Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-21-2009, 10:36 AM   #501
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Originally Posted by subydude View Post
I'm not sure either cam is worth the upgrade IMO. That seems like an pretty small bump between the two cams themselves. Plus the other cams on the market are up in the 272 duration range. If you're going to go through the trouble up upgrading cams then you might as well get something that's really going to make a change.
I'd compare this to swapping from a vf39 to a regular 16g. Yeah, you might gain a little on the top end, but was it really worth all the trouble for those extra 15 hp up top?
the question here is really matching the turbo's abilities with the cams, and because it won't give anything beyond 7k, I don't see much point in getting 272 cams, plus considering my main goal is response
Hyper is offline   Reply With Quote
Old 07-21-2009, 01:38 PM   #502
azmurciev12
Member#: 92501
2004 STi-GDB
white
how about some kelford cams? seems like they have more options. anyone have an idea what would work best with a PE1825? thanks
http://www.nolimitmotorsport.com/kel...ps-SUBARU.html
azmurciev12 is offline   Reply With Quote
Old 07-21-2009, 01:43 PM   #503
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Now those look tasty I think the "C" type cams would be perfect for a 20g. "B" for slightly better low end.
subydude is offline   Reply With Quote
Old 07-21-2009, 01:55 PM   #504
cordizzle
Member#: 55109
2006 sti
Who makes a rotated TS GT30? This might change my plans of a td05 20g depending on spool characteristics
This!
cordizzle is offline   Reply With Quote
Old 08-01-2009, 11:09 AM   #505
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Alright, need some of the experts help here. I have a V7 swap going into a 04wrx and want to make sure I get the last wire right. My question is what is this "Shield Common Ground" wire that is plugged into the 14th pin on the B84 connector @ the ecu? What does it go to? This is the last wire I have to finish up the electric.
My source was DS1's write-up, (Kudos btw as it's really simple with this) I just don't know what to do at this pin and what its connected to.
Oh, and a little trick.......if you can get a donor wiring harness you'll never need to splice any wires and have the perfect length connected to the proper style pins. Its been a breeze! (Thanks Mccanixx!!!)
Just a little of whats in the bag:
Stock V7 long block (w/ functional AVCS)
FP Green 3" inlet
Bosch 1000cc injectors
Corn bo0ze! (e85)
FMIC
TGV Deletes
Header
All straped to a PPG Dogbox
MID-OHIO.........here I come!
Rasmusson14 is offline   Reply With Quote
Old 08-01-2009, 11:19 AM   #506
subydude
Member#: 80649
Quick qestion about ECU's. My current one is has an ecutek tune on it and I'd like to go to something that can be tuned by someone local rather than having to drive 500 miles each time it needs tuned. I have a line on another Ver 7 JDM STi ecu. I'm assuming that it's going to be more or less the same as my current AH970 ecu?
Old 08-02-2009, 12:23 PM   #507
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
i'm pretty sure the ecu is the same. its the reflash version thats different. get yourself a tactrix cable and the romraider/ecuflash software and you can self tune. If your not that comfortable with a selftune you can send your image to one of the many vendors that e-tune. You log they tune....you flash....repeat the process until you the customer and they the tuner like the map and data logs.
scoobystas is offline   Reply With Quote
Old 08-02-2009, 03:38 PM   #508
subydude
Member#: 80649
Good to know. That was the whole reason to get a new ecu, to tune it myself, or get tuned by someone closer than 500 miles away.
Old 08-02-2009, 04:15 PM   #509
Scott_2.5TS
Member#: 163806
Which version is the easiest to swap into a '02 WRX??
Scott_2.5TS is offline   Reply With Quote
Old 08-03-2009, 03:32 AM   #510
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
if anyone has gone twin scroll but has a stock downpipe, i have a custom downpipe and midpipe for sale.
http://forums.nasioc.com/forums/show...ht=twin+scroll
By rcozpinoy, shot with iPhone at 2009-07-12
Arco
arco is offline   Reply With Quote
Old 08-06-2009, 06:29 AM   #511
RealDealTarheel
Member#: 142447
**** Texas
V7 EJ207 owners:
I just picked up my Bug-eye STi and I'm not too far from installing some Defi's, Boost, EGT and Oil Pressure, I was curious what are the operating norms for this motor? The car had obviously been modified by the previous owner so I was hoping to get some insights as to what to look for as far as baseline numbers.
RealDealTarheel is offline   Reply With Quote
Old 08-06-2009, 08:07 AM   #512
Rasmusson14
Member#: 77658
Bump for help!!!!!!
