Old 03-01-2013, 10:44 AM   #5776
Lukas_vee23
Member#: 342863
Originally Posted by unkachabull View Post
Lol... Your welcome!
Really depends on what your goals are for the car... Mine is daily driven and its basically just bolt on mods tuned by STI Mikey and I love it. Running a v7. I don't plan on getting rid of the vf turbo but I beat the **** out of my car and have not had any problems since I swapped which was over a year ago.
Ahaa so your saying go with the v7 ej207. Alright but where would i be able to get one for a decent price and/or either new or not abused. And can all of the ej20 parts fit in the ej207 motor.
Aftermarket wise about the parts fitting
Lukas_vee23 is offline   Reply With Quote
Old 03-01-2013, 11:56 AM   #5777
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Do you really want to put a 10 year old used motor in your car? It could have been sitting in a junk yard next to the ocean for the better part of a decade.
As for part fitment, do some research.
lukeskywrx is offline   Reply With Quote
Old 03-01-2013, 03:58 PM   #5778
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
Hey guys, I am sure if it is covered somewhere in this thread, buy I need some gaskets for my JDM V8 motor.
Does anyone know which USDM seals will work as replacements for the V8 rear main seal and valve cover gaskets? If any?
Also, I heard that 05 USDM STi power steering hoses will work with the V8 JDM power steering pump. Can anyone verify that is the case?
Thanks,
teh chud
chudlo is offline   Reply With Quote
Old 03-01-2013, 07:36 PM   #5779
johnfelstead
Member#: 856
2005 JDM STi
Valve cover gaskets vary year to year, the crank seal is the same.
johnfelstead is offline   Reply With Quote
Old 03-01-2013, 10:25 PM   #5780
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
If anyone's interested. I bought the new longer bolt for my timing belt job for using the newer style bearing. Here is a comparison. Old vs New plus the new part number used for the grade 9 bolt
iNfEk is offline   Reply With Quote
Old 03-02-2013, 01:27 AM   #5781
navydub
Member#: 242585
2005 Saabaru
Hmmm I used the older bolt and the newer bearing. It reached the threads and torqued to spec fine, but now you have me wondering
navydub is offline   Reply With Quote
Old 03-02-2013, 01:34 AM   #5782
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
What was the torque specification? I don't believe there is one for this. I know the other bearings are 29 ft/lbs
Old 03-02-2013, 05:34 AM   #5783
stlnation
Member#: 321805
2002 Jdm v9 STI
So hopefully we haven't made a mistep but while installing timing belt and using a company23 camlock my helper couldnt quite get the belt notches to seat on the driver side lower cam gear. He had a wrench on the lock but I guess he didnt expect a huge amount of spring tension but needless to say when he loosened the lower lock the wrench shot out of his hand and hit me.
The avcs cam did not move. I was able by hand to rotate the driver side lower cam sprocket counterclockwise to reset to match marks.
Information is kind of spotty here... was any damage done?
stlnation is offline   Reply With Quote
Old 03-02-2013, 07:17 AM   #5784
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Well your upper intake cam needs to be turned clockwise. The lower exhaust cam needs to be turns counter clockwise to set the timing. There is bit of pressure. I used the cam locking tool BUT you need to make sure the connections are super tight or it'll get moved by the sprung tension of the cam. The intake cam will be exactly like the exhaust cam where it'll easily turn just before the cam lobe and then you'll need to fight that to keep everything together. I know my old WRX engine that didn't have AVCS didn't move and seemed to be ok but once I tried rotating it then it unsprung and then I could set the timing
Old 03-03-2013, 03:14 PM   #5785
stlnation
Member#: 321805
2002 Jdm v9 STI
My ej207 didn't come with a power steering pulley and is different than my ej205 pulley. Anybody know what I need to order?
Old 03-03-2013, 05:57 PM   #5786
Modollenroc
Member#: 243499
so the Guy who is installing my 207 swap into my GM said that there's some sort of metal or plastic clips missing that hold the axles in the differential. Does anyone know what he is talking about or where I can get them or if they're even necessary.
Modollenroc is offline   Reply With Quote
Old 03-03-2013, 06:05 PM   #5787
johnfelstead
Member#: 856
2005 JDM STi
Rear driveshafts lock into the diff unit with some steel snaprings, the snaprings are in the diff unit, they locate in a grove in the driveshaft.
Old 03-04-2013, 11:47 AM   #5788
stlnation
Member#: 321805
2002 Jdm v9 STI
Will a sti power steering pulley work?
Old 03-04-2013, 12:10 PM   #5789
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
theres one way to find out!
WhiteBgeye02 is offline   Reply With Quote
Old 03-04-2013, 05:56 PM   #5790
stlnation
Member#: 321805
2002 Jdm v9 STI
Found or I can't even order one from the dealer without ordering a whole power steering pump. Not what I want to do
Old 03-04-2013, 06:04 PM   #5791
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
You can try o'rileys or similar place for remanufactured or if you have the old engine take the pump and adapter and transfer it to the EJ207
Old 03-05-2013, 12:57 AM   #5792
Lukas_vee23
Member#: 342863
Got a point there. New the motors arent that much. Didnt realize that
Old 03-05-2013, 10:48 AM   #5793
stlnation
Member#: 321805
2002 Jdm v9 STI
Grrr. Im stuck. I just didn't the past 4 his trying to get my tranny to mate to my v9 motor. I got the studs about 3/4 the way in. Got 2 bolts 95% in the top, but, for the life of me they just will not mate.
Another problem I've run into is I have 4pins pulling out of the engine harness that was on my v9. They will not lock into place. ..
Old 03-05-2013, 11:13 AM   #5794
navydub
Member#: 242585
2005 Saabaru
DO NOT use bolt to try and force the block and trans together. If you get everything lined up the two will literally "pop" together and you can use the bolts to pull them the last cm or two. If the gap is still bigger than the width of your thumb or so without the bolts, things are not properly aligned. More than likely the input shaft on the trans lining up with the bearing on the flywheel.
Old 03-05-2013, 11:24 AM   #5795
stlnation
Member#: 321805
2002 Jdm v9 STI
Do I need the car in gear and to be spinning the crankshaft to get everything to line back up?
Old 03-05-2013, 11:36 AM   #5796
25rsti
Member#: 166324
No...
Old 03-05-2013, 11:43 AM   #5797
unkachabull
Member#: 241491
2005 wrx
v7 ej207- stimikey tuned
You could put it in gear and spin the output shaft in order to line the input shaft snout with the clutch.
unkachabull is offline   Reply With Quote
Old 03-05-2013, 08:42 PM   #5798
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
now that you forced it pull it off and make sure the alignment tool still slides into the clutch/pilot bearing easily.
Old 03-05-2013, 08:48 PM   #5799
stlnation
Member#: 321805
2002 Jdm v9 STI
Has anyone had pins that wont stay in their connector.
The brown plug that came on my v9 engibe harness has 4 loose pins.
They dont look damaged but refuse to stay in.
I installed the iap avcs harness no problem.
Anyone have this problem?
Old 03-05-2013, 09:28 PM   #5800
unkachabull
Member#: 241491
2005 wrx
Maybe your just sliding it into the connector housing in the wrong position? Also check the terminals to make sure that the little locks didn't break off or bend backwards.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
