Old 02-01-2013, 08:53 AM   #5551
Florin1
Member#: 163625
91 Legacy SS
Originally Posted by rdieder View Post
i hope you have the matching ecu for it. If you don't, I think the old timers in the thread will punch you in the balls
It looks like a big wiring job.
What are you planning to use for turbo and injectors? I also notice you didnt get the ac and ps pump, will your existing ones on your wrx just plug in?
I'm using all my stuff. I only need the heads really. My turbo is a vf30
Florin1 is offline   Reply With Quote
Old 02-01-2013, 09:06 AM   #5552
rdieder
Member#: 257818
2007 STi
CGM
so you are just slapping on v8 heads on a 205 block and plan to run a jdm ecu?
rdieder is offline   Reply With Quote
Old 02-01-2013, 09:07 AM   #5553
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
so you will use a short block from a Legacy?
What engine do you have now and which ECU do you plan to run the EJ207 with?
Old 02-01-2013, 09:39 AM   #5554
Florin1
Member#: 163625
91 Legacy SS
My car is a 02 wrx. Ej205. open sourced. I plan on swapping the heads off the 207. so to have the avcs working I need to get what? Jdm V7/8 ecu? what else?
Old 02-01-2013, 10:04 AM   #5555
rdieder
Member#: 257818
2007 STi
CGM
That sucks, sorry i think the magic and reliability is to have the whole jdm shortblock and avcs package. but i hope you get your car up and running.
Maybe start a thread in the subaru conversions forum, so any specific issues and questions that you find unique to your hybrid don't confuse future swappers in this thread.
Old 02-01-2013, 11:07 AM   #5556
Florin1
Member#: 163625
91 Legacy SS
That's what I plan on doing. I just didn't want a bunch of people crying about using the "search" button
Old 02-01-2013, 12:31 PM   #5557
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Florin1, get a v7 ecu and a IA Performance acvs harness to start with. Are you going to use the crank, rods and pistons from the 207 on your 205 cases?
D-Rodman is online now   Reply With Quote
Old 02-01-2013, 01:08 PM   #5558
Florin1
Member#: 163625
91 Legacy SS
Thank you for the answer. This is what I need to find out. Any V7/8 Jdm ecu ?
Yes I plan on swapping the internals as well.
Old 02-01-2013, 04:01 PM   #5559
biodude
Member#: 271720
wont he need the JDM engine harness as well?
biodude is offline   Reply With Quote
Old 02-01-2013, 05:32 PM   #5560
efiniluvr
Member#: 107170
2002 ver 7 EJ207 WRX
No, he can reuse the EJ205 harness, add the AVCS wires and repin TGV wires.
efiniluvr is offline   Reply With Quote
Old 02-01-2013, 05:56 PM   #5561
Florin1
Member#: 163625
91 Legacy SS
Ooh. More info please. Any links on a diy?
Old 02-01-2013, 06:09 PM   #5562
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Search for the DS1 Motorsports or IAP Avcs wiring diagram in this thread. I recall someone posting a google docs link.
fastnoypi is offline   Reply With Quote
Old 02-01-2013, 06:52 PM   #5563
biodude
Member#: 271720
late night edit: nvrmind
Old 02-01-2013, 07:58 PM   #5564
davilleky
Member#: 342361
Im plan on swapping a v7 ej207 into my 2000 2.5 RS. I had a vendor on here send me some pics of a few motors they had. I have a question, One of the pics had a ecu with 8A on it, is this the proper ecu for this motor?
davilleky is offline   Reply With Quote
Old 02-01-2013, 08:27 PM   #5565
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
http://www.iaperformance.com/product...oducts_id=2580
That, + JDM ecu + tune= good to go. The manifold is the same(IIRC) except the TGV are deleted. Lmk how the install goes.
JulianDelphiki is offline   Reply With Quote
Old 02-01-2013, 11:29 PM   #5566
StillBoostin
Member#: 46177
2002 WRB WRX
99 RSTi Coupe
Ok, so i just read a ton of pages and didnt find my answer. Did the wiring swap according to DS1, shielded wire harness and stock pins. I turn the key on and the check engine light flashes rapidly. Scanner says 0 codes. It starts and runs great on V7 481 ecu. The engine is a V8 on a 2004 wrx wagon. Thanks for the help.
James
StillBoostin is offline   Reply With Quote
Old 02-02-2013, 08:11 AM   #5567
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
posts 1341-1350
Originally Posted by murrdogg24 View Post
I just finished installing my EJ207 with JDM ecu today but when I went to start it up for the first time the CEL started flashing immediately when I turned to key over to prime the fuel system. I started up the engine and let it run until it reached operating temp and the CEL kept flashing but the motor seemed to run fine. I used the wiring kit from IAPerformance to wire up the AVCS. Does anybody know what the problem could be? I'm thinking one of the wires in the ECU plug did not seat properly. Would not having AVCS hooked up cause the CEL to blink?
Originally Posted by Clark Turner View Post
Unplug your PCV connector. The JDM motor does not use it and your 04 has it. Sometimes you could also have a Loop back plug put in the connector if you have an aftermarket inlet pipe.
Ok I think I fixed the problem. Went back today pulled off the TMIC and unplugged the connector under the throttle body now I'm not getting a CEL.
Old 02-02-2013, 08:30 AM   #5568
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
My mistake, they didnt have this new harness avail with the avcs connector plugs when I did my swap.
666stars is offline   Reply With Quote
Old 02-02-2013, 10:05 AM   #5569
D-Rodman
Member#: 110078
05 saabaru artc gr
666stars, read the last paragraph of your post, or call your lawyer and have him read and interpret for you. The Iap harness gets around the missing manifold wiring. The rest of the wiring is already on his car. Edit or delete your post, thank you.
Old 02-02-2013, 11:00 AM   #5570
666stars
Member#: 221364
Well I can interpret what the (D) in your screen name stands for
Old 02-02-2013, 11:59 AM   #5571
StillBoostin
Member#: 46177
2002 WRB WRX
99 RSTi Coupe
Originally Posted by fastnoypi View Post
posts 1341-1350
Wow your a life saver! I go do that today and check back with the results.
Old 02-02-2013, 01:11 PM   #5572
efiniluvr
Member#: 107170
Let's all simmer down a bit gentlemen. What D-Rodman was trying to say was, the wiring information has been spoken to many times and maybe you were a bit confused. Perhaps I should've said "He can use his EJ205 engine harness and simply add the AVCS wires, since the EJ205 engine harness is just short of the 4 AVCS wires.
In short, for those that are swapping the EJ207 over, if you already have a intact engine harness, you can reuse your EJ205 engine harness; no need to spend the extra money for a JDM EJ207 engine harness
-Jeff
Old 02-02-2013, 01:18 PM   #5573
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Doctor?
lukeskywrx is offline   Reply With Quote
Old 02-02-2013, 09:33 PM   #5574
D-Rodman
Member#: 110078
05 saabaru artc gr
Thanks for correcting your post, it's a car forum bud, no need to get emotional.
Old 02-04-2013, 03:18 AM   #5575
nola
Member#: 291124
05 wrx
blue
I need some info. I have a 05 wrx and I am looking to do a full swap but Im not sure to what? my question is what is the easiest/best option for my car? V6, V7,V8,V9??? I have a lot of mods and wanted to know if I could reuse them or would I need to sell them and buy new ones? bigger injectors, turbo, up pipe, down pipe, front mount intercooler, exhaust, etc.. also with same mods done to a 207 what kind of power should I expect? I am at about 300whp and if I do the swap would like to put down more than that (with a good tune of course) is this doable? thanks in advance..
nola is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
