Old 03-12-2013, 07:45 PM   #5876
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
turbo inlet is always a nice upgrade to help the vf37 flow as much as it can.
WhiteBgeye02 is offline   Reply With Quote
Old 03-12-2013, 08:18 PM   #5877
sube-trex
Member#: 97577
2001 IS 300
Originally Posted by Whoracle View Post
Well, my 205 had low compression which was diagnosed as a worn rod bearing and warped valves. $4500 to rebuild >.<. Decided to go with a 207, which should hopefully be done around April. This is right after it was just at the bodyshop for 2 months getting 6k worth of work done thanks to a truck reversing into my tail light in a parking lot.
Sure wish I didn't have to deal with CA smog. Also not interested in swapping the ECU's everytime I get smogged
sube-trex is offline   Reply With Quote
Old 03-12-2013, 08:45 PM   #5878
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Originally Posted by JulianDelphiki View Post
Awesome, now to decide which route to take with the twinscroll catless dp
Invidia catless DP, twinscroll flange from IA Performance, and a little welding.
Psychoreo is online now   Reply With Quote
Old 03-12-2013, 08:50 PM   #5879
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
I already have a catless ebay downpipe for my wrx. I was thinking a twinscroll dump tube is required because with just the flange being welded it would be extremely difficult with the opening differences between the td04 and twinscroll exhaust sides
JulianDelphiki is online now   Reply With Quote
Old 03-12-2013, 09:08 PM   #5880
Psychoreo
Member#: 79643
2015 WRX STI
I was talking to Pete at Efi LOGICS and they have done a couple set-ups like that. It does take some massaging, but it's doable. and then you have a USDM length twinscroll dp. it's the route I'll be going soonish.
Old 03-12-2013, 09:20 PM   #5881
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
I guess it depends on the confidence/ability of the welder. I imagine some slitting and 'massaging' is required. Lmk how it turns out.
Old 03-12-2013, 11:42 PM   #5882
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
I can see that being an issue if your current eBay one is a "blank plate" design... like the stock USDM one. But if it's a "bellmouth", I'd like to think it'll flow fine. I lucked out and got a JDM Syms Racing DP with my swap, and just happen to have a JDM length midpipe from a parts trade! Those two hooked up nicely to my Prodrive oval-tip axleback... making for a fairly quiet setup under 4k RPM. Here's a pic of of the DP inlet:
Torquey is online now   Reply With Quote
Old 03-12-2013, 11:57 PM   #5883
SubaruDood
Member#: 340058
I came across this discussion about twin scroll setups randomly. I'm wondering if anyone has tried the Kamak or Kinugawa twin scroll setup. I've been looking at the ones on www.steamspeed.com. I'm just curious since they seem to have such a good warranty and the pricing seems pretty good. Also, any suggestions on the downpipe solution I should try would be helpful. Thanks for all the good info so far!
SubaruDood is offline   Reply With Quote
Old 03-13-2013, 12:24 AM   #5884
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
I got a Tomei down pipe from eBay, $400 delivered, perfect fit, got excellent torque with it when tuned.
D-Rodman is offline   Reply With Quote
Old 03-13-2013, 12:26 AM   #5885
D-Rodman
Member#: 110078
05 saabaru artc gr
Yeah, lined up for immediate install I have(most are for longevity and reliability)..
Killer B oil pickup
Timing belt/idlers
Walboro fuel
Whitebugeye wiring harness
Turbo Inlet
Custom welded catless DP
K/N Typhoon
E-Tune
Hopefully around 290-300whp is attainable with a conservative tune
Get a 3 point electronic boost controller, you'll have full boost much earlier by about 500 rpm.
Old 03-13-2013, 12:43 AM   #5886
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Oh no, my SRS DP is definitely a bellmouth. Its just that the flanges are so different, one being an oval(td04) and the other being shaped more like a house if you will(twinscroll). And because the twinscroll is larger, just the flange can be difficult to weld.
Post a link if you could, I could not find a USDM length one on ebay.
Ive decided that that is the way to go. Read through this thread, Clark said it was a waste on the stock twinscroll but so many people have said otherwise and boost came on so much quicker on my sti with it.