Old 08-06-2009, 11:08 AM   #513
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Any Version 8 guys do compression tests? If so, what were the results?
Bump for help!!!!!!
PM Zephyr on here. He is a wiring guru who wired my V8/04 WRX swap in short time.
OppositeLock is offline   Reply With Quote
Old 08-06-2009, 11:22 AM   #514
Rasmusson14
Member#: 77658
Thx!!!
Old 08-08-2009, 10:50 AM   #515
OppositeLock
Member#: 54060
Bumping this question, not sure if it got lost in the shuffle or if not many have done comp tests.
Old 08-08-2009, 12:04 PM   #516
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
you probably wont find many answers, the number isnt that important but the variance between the cylinders is. Some say no more than 10% variance is acceptable, but the least variance the better. The numbers will read completely different a cold vs warm compression test.
fastnoypi is offline   Reply With Quote
Old 08-08-2009, 10:21 PM   #517
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
My version 8 was compression tested at 112 PSI on all cylinders (cold on the garage floor), and leakdown tested at 10% for 1 & 3, and 12% for 2 & 4, also cold.
~T.J.
02CWRX is offline   Reply With Quote
Old 08-19-2009, 11:40 AM   #518
team_imprezzed
Member#: 142847
2005 WRX w/ v8 EJ207
does anyone know if you can use a AEM EMS to tune the v8 207 and can it tune the AVCS?
team_imprezzed is offline   Reply With Quote
Old 08-19-2009, 03:46 PM   #519
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
AEM told me they won't support any of the JDM AVCS engines when i called them.
I'm pretty sure it wont work anyway because the AEM EMS only supports the drive by wire 32-bit ecus.
Old 08-19-2009, 04:42 PM   #520
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
most of the time you can purchase seperatley, or if your lucky, you get the jdm ecu with your motor and that is what will control your avcs.
Old 08-19-2009, 05:14 PM   #521
rsles01
Member#: 209188
Thought I would post what I just had built to put in my 01 RS, spent alot of time researching what engine to go with for the car. In my case I did not want so much torque to spin out of turns, also going with a 3" exhaust to keep the torque down even more. Also decided to stay with the 5 speed and install custom PPG ratio gears.
The ECU is a 2004 with a UTEK
Hope this helps. Remember that the 2.0 is a closed deck and has thick sleeves. While you will not have the torque of a 2.5, you will be able to pump alot of HP.
Some of the tech info on the engine.
1. Crower rods with metal free carbon coating
2. Wiseco forged pistons with coated skirts / Boring and honing with torque plate installed
3. Wiseco HD wrist pinsw / upgraded wrist pins and heavy duty rings
4. V7 Spec C crank
5. Coated ACL race bearings
6. Pinned block halves
7. Fully ported WRX heads and valve job with lash
8. DPR Stage 3 Cams (avcs holes are plugged)
9. Manley +1mm valves
10. Supertech valvesprings and titanium retainers
11. Balanced rotating assembly to 10,000 RPM
12. Torque hone plate bored and honed .5mm overbore
13. V7 Spec C block
14. Custom Steel Moroso oil pan- 6 quarts capacity
15. Modded - blueprinted 2008 STI oil pump
16. ARP Head Studs
17. Gates timing belt
18. Cometic Head Gaskets
19. New Tensioner for timing belt
20. Moroso high capacity 6qt oil pan
21. Moroso 3qt oil Accumulator
22. Mishimoto Oil Cooler
rsles01 is offline   Reply With Quote
Old 08-19-2009, 05:41 PM   #522
team_imprezzed
Member#: 142847
I do have the JDM ECU but I figured I would try to use the stand alone...guess not though. Anybody need an AEM Standalone?
Old 08-19-2009, 07:21 PM   #523
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
It will run a V8 207 no problem, but it won't control AVCS. Check out an Autronic, Motec, Link, Vi-pec, or Pectel. They all make plug and play standalones that will control AVCS.
eastcoastbumps is offline   Reply With Quote
Old 08-21-2009, 04:40 PM   #524
Rick Hunter
Member#: 825
2002 wrx
135 warm across the board.
Rick Hunter is offline   Reply With Quote
Old 08-22-2009, 12:01 AM   #525
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Anyone know anything about this pulley (on the left). I was told this is from a JDM 2002 EJ207 Spec C Limited (ie No A/C). I was also told this is made of titanium however after feeling it it seems a bit too heavy to be titanium.
ai42 is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
