Old 11-18-2012, 07:53 PM   #4876
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well could always throw the wrx ecu in if you have to and close the codes down in the tune.
tell him to hit me up. i got a few extra avcs harness's i made to do the swap into a 02-05 wrx/saabaru
WhiteBgeye02 is offline   Reply With Quote
Old 11-18-2012, 08:13 PM   #4877
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
I'm in New York, only California has tougher emission testing, lol. I have a 2002 wrx with a 2003 ej207 swap, twin scroll turbo, Tomei catless down pipe runing on a jdm ecu. My car did pass inspection recently but had to install the usdm ecu for for the state inspection computer to be able to communicate with my car. The inspection computer would not communicate with the Jdm ecu. You will have to deactivate all the tgv related diagnostics on the usdm ecu in order to not have a check engine light. You will want to unplug the avcs when runing the car with the usdm ecu. Ideally you also want to tune the usdm ecu to work properly with the 565 injectors on the ej207. Once a year I'll have to install the usdm ecu in order to pass inspection.
Ecu work done with open source.
D-Rodman is offline   Reply With Quote
Old 11-19-2012, 12:09 AM   #4878
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
I'm about to be a new ej207 owner.
I was told that the only way to tune the JDM ECU is through ECUtek, is that correct?
Jubert69 is offline   Reply With Quote
Old 11-19-2012, 02:32 AM   #4879
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
False, you can open source tune it. If your lucky enough and have the extra cash lying around you can try and locate a JDM access port.
ImNOrobo is offline   Reply With Quote
Old 11-19-2012, 04:59 AM   #4880
dundunskeert
Member#: 184151
2000 STI RA Limited
If it's a V6 you can use an Apexi PFC. Also look into Hydra and Simtek.
dundunskeert is offline   Reply With Quote
Old 11-19-2012, 06:04 AM   #4881
D-Rodman
Member#: 110078
05 saabaru artc gr
Open source is your friend.
Old 11-19-2012, 11:57 AM   #4882
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Ok cool.
The one I will be getting, the ECU can only be connected by ECUtek for some reason.
Maybe I just need to buy another JDM ECU?
Old 11-19-2012, 02:17 PM   #4883
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Well I joined the club, or rather my wife did.
We picked up this car for her.
Its an 02 with a version 8 Spec C drivetrain swap. After driving it home a little over 1200 miles, I have a full appreciation for the 207 that you just can't get until you drive one. I just ordered bigger injectors and a fuel pump to get it on E85. Even 93 just doesn't cut it for this engine.
One issue I need to solve pretty quickly though is a leaky axle seal on the passenger side. I've been doing some research but I haven't been able to figure out the correct part number for the axle seals and the axle clips. I want to replace all of them this weekend while I'm putting on new shocks.
Thanks in advance.
Obligatory pic:
WRXt4cy is offline   Reply With Quote
Old 11-19-2012, 02:31 PM   #4884
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
hey, if you want a good tune on that car hit me up. I am in Wisconsin and have a v8 of my own. I do opensource tuning and am attempting to stretch my customer zone to something a bit larger than NE wisconsin.
if your front axle seals are leaking take the axle off the car by taking the nut off. popping the lower ball joint off and then pulling the axle out of the transmission. then put a mark on the circle cover with all the teeth and on the housing. take the locking key off that is held on by the oen bolt then spin the cover off counterclockwise. count the turns out just in case. pull the seal out. get one from the dealter and tap it back in palce with a socket. spin the cover back in to its original location. leaky problem solved!
as far as 93 octane the engine tunes great in my opinion. tuned my ej207 and a local guys ej207 and they make great power on 93. e85 you can turn the timing and boost up a bit with the stock turbo but a larger turbo would really help with the top end.
on a side note i got a few extra avcs harness's made up for sale if anyone needs one for there swap hit me up! lots of ppl on the forums can vouch for the harness's quality and function!
Old 11-19-2012, 02:33 PM   #4885
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
From what a couple tuners told me there is no Access Port for the EJ207......what makes you say there is one that will work?
Old 11-19-2012, 02:34 PM   #4886
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Ok cool.
good luck finding a decent price jdm ecu. they are becoming hard to find. most likely it was ecutek tuned and is now locked. get ahold of someone in your area that can tune ecutek because they can prob unlock it for a decent price so it should work for you.
Old 11-19-2012, 02:38 PM   #4887
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Thanks for the offer on the tuning but I've been doing it for a few years so I'm good there.
Everything I read about the replacement procedure matches what you are saying except I read that the sundial actually rotates out clockwise and back in CCW - is that not right? Where is the locking key you are talking about? I didn't read about that or see one on the tranny.
Also - do you know the part numbers for the new seals and clips? I can't seem to find them.
Thanks.
