the motor watching. Nothing. He tried and tried. We swapped the ECU back and tried a bunch of other stuff. Then I found it... he wasn't stepping on the clutch. He just plain forgot to. :facepalm: Car started right up immediately.
I know these are dumb, but sometimes it's the dumb ones that stump us the most, especially if you're very technical.
Old 10-16-2012, 12:58 PM   #4611
WRick
Member#: 86107
thats interesting
Can you log in romraider if your clutch switch is working ???
Old 10-16-2012, 01:01 PM   #4612
kpluiten
Member#: 120273
06 WRBWRXWGN
You could just put a multimeter on it and compare it with the FSM I think.
Old 10-16-2012, 01:54 PM   #4613
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yeah you can log clutch switch. like 99% sure you can.
Old 10-16-2012, 01:55 PM   #4614
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
how much better is ecuedit compared to ecuflash? i have a bunch of excel stuff i use to aid and just do some visual 3d mapping on excel if ecuflash doesnt offer one for what i want.
Old 10-16-2012, 02:00 PM   #4615
25rsti
Member#: 166324
I just got home from work and tried jumper cables from my truck battery to the battery in my car. Didn't do anything different.
My problem is: I get in the car, turn the key to ACC, hear the fuel pump prime. Try and crank the car...all that happens is: I hear a click (from a relay?) from behind or around the cluster area and the clock and radio dim off.
Old 10-16-2012, 03:48 PM   #4616
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
the click should be a starter relay. either the wire going to the starter for power is bad or the ground wire to the starter is bad to the body/engine. what happens when you take the starter off the car w/ the power going to it and a wire grounding it somehow? it should spin freely when you turn it over. that or try this. with the starter on the car have a friend sit inside and put the positive side of a volt meter on the red wire on teh starter and the black wire on the engine or ground wire ontop of the starter.when you turn it over you should see like 12 volts or so. if all your hearing is a click then the relay is good 99% of the time and something post relay between starter and relay is bad. seeing if voltage is getting there is a good start to see if the wire is bad or something. you obv bought a few starters and its unlikely all of them were bad.
also i noticed when my battery was low it would click then click a ton of times( like 5 times/second or so) if i held the key over but obv not turn the engine over.
Old 10-16-2012, 04:05 PM   #4617
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Nope, it does not go into the ECU. Otherwise flat foot shifting would not need an external input for the 16bit ecu
Old 10-16-2012, 04:30 PM   #4618
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
very true,, i guess i figured since you were grounding one side and then feeding the other side into the ecu it could be logged. but then again its going into the cruise control pin i beleive so totally different. my bad!
Old 10-16-2012, 04:49 PM   #4619
25rsti
Member#: 166324
What else post relay could be going wrong? I bypassed the starter a few times. It sounded like it was just spinning and the bendix wasn't plunging foward.
Old 10-16-2012, 06:17 PM   #4620
todeswalzer
Member#: 191495
'05 WRB GTX3071R
How's the flywheel? Maybe its not the starter
Old 10-16-2012, 06:23 PM   #4621
25rsti
Member#: 166324
But, if it was the flywheel wouldn't something at least happen prior to the flywheel? Though, the flywheel is good.
Old 10-16-2012, 06:28 PM   #4622
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Well if there was no flywheel it wouldn't start right? =p
Old 10-16-2012, 06:48 PM   #4623
25rsti
Member#: 166324
haha, correct. There is a flywheel in there, with a clutch too :-). It just doesn't start :-(
Old 10-16-2012, 06:58 PM   #4624
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
if you bypassed the wires with direct power to the starter and nothing happened then idk wtf is wrong. i mean literally ran a thick wire from the positive on the battery to the starter and it should start to spin. if it spins and then wont go forward then its the bendix being a pos. but still you need to hunt down if its before the starter and after the relay then tis the wire inbetween. check for good connections. the wire connects to the relay im pretty sure by a nut kinda like on the back of the starter. its really a basic function. you turn the key. the key sends a small voltage to the relay which creates a magnetic field in the coil inside and moves a metal contact into another. this is the loud click when they hit. then these two contacts let electrons from from the battery thru the relay contacts thru the wire to the starter. starter spins and bendix moves toward flywheel. gear contacts teeth on flywheel and turns engine over. if any of those parts has a missing link or loose connection it wont work period! beyond that your car has some bad black magic in it or something.
Old 10-16-2012, 07:00 PM   #4625
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
Got it all fired up and runs great but I cant get the avcs to work. I copied over the USDM gear determinations and it's detecting the proper gear with 1-5 and 6 in neutral. The "Neutral position switch" shows 1 in neutral and 0 in gear. I have it wired up per IA instructions.
I'm assuming I should see advance on the 2 intake advance parameters on romraider logger if it's working properly? I see like 2-3 randomly on one side and the other is always 0. I'm hoping I didnt miswire something. I was very careful to triple check each one before insertion.
The center plug was much harder to insert the first few times of plugging it in, but now it's no different than any of the other ecu plugs.
Any ideas?
simon021 is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
