Old 08-22-2009, 01:36 AM   #526
mattyquinn22
Member#: 37045
my99 Impreza Rs
silverthorne melatic
Quick question, I'm having Garage Tuning drop in a 207 V8 motor into my 99rs and it comes with a VF39, Will this turbo be a good one for a DD. I'm keeping my 5 speed for awhile too if that helps with your response. Thanks
mattyquinn22 is offline   Reply With Quote
Old 08-22-2009, 06:06 AM   #527
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
V8 comes with twinscroll turbo, EL manifold which are nice bits and perfect for DD, so you are missing out a lot of fun
plus VF39 are notorious for cracking
Hyper is offline   Reply With Quote
Old 08-22-2009, 10:33 AM   #528
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Originally Posted by ai42 View Post
Anyone know anything about this pulley (on the left). I was told this is from a JDM 2002 EJ207 Spec C Limited (ie No A/C). I was also told this is made of titanium however after feeling it it seems a bit too heavy to be titanium.
Hate to break it to you, but I have that engine. The "Limited" meant it HAD AC and a vf30 instead of the vf34. Mine has the standard pulley. I don't know if the regular Spec-C had that pulley or not, but all of the Subaru pulleys I've seen have been regular old OEM style.
subydude is offline   Reply With Quote
Old 08-22-2009, 11:30 AM   #529
ej20ajk
Member#: 113223
08 WRX NB R180
Just did the swap, and read few posts saying that bare minimum recommended gas is 94 octane -I am curently running on 91 octane.
Is the stock wrx fuel pump sufficient or upgrade is necessary?
ej20ajk is offline   Reply With Quote
Old 08-22-2009, 11:32 AM   #530
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Umm what? What does fuel pump have to do with octane? I think you need to do some reading.
ai42 is offline   Reply With Quote
Old 08-22-2009, 11:51 AM   #531
Clark Turner
Member#: 178047
02 WRX STI Spec C
The WRX pump is not enough in my opinion. I would order a Walbro 255 pump now. On 91 octane you will be knocking on the JDM tune. You need to recalibrate the ECU for your mods and octane. I have files you can use. You will need a tactrix cable to flash the ECU.
Clark
Clark Turner is offline   Reply With Quote
Old 08-22-2009, 06:29 PM   #532
ej20ajk
Member#: 113223
08 WRX NB R180
It was worded very poorly. Its actually two different statments which sort of tie in.
I am afraid that fuel starvation in higher RPM coupled with detonation from low octane fuel can lead to cathastrophic motor destruction, sooner then later.
Clark
I heard great things about your tunes. Only issue, is that my Tactrix cable is packed up for next 3 months in offsite storage, till I move into my new house. But definatly want to get it retuned for 91 octane, and higher boost.
Hence the question about the octane and pump being bare minimum.
-AJ
Old 08-22-2009, 07:17 PM   #533
Clark Turner
Member#: 178047
02 WRX STI Spec C
I understand. If there is anything I can do, Just let me know man.
Clark
Old 08-23-2009, 04:26 PM   #534
mattyquinn22
Member#: 37045
my99 Impreza Rs
What does everyone here think about the Version 6 Sti 207 compared to a USDM Ej205? Any major benifits?
Old 08-23-2009, 05:48 PM   #535
Clark Turner
Member#: 178047
02 WRX STI Spec C
early V6 STI motors are small port. Still an upgrade. Later V6 motors are exactly the same as the V7s. Big port and more power.
Clark
Old 08-23-2009, 09:41 PM   #536
dankster
Member#: 54592
I thought the regular V7 had small ports and the V7 Spec C had the large ports? Are there different casting numbers or something so you can tell what you're buying?
dankster is offline   Reply With Quote
Old 08-23-2009, 09:43 PM   #537
Clark Turner
Member#: 178047
02 WRX STI Spec C
Regular V7, 8 and 9 JDM STI all had large port heads.
The Aus and some other markets had the V7,8 and 9 with small ports.
JDM are big ports though.
Clark
Old 08-23-2009, 11:10 PM   #538
dankster
Member#: 54592
Does the V8 have any advantages over the V7 besides the twinscroll? Are the cams better or something?
Old 08-23-2009, 11:18 PM   #539
Clark Turner
Member#: 178047
02 WRX STI Spec C
Standard V8 JDM STI motors came with the same cams as the V7 Spec C. They also have Hyper cast pistons. later V8 STIs motors has Twin scroll. Early did not.