Old 03-13-2013, 01:12 AM   #5887
D-Rodman
Member#: 110078
05 saabaru artc gr
Meh, I spoke to that Clark dude when I was getting started on my swap, I went to EFI logics and got a real tune. Was spoken to with respect and no attitude. The tuner at EFI asked if I had a 3 point boost controller, I told him I had it but had not installed it. Immediately he said to install it and he'd have my car boosting much Quicker. Other than the turbo back exhaust I also installed a Perrin turbo inlet and a walbro fuel pump, kept the stock air box. The car feels awesome, well worth the real tune money.
The Tomei down pipe I got is Jdm length, I just modified my intermediate pipe to reach the down pipe joint, no big deal. It's also a donut style, I wanted to keep the factory like setup. I have a borla hush catback, it's a slip over pipe setup, was very easy to extend and adjust to fit properly.
I agree with you that welding a twin scroll flange on to a usdm style bellmouth is not going to end up just right, it'll be a hack job. I've seen a Cobb somebody here modified, it wasn't good.
Old 03-13-2013, 07:18 AM   #5888
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Pete is always very helpful. I'm also very happy with my efi tune. Great shop
mrxr250rider is offline   Reply With Quote
Old 03-13-2013, 11:34 AM   #5889
unkachabull
Member#: 241491
2005 wrx
v7 ej207- stimikey tuned
Yep.. that's the one and only reason that I went with stimikey instead of Clark. Everytime I had a question he would be very rude and sometimes just completely ignore me. Also stimikey is now tuning for efi. I got his e-tune and my car feels great. Very happy with the results and he is a great person to work with! Only down side is no dyno numbers and we can't get the virtual dyno to work because it says there are missing columns. But we can't figure out why it won't read the columns.
unkachabull is offline   Reply With Quote
Old 03-13-2013, 01:33 PM   #5890
2JZ
Member#: 291949
Originally Posted by stlnation View Post
You will still need to get the jdm ecu tuned.
I bought the car swapped and tuned (jdm ecu)
2JZ is offline   Reply With Quote
Old 03-13-2013, 04:48 PM   #5891
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
send me the log from romraider and ill see if i can figure it out. i have had this problem in the past and figured it out. just will have to tinker with it..
agreed. Clark may be a wealth of knowledge but no one can say anything good about his attitude and customer service. I even contacted him via a different way so he wouldnt know it was me and came to the same point that basically I had no idea what I was talking about and my car will never run right how i tune. w/ 20 local subaru's running my tune and no complaints I can conclude I must be doing something right
stimikey and phatron are a very helpful and put out great tunes. both of which have given me free advice on how to improve my tune or how little they would change if I had them modify my current tune via etuning.
Old 03-13-2013, 04:53 PM   #5892
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Did this become the Clark hurt my feelings thread all of a sudden?
Keep all the good and bad in the vendor reviews area.
fastnoypi is offline   Reply With Quote
Old 03-13-2013, 05:02 PM   #5893
25rsti
Member#: 166324
I feel the same way.
Old 03-13-2013, 06:27 PM   #5894
stlnation
Member#: 321805
2002 Jdm v9 STI
Anyone else lose cruise? I'd I push the cruise dash Button it lights up but hitting the steering wheel control does nothing
stlnation is offline   Reply With Quote
Old 03-13-2013, 06:35 PM   #5895
unkachabull
Member#: 241491
2005 wrx
Nope. The only problem I have IA with my JDM instrument cluster the cruise light doesn't turn on but it will still function.
Old 03-13-2013, 06:59 PM   #5896
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Does your v9 throttle body have hook-up for the cruise cable? It works fine on my v8 swap, as the TB is identical to the WRX.
Old 03-13-2013, 07:03 PM   #5897
stlnation
Member#: 321805
2002 Jdm v9 STI
No it didn't. But I swapped my wrx throttle body on which does have it
Old 03-13-2013, 07:07 PM   #5898
Psychoreo
Member#: 79643
2015 WRX STI
Nope. The only problem I have with my JDM instrument cluster the cruise light doesn't turn on but it will still function.
Same here. Ver8 swapped.
Old 03-13-2013, 07:14 PM   #5899
stlnation
Member#: 321805
2002 Jdm v9 STI
What did you guys do about the ground that comes of the motor right by the turbo.
Old 03-13-2013, 07:25 PM   #5900
25rsti
Member#: 166324
I grounded mine.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
