#5101 | |
Member#: 56754
NESIC
Vehicle:2004 Hybrid 2.5XTR RIP Chris@EFI |
We swapped his IAC over from his WRX and it seems to have solved the idle issue. ![]() AVCS wiring is complete and double checked, we reset the ECU and CEL is still on. Car will start and idle great but won't rev past 2700 rpm. None of the other sensors looked damaged but we can't pull the CEL since I don't have a tatrix cable anymore. ![]() Any other ideas are appreciated.
#5102 |
Member#: 175334
TXIC
Vehicle:2003 Impreza WRX JDM v8 EJ207 WRB |
^^ Get the CEL checked out asap... take it to an autozone or other local parts shop, that'll do it for free. Car could be in 'limp mode' for some reason... which will limit the revs afaik.
#5103 |
Member#: 110078
Vehicle:2005 92x - 02 wrx silver 92x-wrb bugeye wag |
Sounds like it still in limp mode, you should take it for a gentle drive, I had the same issue and it cleared up when I drove it a short distance.
#5104 | ||
Member#: 79643
NESIC
Vehicle:04 EJ207 Swapped Mikey tuned 271whp/287wtq |
Still had a flashing CEL. Problem solved, unplug the IAT sensor on the back of the manifold. |
#5105 |
Member#: 287080
TXIC
Vehicle:2004 WRX PSM |
Stock dp is cast iron. But it is just an open bell mouth.
#5106 |
Member#: 154281
W. Canada
Vehicle:2002 V7 EJ207 Dom1.5 MBP |
Huh. I didn't think it was cast (could be wrong). But here's a pic of a V9 dp.
#5107 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
#5108 |
Member#: 287080
TXIC
#5109 | |
Member#: 291949
http://www.avoturboworld.com/avoshop...roll-p-10.html I hope the stock bellmouth DP is cast iron, would likely mitigate any wanting to do a custom catted DP. And of course the cheap eBay stuff sounds to good to be true (but atleast has exhaust & waste gases separated). Even with a decent ceramic coating I doubt it would perform as well as a cast iron bell mouth on the stock DP (if it actually is). Here is some cheap eBay twin scroll EJ207 DP if anyone is interested. The second one looks rather well made. http://www.ebay.ca/itm/2002-TO-2007-...#ht_996wt_1037 http://www.ebay.ca/itm/SUBARU-IMPREZ...#ht_500wt_1054 Last edited by 2JZ; 12-12-2012 at 10:24 PM. |
#5110 |
Member#: 292823
SCIC
Vehicle:2003 WRX EJ207 TEC 20G 8cm |
#5111 |
Member#: 110078
What are you doing for the oil cooler, are you eliminating it ?
#5112 |
Member#: 292823
SCIC
#5113 | |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
I've considered reporting him to ebay.uk. |
#5114 |
Member#: 255716
NWIC
Vehicle:04.5 v9 STI in wrx clothing, covered in PSM. |
The guy welded mine up had no issues welding the stock bellmouth to a ss dp. It sure looks like ss to me when it is cut, looks cast from the outside though. Weird, my metallurgy isn't that great though.
#5115 | |
Member#: 293355
I bought the AVO world outlet. It doesn't have the splitter in it as they were getting interference with the wastegates. Otherwise it seems well made. There is a fair restriction as it bends down towards the downpipe, but I don't know if that matters much. I welded a flange to a cheapo ebay exhaust. Its too loud, and stinky, so I am going to be adding a cat to it eventually. |
#5116 |
Member#: 110078
Had my ej207 tuned today by Mike at EFI Logics, here is the final product graph, the car drives awesome, it's a 93oct tune.
I'm using a Tomei down pipe, borla hush catback, Perrin turbo inlet, walbro 255 fuel pump, Ixiz concepts ebcs on an otherwise stock 2003 jdm ej207 ver 8 engine and ecu with working AVCS. Thanks EFI Logics, your professionalism and quality of work is top notch, thank you. ![]() ![]() Last edited by D-Rodman; 12-14-2012 at 10:32 AM. |
#5117 |
Member#: 79643
NESIC
I hope mine looks similar. I'll probably put out considerably less though due to the stock downpipe and BCS. Other than that our mods are similar
#5118 |
Member#: 107170
Vehicle:2002 ver 7 EJ207 WRX WRB |
D-Rod,
Congrats!!! Numbers look great on a otherwise stock motor. On my Ver 7, with 91 Oct, at 17psi, I made 262whp @ 6400 and (only) 242tq @ 3700 rpm. Mods were Hallman MBC, Walboro pump, Invidia catless dp, NGK one step IR plugs. My AVCS were erratic so I'm still hunting down the problem. Since I need to fix/replace the leaky fuel line, I recently bought a new Perrin inlet, Cobb catted DP, Grimmspeed phenolic spacers and Samco AFT MAF hose, all to install while the manifold is off. I will head back to get a retune after all that is done. Hopefully with the AVCS sorted out, bump up the boost slightly to reach 300whp. Doable with the VF30?? |
#5119 | |
Member#: 110078
#5120 | |
Member#: 54060
Vehicle:205 + td04=12.4@109 V8 207+VF37=12.3@111 |
#5121 |
Member#: 110078
Catless Tomei down pipe with the factory donut catback gasket. Not sure how to answer your question about Mike, I asked him how he got started tuning. He told me he is an engineer and started out a few years back tuning his own car, the job felt natural to him. Fast forward, he is becoming a prominent CT tuner on his own right and merit. He did a fantastic job on my car.
Boosting 19psi Last edited by D-Rodman; 12-14-2012 at 10:39 AM. |
#5122 |
Member#: 225439
#5123 |
Member#: 271412
Vehicle:05 ej207 wrx wagon wrb |
Efi logics is legit. And so is sti mikey. I got my v7 tuned twice by chris @ efi logics before he passed. Stage 2 maxxed stock vf30. Came in with 290whp/247 at 18psi. Left with 298/264 on 18psi. Once I fixed a spark blowout issue due to a bad coil pack I was retuned for 21psi 310/288. Car runs great.
#5124 |
Member#: 225723
NESIC
Vehicle:2002 Wrx ej207 stg 2 PSM |
Just finished my v9 STI swap into my 02 wrx. It turns over but will not start. The ecu is v8 so it's not immobilized. Could it be that I didn't change the Neutral Safety Switch??? There is fuel at the fuel rails, dont know if maybe the injectors are stuck from sitting. Any ideas? Thanks guys.
#5125 | |
Member#: 79643
NESIC
| Thread Tools | |
| Display Modes | |
| ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain | 2 | 02-26-2011 07:29 PM |
| Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain | 10 | 06-03-2010 04:53 PM |
| JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
| 08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
| Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain | 21 | 10-17-2005 01:56 AM |
