Old 02-04-2013, 05:43 AM   #5576
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by nola View Post
I need some info. I have a 05 wrx and I am looking to do a full swap but Im not sure to what? my question is what is the easiest/best option for my car? V6, V7,V8,V9??? I have a lot of mods and wanted to know if I could reuse them or would I need to sell them and buy new ones? bigger injectors, turbo, up pipe, down pipe, front mount intercooler, exhaust, etc.. also with same mods done to a 207 what kind of power should I expect? I am at about 300whp and if I do the swap would like to put down more than that (with a good tune of course) is this doable? thanks in advance..
It's a fairly direct swap for v7 / v8. v9 if you can find an ECU that will work (or you need the ignition from the donor, which usually doesn't happen.)
Obviously these will come with stock STi injectors, if that's not enough for you, you need to move injectors over.
Power-wise on the same turbo you will generally see a small bump in peak power from the better flowing heads. Not huge, but some. AVCS means low end and off-boost improves, so the powerband is overall broader on the 207.
v8 / 9 is twinscroll and you either use all the JDM stuff or you move EVERYTHING over from your current engine. Header, uppipe, turbo, downpipe, heat shielding + brackets, oil cooler, and intercooler support bracket are all different from single scroll.
Concillian is offline   Reply With Quote
Old 02-04-2013, 03:18 PM   #5577
nola
Member#: 291124
05 wrx
blue
are there any pros and cons going with one over the other, like should I get a v7 before getting a v9 because its ...??blank??...???blank...?????? or get a V8 before getting a V7 because ...????blank..??blank??.. get what im saying?
nola is offline   Reply With Quote
Old 02-04-2013, 03:24 PM   #5578
WagonMafia23
Member#: 273900
02 wrx
SRP
someone should take all the info and put it in the first page
-best place to get motors
-what are good things to replace/look over before install
-what is needed for each motor to work
it would kill alot of random questions
WagonMafia23 is offline   Reply With Quote
Old 02-04-2013, 03:32 PM   #5579
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
It is covered almost once per week, READ!
Or for the more condensed version
http://forums.nasioc.com/forums/show....php?t=2385141
I still say the 207 needs its own dedicated sub-forum within the 2.0L Powertrain forum
lukeskywrx is offline   Reply With Quote
Old 02-04-2013, 03:44 PM   #5580
nola
Member#: 291124
05 wrx
blue
thanks, I did read that whole post already.
Old 02-04-2013, 04:13 PM   #5581
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Question for you guys that are running the CarBerry SD rom - what are you using to meter your intake air temps?
Are you using the IAT sensor built into the MAF? Using the OEM intake manifold temp sensor located below the throttle body? Or an aftermarket IAT sensor scaled and mounted somewhere?
I have the stock air box currently and might go with a cold air intake eventually. I'm trying to determine the best option for metering the intake temps. It seems like a lot of people just use the MAF sensor's IAT reading and that is good enough but being that intake temps are more important with SD, I want to use the best location.
Let me know what you guys think the best option is.
WRXt4cy is offline   Reply With Quote
Old 02-04-2013, 04:29 PM   #5582
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
mount one in the intake mani. or the bottom tank of the tmic.
WhiteBgeye02 is offline   Reply With Quote
Old 02-04-2013, 04:52 PM   #5583
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
There is already one in the intake manifold, below the throttle body. Should I wire it to the intake temp wires going to the MAF sensor currently? Do you know if it uses the same scaling as the MAF IAT sensor?
Old 02-04-2013, 07:29 PM   #5584
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Do not use the one that is already in the manifold, it is a closed element sensor so it has really bad response and it heat/cold soaks horribly. I have played with it and the fueling was rarely correct. The GM sensor is nice but needs a big hole in the intake manifold or IC. I chose to go the more elegant route and made mine with an old thermister from a dead MAF and a BSP plug that replaced the PCV valve. It responds as fast as the GM sensor but cost me 0$
Old 02-04-2013, 09:01 PM   #5585
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
Are there any better sensors that could replace the sensor in the manifold or is it just easier to tap the IC? Seems like it would be a pain to swap that sensor.
simon021 is offline   Reply With Quote
Old 02-04-2013, 09:20 PM   #5586
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
http://www.nzefi.com/product/inlet-a...rature-sensor/
This one will replace the stock sensor or the PCV valve, i believe both are 1/8 BSP
Old 02-04-2013, 11:02 PM   #5587
StillBoostin
Member#: 46177
2002 WRB WRX
99 RSTi Coupe
Originally Posted by StillBoostin View Post
Wow your a life saver! I go do that today and check back with the results.
