Old 02-15-2013, 06:03 PM   #5701
25rsti
Member#: 166324
Got it fixed, pins in the connector were loose. YIPPIE!
Old 02-15-2013, 06:59 PM   #5702
25rsti
Member#: 166324
Blllleeeeeeeeepppp
Think it just spun a bearing!!
Old 02-15-2013, 07:51 PM   #5703
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
todeswalzer is offline   Reply With Quote
Old 02-15-2013, 09:57 PM   #5704
25rsti
Member#: 166324
It doesn't sound that bad, but it makes a ticktickticktickticktickticktick sound
Old 02-15-2013, 10:34 PM   #5705
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Injector? Bucket?
Old 02-16-2013, 06:37 AM   #5706
25rsti
Member#: 166324
Old 02-16-2013, 09:09 AM   #5707
stlnation
Member#: 321805
2002 Jdm v9 STI
anyone use a Crawford water pump? i see their about the same price as a replacement 12mm jdm pump
stlnation is offline   Reply With Quote
Old 02-16-2013, 01:14 PM   #5708
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
The JDM oil pump is a 12mm unit, I am not aware of the water pumps being different diameters.
lukeskywrx is offline   Reply With Quote
Old 02-16-2013, 01:26 PM   #5709
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The regular water pump is the same and the spec c with oil radiator has the same part number for water pump as the GRB USDM WRX
Old 02-16-2013, 02:09 PM   #5710
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by lukeskywrx View Post
Averages are useless without standard deviations
i know but i said assuming they were correct. idc about std deviation. i took that math class. waste of time!
WhiteBgeye02 is offline   Reply With Quote
Old 02-16-2013, 02:12 PM   #5711
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by 25rsti View Post
time to pull it out and tear it apart. shoulda heard it when my friends ej257 bent a rod and it was slapping the counterweights on the crank. jackhammer affect at 7k rpms. 550whp will do that. i tuned it a bit too spicey!
Old 02-16-2013, 02:20 PM   #5712
johnfelstead
Member#: 856
2005 JDM STi
The JDM Impreza STi EJ207 oil pump is not 12mm, the 12mm pump is fitted to the JDM Twin Turbo Legacy, it uses the 12mm pump to flow enough oil to supply both turbos. The last thing you want is a larger than stock oil pump, all you will do is heat the oil up as it gets passed back through the PRV.
johnfelstead is offline   Reply With Quote
Old 02-16-2013, 03:40 PM   #5713
25rsti
Member#: 166324
I'm trying to weigh out my options on what to do to get it running again.
Any suggestions?
Old 02-16-2013, 04:11 PM   #5714
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Any suggestions?
well since you continued to run it there is metal in the entire engine now and probabl the turbo as well.
tear it down to get hot tanked and full cleaned.
go through the heads and check the scoring that probably happened in the cam journals esp the caps since they take most of the pressure.
get a shop or someone knowledgeable to inspect the crank journals as well as the bearing journals for proper seating.
depending on the cylinder walls get a quick hone job or bore it out.
order a new oil pump and oil cooler. they are full of metal shavings and need to hit the trash.
send your turbo to a shop to be rebuilt or back flushed for any metal shavings that got into it.
take apart the avcs solenoids and hope ours have the screens that caught the metal shavings that went into those. if not disassemble and clean out. check for any seals that will contact scored metal.
unfortunatly a spun bearing causes metal shavings to get into everything in a very short time.
Old 02-16-2013, 04:14 PM   #5715
25rsti
Member#: 166324
Yeah, That video was taken as soon as it happened. It was running perfectly fine and then that sound happened and I started recording and then shut down. Haven't turned it on since. I'm hoping the damage is as minimal as possible, obviously.
There aren't any screens in my solenoids either.
Old 02-16-2013, 04:17 PM   #5716
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
okay well you have one choice right now. take it out and tear it down inspecting everything under good light. also keep the head cam caps organized, they are bore matched for each one and mismatching them could lead to further problems. good luck and if in doubt make a thread int he ej205 forums with pictures if you need more feedback.
Old 02-16-2013, 04:27 PM   #5717
25rsti
Member#: 166324
Thanks. Really blows. I was so excited for nothing.
Old 02-16-2013, 04:44 PM   #5718
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
DOOOOOD, I told you that I would help you break it down and rebuild it.
vogun16 is offline   Reply With Quote
Old 02-18-2013, 01:59 AM   #5719
Modollenroc
Member#: 243499
I'm doing a v6 swap right now on my 01 rs and uhhhhh I need a crossmember. Does it need to be a v5/6 crossmember or just a turbo one ? I am also trying to use the sti aluminum axles that I was given
Modollenroc is offline   Reply With Quote
Old 02-18-2013, 08:09 AM   #5720
25rsti
Member#: 166324
Any 02-07 wrx/sti crossmember would work.
Old 02-18-2013, 04:00 PM   #5721
Modollenroc
Member#: 243499
What about sway bar? Do I have to use the JDM sway or can I just use my usdm one?
Old 02-18-2013, 04:04 PM   #5722
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
they are all the same^^ drivetrain thread buddy not ej207 thread.
Old 02-18-2013, 05:04 PM   #5723
sk8boylou
Member#: 246669
2002 V8 EJ207 6pd
Had a quick question about doing a complete v8 6spd swap with 5x114 hubs. I was told I will loose my abs if I keep my stock 02 wrx abs sensors with the 5x114 hubs. Also will I run into issues with my neutral saftey swich? I am running v8 ej207 with the v8 ecu in an 02 bugeye.
sk8boylou is offline   Reply With Quote
Old 02-18-2013, 05:15 PM   #5724
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
This is probably best placed in the Drivetrain subforum. We can answer it here, but it's not really having much to do with EJ207's directly.
Old 02-18-2013, 05:23 PM   #5725
sk8boylou
Member#: 246669
2002 V8 EJ207 6pd
im sure someone has done a full EJ207 swap and has ran into this issue..
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