C
Old 08-25-2009, 04:13 PM   #540
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I found a Version 3 front clip for 3700 and want to put it in my GC.
I will use this as my daily driver.
Is there any sort of tuning i can tune it to take 93 octane?
Is this a good engine? Will it be reliable and still make good power with the 93?
Or should i just save up and find a Version 4, 5, or 6?
Smoke is offline   Reply With Quote
Old 08-25-2009, 06:02 PM   #541
RealDealTarheel
Member#: 142447
**** Texas
The answers you seek are in the pre-2002 factory power train section. But the short answer is that is an EJ20K, it's a roll of the dice from what I've seen with those engines especially if your part of the country doesn't get 93 octane.
RealDealTarheel is offline   Reply With Quote
Old 08-25-2009, 06:04 PM   #542
RealDealTarheel
Member#: 142447
**** Texas
Originally Posted by RealDealTarheel View Post
V7 EJ207 owners:
I just picked up my Bug-eye STi and I'm not too far from installing some Defi's, Boost, EGT and Oil Pressure, I was curious what are the operating norms for this motor? The car had obviously been modified by the previous owner so I was hoping to get some insights as to what to look for as far as baseline numbers.
Anyone?
Old 08-25-2009, 06:42 PM   #543
Clark Turner
Member#: 178047
02 WRX STI Spec C
Skip the V3 motor.. Get a later V7 or V8 engine. Its much better and the ecu is tunable.
EJ207s will run 18 to 19 psi of boost factory in higher gears. EGT really depends on where the probe is.. But if its in the manifold 4 inches from the port, It should be around 850 to 900C on a long WOT pull. Oil pressure will depend on the oil used. 10W40 is what I run in these motors and that gets 20 to 25 psi at idle and 80 to 100 above 4000 rpm.
Clark
Old 08-25-2009, 06:51 PM   #544
RealDealTarheel
Member#: 142447
**** Texas
Thanks for the info, I tapped the probe right in front of the factory 02 sensor on the drivers side exhaust manifold so I think that should buff out with what you just told me. Right now I'm running Amsoil 5w-30 but I think the next oil change I'm going back to M1 0w-40 or try out the Rotella-T 15W-40.
Old 08-25-2009, 07:12 PM   #545
Clark Turner
Member#: 178047
02 WRX STI Spec C
Dont put the 15W in that motor.. 10/30 or 10/40 is fine. You can run 5w oil in the winter if it gets cold where you live.
850 to 900C in the manifold is normal.
Cya
Clark
Old 08-26-2009, 02:07 AM   #546
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
That's what I heard. I doubt many tuners these days are using Hydra or anything like that.
I'm on a budget, I'm not planning to make a track beast or a dyno queen, but a reliable car.
I'm just wondering if I could run an earlier motor here reliably with a good tune to take 93 octane and maybe meth?
Old 08-26-2009, 02:16 AM   #547
Clark Turner
Member#: 178047
02 WRX STI Spec C
I ran a V7 Spec C motor for 12 months. I had a GT30R and FMIC on it. PE800CC injectors. It made 400whp on pump gas and I sprayed a 70 shot of nitrous on it. It ran better then I can describe.. Then I did donuts and slung the oil away from the pick up and toasted the Rod bearings. Before this stupid mistake, It was rock solid reliable.
Clark
Old 08-26-2009, 12:16 PM   #548
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i havnt seen the Hyrda being run on the v3 platform but have seen a few older modded subarus run on SDS engine management.
If you're on a tight budget and are leaning to more a daily driver, a newer wrx swap might be more inline with your goals. Supportability ties into reliability when doing a swap.
fastnoypi is offline   Reply With Quote
Old 08-26-2009, 07:59 PM   #549
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
So an older STi motor isn't really worth it?
I've read a WRX swap into a GC is pretty hard compared to JDM.
What about a V5 or V6 are those good?
Old 08-27-2009, 02:34 AM   #550
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
for 3700 i really don't think its worth it. use that money and look around for a late big port version 7 or version 8. i went with a version 8.
as stated from others above, i believe that the internals are stronger on the version 7. they have forged internals versus the version 8 which is hyper cast. The hyper cast (still not sure if that's what it's called) is still still stronger than the stock usdm stuff we have. The version 8 has some nice accessories with it like the one piece tgv less manifold.
arco is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