So the sensor under the T/B was it! Thanks again.
StillBoostin is offline   Reply With Quote
Old 02-05-2013, 12:15 AM   #5588
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
this is what i did but used a small npt end. silconed one into it and then taped the throttle body at an angle toward the top. got about 3 or 4 good threads and used some sealant. being its right before the iacv hole near the top of the butterfly valve it gets all the air flow during idle and when u crack the throttle the valve tips away from the sensor allowing half the air going thru the tb past the iat sensor.
Old 02-05-2013, 09:41 AM   #5589
simon021
Member#: 157532
2002 MY03 EJ207 E85
Last night I was looking through my box-o-stuff and came across my old tmic to throttle body silicon coupler that has my meth nozzle installed in it. Has anyone installed an iat sensor in the hose there like a meth nozzle? Seems like an easy way to get a sensor there without any permanent modification.
Thoughts?
Old 02-05-2013, 10:30 AM   #5590
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
No problem, enjoy your swap!
fastnoypi is offline   Reply With Quote
Old 02-05-2013, 11:24 AM   #5591
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Thank you for the detailed response. I read in a few in a few places the oem manifold mounted sensor was bad but no one could offer up a satisfying explanation as to why this was the case. I'll get the correct type of sensor and go that route.
I am curious though as to why you replaced the PCV valve connection on the manifold. Wouldn't you want to leave that intact to provide a strong vacuum to the crankcase?
Old 02-05-2013, 11:58 AM   #5592
Florin1
Member#: 163625
91 Legacy SS
So does anyone have a jdm V7/8 ecu they wanna sell? I figured I'd ask in here since this is where most of the 207 guys are, and nobody ever checks the WTB ads.
Florin1 is offline   Reply With Quote
Old 02-05-2013, 12:19 PM   #5593
rdieder
Member#: 257818
2007 STi
CGM
I think everyone in here is enjoying their swap to sell you one
You're better off contacting the vendors mentioned in this thread.
rdieder is offline   Reply With Quote
Old 02-05-2013, 01:17 PM   #5594
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
pm me
Nomadgene is offline   Reply With Quote
Old 02-05-2013, 02:14 PM   #5595
flath4
Member#: 331643
i agree with you on this one EJ207 Sub-Fourm
flath4 is offline   Reply With Quote
Old 02-05-2013, 02:32 PM   #5596
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
The PCV only works at negative relative manifold pressure so the only time it is really doing anything is idle and very light cruising to decrease emissions. All other times vacuum is sourced from the turbo inlet so I am fine with my crank being a slightly higher pressure at idle and low throttle cruise as long as I get good vacuum at WOT.
Old 02-05-2013, 03:22 PM   #5597
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Makes sense. I figured its effect during cruising might have been a little higher but maybe not.
Old 02-05-2013, 07:00 PM   #5598
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
Originally Posted by vogun16 View Post
Hey guys,
I just finished my swap and build! I have a V7 with GSC S2 cams and springs for the heads and a twinscroll GT3076 for a turbo. Hopefully I will have it tuned in a week or so after I break everything in. My only issue is tracking down why I have a P1306 cel (OCV open, passenger side) any suggestions? I know this corresponds to the solenoid but I am pretty sure of the wiring.
Figured out my issue and am hopefully going for a quick street tune this week!
vogun16 is offline   Reply With Quote
Old 02-05-2013, 08:50 PM   #5599
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Can you post how you figured out incase anyone else ever has a similar issue please.
I bet it was wiring related
Old 02-05-2013, 08:54 PM   #5600
vogun16
Member#: 93206
02 WRX....
The issue is that I have the TIC tgv deletes which then separate the grounds from the engine to the manifold. I ran a ground from the tower to the manifold and then to the head on that side.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
