Old 01-17-2013, 03:39 PM   #5401
25rsti
Member#: 166324
Either is fine, it's just a matter of how you drive/take care of your car.
Old 01-17-2013, 04:41 PM   #5402
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Originally Posted by shamrock 05 View Post
so for reliability purposes on jdm stock turbo....v7 or v8?
Both should be more than capable of handling what the stock turbos have to offer. Considering the v8 will be newer and sitting around for less time, it *should* be more reliable. But at the same time, it's next to impossible to say... w/o knowing how the previous owner(s) maintained it.
Torquey is offline   Reply With Quote
Old 01-17-2013, 05:53 PM   #5403
207STi
Member#: 197062
1998 Swapped Impreza
black
Anyone have any insight on how to pop out the pins for the F61 connector? I found some instructions on how to pop out the ECU pins, but it doesn't seem there is a little hole under the pins to stick a needle in with this connector. I am using this diagram and the accompanying instructions. Any insight is greatly appreciated.
Originally Posted by ViperWRX View Post
Here is a little diagram of what I made a few years ago when doing my 04' JDM EJ207 STI swap in my 02' USDM WRX. The shop that helped me over the phone is S.w.a.p.shop but used to be known as JDMSpecC. Hope this helps anyone else with current or future swaps. This is for wiring up AVCS exc...
2002 WRX ECU
Add Wires:
E1 Plug (Light Gray)(Located just above the turbo) to E:B84 (located at the ECU/ECM)
E1: 5 to B84:15
E1: 8 to B84: 9
E1: 9 to B84: 3
E1: 10 to B84: 2
Relocate Pins:
E:B84
Plug 4 to 6
Plug 5 to 12
Plug 11 to 17
Plug 10 to 16
F61 (Black Plug)(Located right behind the battery but infront of the Windshield Washer Resevouir)
Plug 5 to 1
Plug 6 to 2
Plug 7 to 3
Plug 8 to 4
207STi is offline   Reply With Quote
Old 01-18-2013, 12:19 AM   #5404
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
I have a bunch of extra ECU end connectors and I have not been able to depin them without mangling the connector. I was just playing with them to see how hard they were to get out.
Adding more pins is easy, getting them out cleanly is the challenge.
lukeskywrx is offline   Reply With Quote
Old 01-18-2013, 04:40 AM   #5405
turboedracer
Member#: 107617
2003 STi ej207
the silver bullet
Dumb question. Im assuming I can just get a reg OEM timing belt for 02-07 WRX/STi and it will work for EJ207?
turboedracer is offline   Reply With Quote
Old 01-18-2013, 07:17 AM   #5406
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
You use a small pick or safety pin from the connector face side to depress a small piece of plastic inside the connector.
It takes some practice but once you figure it out it's easy
Psychoreo is offline   Reply With Quote
Old 01-18-2013, 08:06 AM   #5407
25rsti
Member#: 166324
I had never tried to do something like de-pinning before having to wire in my avcs but it actually went pretty smooth for me.
I ordered my 2 gaskets I needed from IAP and they should be here tomorrow, then I can drive my car!!! Off boost of course, need to contact Clark.
Old 01-18-2013, 08:14 AM   #5408
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Order a gates racing timing belt kit, the kit part number is on this thread buried some pages back from here, search. If I have time later I'll message you the part number. Check oakos,com, they have good prices and excellent service.
D-Rodman is offline   Reply With Quote
Old 01-18-2013, 08:28 AM   #5409
turboedracer
Member#: 107617
2003 STi ej207
the silver bullet
Is a racing timing belt nessacary? I dont have many power mods on it just a few bolt ons. figure a stock would be fine and cheaper then a racing one.
Old 01-18-2013, 08:42 AM   #5410
Jayzwrexx
Member#: 125927
2000 2.5rs
Brp
the oem one will be fine also.
Jayzwrexx is offline   Reply With Quote
Old 01-18-2013, 08:52 AM   #5411
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Necesary is probably not the right way to word it.
Here are two sub-questions:
1. Can you use a non-racing belt and it will still run? Yes.
2. Do you want to trust the people that made this engine and get the right belt? Then you can do 3 things:
a. get the belt for the EJ207 from Japanparts. Not that expensive and you'll have it in 3-5 days.
b. get the Sti pink belt, which my research shows is specified for USDM as well as EJ207. I did this
c. get the gates belt. Many run it with good results and it's still a rigid belt.
The racing belts are more rigid, allow for less timing distortion between the driver's and passenger's side cams and are needed for the higher RPM that the 207 can reach. They require more often replacement than the regular ones.
The silver sticker on the right side of your engine tells you to replace the timing belt at 100 000 Km (62K Miles). Replace it again in 62K miles.
