Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 10-23-2012, 01:33 PM   #4701
PHruska
Member#: 214589
2002 wrx wagon
Originally Posted by todeswalzer View Post
The first engine I got had one in it. I no longer have it but.....Its definitely bigger than 1/8 npt
Try going to a local hardware store or even auto zone and get a brass 1/4" npt/hose barb fitting. They're like $2 and will give you piece of mind
Or try threading some 6mm/8mm bolts in
hmm yeah well i was hoping i would be able to just put the new pressure sender into the old sandwich.
PHruska is offline   Reply With Quote
Old 10-23-2012, 01:33 PM   #4702
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Originally Posted by PHruska View Post
So im looking at getting an oil press gauge and have the JDM sandwich adapter on there already. i searched and only had one person say they thought it was 1/8npt. can anyone verify so i dont have to wait on the correct one if it doesnt fit?
do you know which brand sandwich adapter?
Defi and Greddy are definitely 1/8 npt .
I would not thread any metric bolts in the sandwich adapter, you can damage the finer pipe threads and cause leaks with any sender you put in afterwards.
fastnoypi is offline   Reply With Quote
Old 10-23-2012, 01:43 PM   #4703
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Sorry, I meant hand thread them to see if they line up...being JDM who knows if it follows standard NPT
http://mdmetric.com/tech/metnptcomp.htm
todeswalzer is offline   Reply With Quote
Old 10-23-2012, 03:05 PM   #4704
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
I really need help on this one guys. I've tried everything, from checking my grounds to swapping sensors from one side to the other. Basically in short, I've had P0365 (camshaft position sensor bank 1) CEL code ever since I've got my swap. I bought a new camshaft sensor and the light stayed on. So I went ahead with a friends advice and swapped everything from one side to the other in hopes that the code will jump to the other side, being bank 2, nonetheless still stuck on bank 1.... I had someone hook up a computer to my car to see if the avcs were working, turns out they are. The only weird thing he noticed in the logs was how the left and right AVCS were operating, one gave out 6% while the other 68%.
Any idea on what can be causing this?? I'm really tired of looking at this CEL on, and what makes it worse I can't get a tune cause of this, actually maybe I can but it won't be a smart decision.
Thanks everyone.
dolosolow is offline   Reply With Quote
Old 10-23-2012, 04:17 PM   #4705
todeswalzer
Member#: 191495
'05 WRB GTX3071R
do you have a lightened pulley/flywheel? I have a crank sensor code right now and I've been reading....some say these 2 codes can be related to those mods.
Also did you check that your timing is correct?
Old 10-23-2012, 04:34 PM   #4706
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
my friend was getting that code simular on the ej255. when he put the cam sensor on it was slightly off and caused the sensor not to read the cam. maybe take the timing stuff off and verify its all correct. when you log avcs look at the angle opening not hte percentage. when its not working it stays at like 6% duty cycle i believe so that one is not working. the duty cycle referes to the oil that is fed into the cams and how often out of 100 times say the solenoid must be open to hit the target avcs value from the table.
WhiteBgeye02 is offline   Reply With Quote
Old 10-23-2012, 04:45 PM   #4707
OppositeLock
Member#: 54060
Now: v8 207/v6 5mt
Then: JRTune fastest td04
Thanks everyone.
I had a problem similar to this before I straightened out my AVCS wiring. Did you do the wiring on the car and how did you (or the person who did it) do it? What diagram did you follow and did you make your own harness or buy one? Also, where are you in NJ? If you are close I can look at it.
OppositeLock is offline   Reply With Quote
Old 10-23-2012, 04:50 PM   #4708
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
Go back and check the pins that you added along with the pins that you swapped in the harness.
Sometimes they do not seat 100%. And while your at double check your pin locations.
Also check to see if you still have the avcs filters or if you have a blocked filter.
JRsleeper is offline   Reply With Quote
Old 10-23-2012, 05:49 PM   #4709
PHruska
Member#: 214589
2002 wrx wagon
I thought it was stock on the Jdm engine. I'll look to see if there is a name on it.
I'm still throwing the p0365 too. Where are these filters you're talking about? On the solenoid itself?
Old 10-24-2012, 04:46 AM   #4710
stlnation
Member#: 321805
2002 Jdm v9 STI
Anyone have any experience with this product. i searched and didnt see any posts.
from their website:
Camcon Ex
Retails for $650. found one on ebay for a little cheaper but it seems to be an older model
Camcon Fi Ebay
looks to be a $250 steal of a AVCS and A/F controller. seems legit. thinking about getting it. wanted a couple opinions.
edit:
another link on their website for setting information (at bottom of page)
http://power-enterprise.co.jp/electronic/camconfi.html
stlnation is offline   Reply With Quote
Old 10-24-2012, 07:36 AM   #4711
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
Why even bother with that when you can tune your ecu with open source.
Old 10-24-2012, 01:13 PM   #4712
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
no ****! and there are plenty of good avcs maps around. you just have to hunt or have a tuner put one on for you!
