Old 02-13-2013, 03:42 PM   #5676
WRick
Member#: 86107
You can flash it with the stock IAT ( keep the maf in place, and plugged ) and revert back so the wife can DD it.
Heck once you install the GM IAT, you still leave the maf there. Kind of practical for tuning anyway.
WRick is offline   Reply With Quote
Old 02-13-2013, 04:15 PM   #5677
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
It works pretty well with the IAT in the maf, just not perfect.
lukeskywrx is offline   Reply With Quote
Old 02-14-2013, 03:43 PM   #5678
Florin1
Member#: 163625
91 Legacy SS
So I have a question. To make avcs heads work, I need the heads, ecu and an ia performance wiring kit. Right? I emailed them today, and the sales department said I needed both of the harnesses. (bulkhead kit and avcs kit) that came out to $400. I thought I needed just the one harness... Was I misinformed?
my car is an 02 wrx ej205.
Florin1 is offline   Reply With Quote
Old 02-14-2013, 03:57 PM   #5679
xthecursex
Member#: 224079
You need complete heads with the oil lines cams ect. the jdm ecu.
and yes both harnesses. One is the engine harness(since you do not have a jdm one I assume) and the other is the ecu harness.
xthecursex is offline   Reply With Quote
Old 02-14-2013, 05:44 PM   #5680
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
if u get an engine harness from a jdm car which i reccomend you do then i make an alternativly cheaper avcs harness that uses the stock wrx wiring harness, jdm ecu, heads, and jdm engine harness.
WhiteBgeye02 is online now   Reply With Quote
Old 02-14-2013, 05:54 PM   #5681
Florin1
Member#: 163625
91 Legacy SS
I like where this is going.
Now where would I find, said harness?
Old 02-14-2013, 06:05 PM   #5682
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
ej207 engine partouts. theres one on here a time or two each month. if u get it let me know and i sell the avcs one for about 30% less than the other ppls.
Old 02-14-2013, 06:24 PM   #5683
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by WRXt4cy View Post
Thanks for sharing your knowledge and maps.
Perhaps I'm missing something, its early still, but it seems like you have too much resolution in the vacuum area of your AVCS maps.
Assuming your atmospheric pressure is somewhere around 14, you would only have about 4 columns of your map for positive relative pressure. You probably cruise at around 9 psi absolute so that would mean in your power avcs map, you cruise, spool and peak your boost @ 40* avcs. I don't think you'd spend much time if the first 4 columns of your map. They would seem to cover idle and just off idle. Is this correct or am I missing something?
You're mileage map example is closer to what I'm running now. I'm working up and down from around 20* avcs at cruise, ramping up quickly starting at loads around 1.2 then tapering down similar to what you have. This seems to have the best off boost response, best spool and great top end. I'm just trying to find the best cruise values now, mainly to maximize efficiency for road trips.
I did some experimenting last night. I used a pretty flat stretch of road with two small bridges at each end to use as start/end points. There was plenty of room to get my speed set coming from either direction. I tested each change in both directions and averaged the results. I tested four different cruise avcs values: 10, 20, 30 and 40. Timing was kept at 48*, average speed was kept at 62 mph, turning 2760 rpms in 6th with the JDM 6MT. I'm running E85 blended at 70% ethanol. My AFR at light cruise loads is 15.6 (gas scale).
10* showed the highest average IDC and lowest average mpg, about 17.7.
20* & 30* were pretty similar. 20 had a lower IDC but 30 showed a higher mpg, around 18.3
40* had a lower IDC than 10* but a lower mpg, around 17.5
I couldn't see any noticeable different in EGTs. They stayed at 1250* for all the tests.
My mpg values assumes that the romraider definition for fuel consumption is correct and that I have fairly accurately created my own formula to account for running E85.
I'm going to work a little more between 20* and 30* to see if I can find the lowest IDC and best mpg and then I will start working on timing at whatever avcs value seems best.
assuming this is true you used the mpg est given thru romraider or did exact fuel calculations?
Old 02-14-2013, 07:46 PM   #5684
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Averages are useless without standard deviations
Old 02-15-2013, 09:58 AM   #5685
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Hey guys- not really a 207 specific question but anyone with the single piece manifold - do you have an aftermarket turbo inlet? What is it and how does it fit? I'm having stupid issues getting the recirc hose in place.
Thanks!
Computersare8ad is offline   Reply With Quote
Old 02-15-2013, 10:07 AM   #5686
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
I got a Perrin full 3" inlet on mine and it fit perfectly fine for me....I also have 8mm phenolic spacers maybe that made the difference?
todeswalzer is offline   Reply With Quote
Old 02-15-2013, 11:04 AM   #5687
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Shut up, nerd.
Old 02-15-2013, 11:06 AM   #5688
kpluiten
Member#: 120273
06 WRBWRXWGN
Thanks!
I have a Perrin V1. It fits OK. Better than it did with TGV's. But still not great. Hardly any fit great though. This one fits as well as an eBay BPM unit for whatever that means.
Old 02-15-2013, 11:16 AM   #5689
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
I'm running the Gimmick piece - my problem is the recirc sits basically between the fuel rails and the manifold and doesn't come away far enough to be able to fit anything in there properly.
A quarter inch and it would be perfect...
Old 02-15-2013, 11:24 AM   #5690
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Gimmick
It seems I've found your problem
Old 02-15-2013, 11:43 AM   #5691
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Originally Posted by kpluiten View Post
Shut up, nerd.
He does have a point. Standard deviation on the mpg calculations was between .74 and .87; it was very flat stretch road so the the throttle deltas are very low.
I am just using the RR calculation but I created my own for running E85 to account for E85's different fuel density and to convert the gas AFR to E85 AFR so the correct parts of fuel to air is used. Its probably not perfect but it seems pretty close to what I average with mostly highway driving.
WRXt4cy is offline   Reply With Quote
Old 02-15-2013, 02:10 PM   #5692
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
I know this is petty but any way to get replacement timing belt engine code stickers?
iNfEk is offline   Reply With Quote
Old 02-15-2013, 02:11 PM   #5693
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
You get one with the Sti pink belt or with the JDM OEM belt.
Old 02-15-2013, 02:22 PM   #5694
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Not that one. The one on the center timing belt cover that says what kind of engine it is. For example EJ207DW3CR. Mine is coming off and needs replacing.
Old 02-15-2013, 05:19 PM   #5695
efiniluvr
Member#: 107170
2002 ver 7 EJ207 WRX
You get a free engine code sticker free with every purchase of another EJ207!!! Or the other way around, you get a free engine when you buy a JDM EJ207 timing belt cover. Sorry, couldn't resist.
efiniluvr is offline   Reply With Quote
Old 02-15-2013, 05:32 PM   #5696
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
LOL. funny. I have the actual code I just have to figure out how to make a sticker that'll stand up to washing and normal driving. LOL
Twin EJ207s in my Suby would be epic though
Old 02-15-2013, 05:48 PM   #5697
25rsti
Member#: 166324
Trying to get tuned now and it can reado both jdm and usdm ecus but can't write to them. Any ideas? So pissed.
Old 02-15-2013, 05:52 PM   #5698
RealDealTarheel
Member#: 142447
06 Outback
Any specific error code as to why it won't write?
RealDealTarheel is offline   Reply With Quote
Old 02-15-2013, 05:55 PM   #5699
25rsti
Member#: 166324
Something about the white conector with a red wire
Old 02-15-2013, 06:01 PM   #5700
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
You have the proper flash jumper for your chassis harness and your green connectors are not worn out.....Right?
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