Yes, many have used USDM OEM timing belts and did not report problems.
This community, the EJ207 community, seems to do better with reliabillity of the engines.
I think it's the engines, but I think it's also awareness and a willingness to do the right thing, to maintain them properly.
Old 01-18-2013, 09:08 AM   #5412
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I should get mine replaced. I believe my motors around 69k and previous owner didn't replace it at 34k when motor was installed
mrxr250rider is offline   Reply With Quote
Old 01-18-2013, 09:18 AM   #5413
207STi
Member#: 197062
black
Is the plastic piece on the bottom or top of the pin? I grappled with that connector for almost an hour and I was almost to the point of yanking them out the back. I was using a tack and then a small flat head I filed down to no avail.
Old 01-18-2013, 09:23 AM   #5414
Psychoreo
Member#: 79643
2015 WRX STI
When you loom at the face of the connector you should see two "holes" in each slot if that makes sense.
One is where the other pin goes from the other connector and the smaller is where you poke with the pin/pick
Old 01-18-2013, 09:53 AM   #5415
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Well thats just the thing.....you dont know who owned the car. Your taking a chance with any of these motors...
From my understanding the v7 came outa the STI "bugeye"?
What cars did the v8 come out of, the "blobeye"?
shamrock 05 is offline   Reply With Quote
Old 01-18-2013, 09:54 AM   #5416
D-Rodman
Member#: 110078
05 saabaru artc gr
The racing belt kit comes with all the pulleys, tensioner and water pump. They have a similar kit with a standard belt for a little less money. I spent the extra few $$$, I just have a turbo back exhaust an inlet pipe and a 3 point ebcs. I plan on daily driving but I like to have some fun some times, this engines rev high, I want piece of mind and reliability, worth the extra money.
Old 01-18-2013, 10:39 AM   #5417
turboedracer
Member#: 107617
2003 STi ej207
the silver bullet
I wasn't going to get some cheap brand I was wanted to know if the timing belts they use for stock USDM STi would work on the EJ207. Figure if subaru puts it in the STi it's reliable.
Old 01-18-2013, 11:13 AM   #5418
207STi
Member#: 197062
black
Thanks for the advice. I'll try to tackle it tomorrow.
Old 01-18-2013, 11:15 AM   #5419
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Subaru puts the EJ257 in the STi. How are those for reliability?
(Teasing of course. Sort of.)
Old 01-18-2013, 11:17 AM   #5420
kpluiten
Member#: 120273
06 WRBWRXWGN
I found the $3 dental pick set at Harbor Freight works really well for removing terminals from the connectors. Those and a third hand.
Old 01-18-2013, 11:20 AM   #5421
Psychoreo
Member#: 79643
2015 WRX STI
This statement is far to accurate.
Old 01-18-2013, 11:28 AM   #5422
turboedracer
Member#: 107617
2003 STi ej207
the silver bullet
I have an 06 STi with the EJ257 I don't have a whole lot of mods done to it but hit 130K on it with no major issues only thing thats has broke on it was radiator when I was playing in the mountains, but thats just me. Now the rear struts on the other hand
Old 01-18-2013, 11:55 AM   #5423
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Hey I just want to throw this out there for you guys, since so many people are running non-matching ECUs. There are two different MAP sensors on these motors and ECUs. Make sure you are setup for the proper sensor otherwise you will be running ~2.3 psi higher or lower than you think. On an unrelated side note the VF36 feels amazing on E85 at 26 Psi
USDM 02-05 WRX 2.8 BAR sensor
JDM v7-v8 01-04 2.8 BAR sensor
JDM v9 05+ 3.0 BAR sensor
2.8 BAR Multiplier=9.943 Offset=-8.005
3.0 BAR Multiplier=9.943 Offset=-5.666
Old 01-18-2013, 03:08 PM   #5424
D-Rodman
Member#: 110078
05 saabaru artc gr
Do not ignore the idlers, tensioner, water pump, etc, replace everything at the same time as the belt, don't wait till you're sorry you didn't do it right the first time. Something other than the belt fails and the results can be just as bad.
Old 01-18-2013, 03:13 PM   #5425
johnfelstead
Member#: 856
2005 JDM STi
I've been running JDM STi's since 2000, doing a huge amount of miles on track and road, current MY05 JDM STi engine is running 500BHP and 540FtLb, i've always used OEM or equivilent gates spec belts.
I wouldn't change from this unless changing to a none OEM camshaft/valve spring configuration that would load the belt up more, OEM is designed for an 8200rpm limiter spec.
Change your belt every 5 years, irespective of mileage, and do the idlers and tensioner at the same time.
johnfelstead is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