Old 11-19-2012, 02:44 PM   #4888
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Obligatory pic:
Nice Ver.7 Goldies Always wanted a set of those, just hard to find in good shape.
kayen is offline   Reply With Quote
Old 11-19-2012, 02:44 PM   #4889
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
no idea on part numbers.
here is a picture of what im talking about. i swear when i took them out of my 5mt they came out lefty loosy righty tighty lol. that gold colored thing is the key that holds it from turning.
okay glad you got it figured out. they love timing but make sure you log everything to make sure! you will be surprised how much they take compared to a ej205 or a ej257.
http://www.google.com/imgres?q=subar...w=1280&bih=694
Old 11-19-2012, 02:59 PM   #4890
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yeah, I really like them too. These were in pretty decent shape, only minor rashing on them.
http://media.beta.photobucket.com/us...g.html?filters[term]=subaru%206%20speed%20axle%20seal&filters[primary]=images
Yeah, they do like timing for sure. I've been working on an E85 tune on a v8 207 and I was so impressed that it gave me the extra kick in the ass to go ahead and get this car. I've got my 2011 STi on E85 and its a blast but I think the 207 on E85 in the lighter chassis might be able to give it a run for the money when its done. The power band on the 207 is just amazing.
I see the key you are talking about, I was wondering how the dial stayed in place. I must not have noticed it. The information I found was here:
http://forums.nasioc.com/forums/show....php?t=2399150
Its for an 04 STi tranny which I was thinking was similar to the JDM tranny but I'm just not sure if the seals/clips are the same or not. I guess I can just take it apart now and see what I have in there but I wanted the part numbers because: A. My local Subaru dealership is run by idiots and B. They more than likely don't stock the parts I need and will need to order so I want to order the right stuff.
Old 11-19-2012, 03:35 PM   #4891
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
check this thread for post for part numbers, you'll have to figure out if its from an early or late model 04 trans
http://forums.nasioc.com/forums/show...14&postcount=1
fastnoypi is offline   Reply With Quote
Old 11-19-2012, 03:43 PM   #4892
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
hit up subarugenuineparts guy on here. he runs a oem parts website and if you cant find it message him and he will link you to the page or part number on his website.
http://www.subarugenuineparts.com/
Old 11-19-2012, 03:54 PM   #4893
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Perfect! Thank you. That is what I needed. I have a late 04 type tranny it seems as I have male axles rather than stubs.
It sounds like the same circlips work for the stubs OR the male axles.
Since I have the part numbers now, I should be able to deal with my local dealership but if they can't help, I'll try this guy.
Thanks for your help guys. That's was quick.
Old 11-19-2012, 04:34 PM   #4894
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Whelp, ej205 decided to spin her bearings after >220,000miles.
Time for a swap.
Psychoreo is offline   Reply With Quote
Old 11-19-2012, 05:20 PM   #4895
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Time for a swap.
Glad you saw the "silver lining on the cloud"
... I swapped mine at 130k and was able to sell the old motor for $1500... about half of what I paid for the v8
Torquey is offline   Reply With Quote
Old 11-19-2012, 08:06 PM   #4896
Psychoreo
Member#: 79643
2015 WRX STI
That's what I'm hoping. I'm in a tough spot but I think I'll be alright. Jdmracingmotors is being nice and I think I'm getting a decent deal.
Although, the great question.
V7, V8, or V9?
(starts re-reading the thread)
Old 11-19-2012, 08:31 PM   #4897
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
V7, V8, or V9?
V8 if you don't have the ecu all ready. V9 if you do or don't mind sourcing one.
There are no differences in the hardware between the two really but with the v9 you get a "newer" motor.
Meaning better chance of lower miles, sat in a warehouse for a shorter time period, etc.
V9 ecus are immobilizer ecus unless you get a spec c, which is a different animal all together.
Now go back and read the thread!
Computersare8ad is offline   Reply With Quote
Old 11-19-2012, 10:01 PM   #4898
mattrubywrx
Member#: 315635
04 STi
Hey guys
Whats a good stand alone system to run for the v7 ej207? i have avcs wired up and, and am running my previous 02wrx wiring harness (modified).
any suggestions or preferences from experience?
mattrubywrx is offline   Reply With Quote
Old 11-19-2012, 11:18 PM   #4899
Clark Turner
Member#: 178047
02 WRX STI Spec C
There is more and more and more bs in this thread
Mattrubywrx, The Link G4 Plug in is the best aftermarket ecu at this time for the V7 to V10 engines. They plug in but will require a professional to calibrate them. They have full cam control for AVCS use.
http://www.linkecu.com/products/engi...4-plug-in-ecus
Clark Turner is offline   Reply With Quote
Old 11-19-2012, 11:28 PM   #4900
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well a lot more ppl reading and then retyping what they see in a slightly different fashion tends to make that happen. plus many new ppl asking general questions which mostly apply to a ej20 engine and not specifically to ej207. this tread has pretty much lost most of its informative matter and turned into a dialy question/answer discussion. no one is going to read almost 200 pages to figure out what they want. they just ask now and say" well just read the whole thread but still dont knwo what to pick" etc etc. when i first read it there was like 75 pages which only took a few class periods sitting on my lap top in history class. now its too hard to weed through it all. sub threads need to be added to the top of the thread asap including a ej207 newbie question thread so it keeps the bs stuff out.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
