Old 12-20-2012, 06:53 PM   #5176
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I promise that stuff is better than what I used. I doubt I'll have this turbo that long, but perhaps down the line I'll do it.
Got any pictures of the stuff you used? Did you coat the inside at all?
I'm really inclined to remove the OEM manifold shrouds and coat /wrap the pipes and then reinstall the shrouds. I think this might be useful given past experiences with thin walled tube headers.
Old 12-20-2012, 09:32 PM   #5177
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
LOL Iron Oxide=Rust
lukeskywrx is offline   Reply With Quote
Old 12-20-2012, 09:55 PM   #5178
kpluiten
Member#: 120273
06 WRBWRXWGN
Originally Posted by lukeskywrx View Post
LOL Iron Oxide=Rust
I know what iron oxide is. The was I read your post, I thought you were talking about some ceramic coating that blocked/prevented rust (which most should).
So you have no coating, and only rust. I read you now.
Old 12-21-2012, 10:19 AM   #5179
mekilljoydammit
Member#: 258151
Hey, just in the sense of trying to budget, anyone have any feedback on how much cams (GSC S1 or Kelford 199-B - both 264ish with 10.5ish lift) would be worth on a milder V8? I'm budgeting for a V8 swap for a non-tracked DD, am only shooting for high 300s, maybe 400whp but I'm not chasing a number - just something like a twin scroll Dom 1.5 or so and an unopened motor. The stock cams are just so relatively tiny from what specs I've found, and it would be so much easier to do with the engine out of the car.
mekilljoydammit is offline   Reply With Quote
Old 12-21-2012, 10:34 AM   #5180
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
From the numbers people have been getting from the 1.5TS I do not think cams are really necessary for that power level, especially if you are wanting to keep it as a daily driver.
Old 12-23-2012, 11:20 AM   #5181
Modollenroc
Member#: 243499
I am in the process of getting a v6 swap and I do not know what Ecu to use. Not trying to spend over 9000 doll hairs for a Power FC. . .the car will be ran on 91 octane since California wants to be lame.
It will be my daily/occasional mountain drive car. And im not shooting for big power...Help??
Modollenroc is offline   Reply With Quote
Old 12-23-2012, 11:48 AM   #5182
kpluiten
Member#: 120273
06 WRBWRXWGN
Why don't you tell us what type of car you have? Also, why a Ver 6 setup?
Old 12-23-2012, 12:00 PM   #5183
Modollenroc
Member#: 243499
2001 rs. No real reason on why I went with a v6. My biggest thing is to get the car to comply with 91 octane without detonation and then MAYBE hit 300 whp using AVCS and Turboback exhaust.
Old 12-23-2012, 02:25 PM   #5184
Diodon
Member#: 341423
Sounds like it still in limp mode, you should take it for a gentle drive, I had the same issue and it cleared up when I drove it a short distance.
Diodon is offline   Reply With Quote
Old 12-23-2012, 02:29 PM   #5185
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
you might want to check out the rs25.com forum, iirc there was some chatter about ecutek having offering for the older v6 platform or just contact ecutek themselves.
fastnoypi is offline   Reply With Quote
Old 12-23-2012, 10:10 PM   #5186
Modollenroc
Member#: 243499
Thanks. I am on that forum I will search ecutek
Old 12-24-2012, 04:39 PM   #5187
kiwi_fozze
Member#: 339562
could always get hold of a v7 non avcs ecu, few wiring changes and trigger wheels and it'll run in your v6.
kiwi_fozze is offline   Reply With Quote
Old 12-25-2012, 01:35 PM   #5188
azeyatic
Member#: 261620
2004 WRX
WRB-
Merry Christmas to all! Happy to have finally gotten through this thread! Proud owner of freshly swapped EJ207 type RA Spec C! Tune happening 2moro! Thanks to Vlad, [email protected] and JDMRacingM!
azeyatic is offline   Reply With Quote
Old 12-25-2012, 03:07 PM   #5189
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
What mods do you have on that swap ?
D-Rodman is offline   Reply With Quote
Old 12-25-2012, 11:07 PM   #5190
azeyatic
Member#: 261620
2004 WRX
WRB-
Just the standard stg 2 setup, SRI, TBE ..have a perrin turbo inlet laying around but debating if I should put that on. Just need some reliability until summer comes around.
Old 12-26-2012, 06:54 AM   #5191
D-Rodman
Member#: 110078
05 saabaru artc gr
With the short ram intake I would think you would also benefit from having the Perrin inlet, surprised you didn't install it. I like them inlet pipes, have them installed on both my rex's. I run stock air boxes on mine but I'm sure a less restrictive air path is nothing but good.
Old 12-26-2012, 11:21 AM   #5192
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I have a perrin on mine aswell. Fits and works well
mrxr250rider is offline   Reply With Quote
Old 12-27-2012, 02:57 AM   #5193
NDLBot
Member#: 341731
Best source of info I've found so far : )I want to share with my friends
NDLBot is offline   Reply With Quote
Old 12-27-2012, 12:17 PM   #5194
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Is there supposed to be a link there?
Old 12-27-2012, 12:39 PM   #5195
Modollenroc
Member#: 243499
to order stuff for the 207 I would need to be purchasing ej205 parts? Like if I were to get an intake manifold...or exhaust downpipes cat back etc...
Old 12-27-2012, 04:04 PM   #5196
rdieder
Member#: 257818
2007 STi
CGM
Best source of info I've found so far : )[img http://.net/www/images/tivitie.gif[/ img]I want to share with my friends
thanks for the useless gif
rdieder is offline   Reply With Quote
Old 12-27-2012, 05:15 PM   #5197
kpluiten
Member#: 120273
06 WRBWRXWGN
He's a spammer.
http://forums.nasioc.com/forums/sear...rchid=35232275
Old 12-27-2012, 09:08 PM   #5198
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Hey guys i'm selling my kinugawa twinscroll TD05-20G, it has <5k miles hit me up if you're interested
murrdogg24 is offline   Reply With Quote
Old 12-27-2012, 09:26 PM   #5199
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
pm me price picked up. Ill be back in SD on jan 9
Old 12-28-2012, 12:46 AM   #5200
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Today was a good day for the wagon.
Psychoreo is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