Old 10-24-2012, 02:15 PM   #4713
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
get a 207 first , then worry about your avcs tuning later
Old 10-24-2012, 06:39 PM   #4714
Clark Turner
Member#: 178047
02 WRX STI Spec C
Dan, Its fun to post about 207s when you dont even have one.
C
Clark Turner is offline   Reply With Quote
Old 10-24-2012, 07:42 PM   #4715
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Really, where can I get a map for my 207? I have a catless 3" turbo back exhaust and a Perrin turbo inlet, stock otherwise, hook a brother up.
Thanks.
Doug
D-Rodman is offline   Reply With Quote
Old 10-24-2012, 09:17 PM   #4716
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
there is all the S car maps and higher version engine maps on romraider. did you still want me to mod your man D-rodman?
Old 10-24-2012, 11:45 PM   #4717
stlnation
Member#: 321805
2002 Jdm v9 STI
C
well that wasnt fun
Old 10-26-2012, 05:54 PM   #4718
pooky
Member#: 267372
2003 bugeye
SRP
Hello ladies and gents. I am currently thinking about picking up an EJ207 motor since I found a pretty sweet deal along with the v7 trans. How do I tell if they are legit? After researching all I can find is that it's supposed to have a red intake manifold(he could've just sprayed it) and certain turbos(He could've swapped it in no?) I would really appreciate the help thank you all.
pooky is offline   Reply With Quote
Old 10-26-2012, 05:58 PM   #4719
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
It seems like you really don't know much about these engines. Just research this thread some. There's 95 pages of great info and pics. Research some of the JDM vendors on this forum and you will find exactly what you need and it will answer just about 99.9% of your questions.
Old 10-26-2012, 06:08 PM   #4720
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Start with this thread http://forums.nasioc.com/forums/show...96&postcount=3
Then come back and read all of this thread. There are subtle external differences between the year offerings that you can give you an educated guess if the one you are looking at is legit.
Old 10-26-2012, 09:42 PM   #4721
Ryan2002WRX
Member#: 225439
If you are seriously in the market for one you NEED to read up on this thread. It will be extremely helpful for you. With the upmost respect based on your post you don't have the knowledge yet to effectively make the right choice. If you can't pick a JDM motor out of a pile of STI motors you must do your research. And again in absolutely no way am I trying to be a dick at all. I just want you to be fully educated so you don't wind up getting screwed. Read every page of this thread you won't regret it. Good luck in your search.
I still wish there was an inner thread search option There is tons of stuff in here I want to refer back to all the time and can never remember what pages things are on.
Ryan2002WRX is offline   Reply With Quote
Old 10-26-2012, 11:01 PM   #4722
pooky
Member#: 267372
2003 bugeye
SRP
No offense taken. I've been researching for the past few weeks. I know some of the differences(though compared to you it may be basic knowledge). So far I haven't found any way to tell them apart with the naked eye. The guy I am purchasing from has it installed already and with some bolt-ons.
Reason for wanting to upgrade is I have decided to go with a 20g-xt and would be much more comfortable that the ej207 is a stronger platform. Just a peace of mind that I won't run into any problems later on. Also since my stock motor/tranny only has 55k miles I can sell it off now for a decent price and recuperate the some of the costs.
This will be my first engine swap, but with the help of a buddy who has done many engine swaps(but for BMW). He will guide me through along with his other friend who is a Subie enthusiast. Thanks for the heads up though. All advice is appreciated(even if it isn't put in the kindest way )
Old 10-26-2012, 11:38 PM   #4723
silviaps13
Member#: 220403
2002 207 V7 WRX
Quick question for those who had their V7 tuned by Clark, the 16bit.xml logging file, is that supposed to be loaded as the logger definition in romraider, I've been trying but it hasn't worked for me.
Nevermind, Figured it out, the 16bit.xml file isn't a logger definition file, it it a logging profile. Just a bit of a communication error.
silviaps13 is offline   Reply With Quote
Old 10-26-2012, 11:48 PM   #4724
Ryan2002WRX
Member#: 225439
Well that's what I'm getting at is there are many many ways to tell with the naked eye. This is a whole different ball game than just a your standard engine swap. I am not insulting you in any way at all. Just don't want you to make any mistakes. All of your answers can be found here in this very thread. Being able to identify the motor is a great start. I am not going to rub it in your face or be a dick because unlike some others it is not my style. Because I remember where I come from and know that one day I was in your shoes. And day by day with research I am still learning more and more every single day.
Old 10-26-2012, 11:51 PM   #4725
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Pooky, I know this isn't a 100% fool proof way but check out the intake manifold. Does it have Tgv's or do the runners go all the way to the heads? How about the avcs solenoids, are they there? If the sticker is still there you can check that, its on the timing belt cover, left hand side when looking at it installed.
A few simple things to look for. I am with everyone else though, do lots of research before hand especially since you are buying third or fourth hand. I bought mine from a reputable company but only after doing a metric **** load of research.
Good luck.
ImNOrobo is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
