Old 03-20-2013, 01:25 PM   #5951
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Originally Posted by WRick View Post
Morning ladies,
I have my heads apart ( 207 spec c's ) and a buddy gave me BC stainless exhaust valves. Should I stick to factory valves or replace with new BC stainless exaust ones ? They actually seem heavier ( the BC's ) and are flat instead of dome shaped.
imo i'd stay with the factory ex valves because they are sodium filled, they transfer heat better so valve guides don't get coked up.
If you are going +1 sized or have to replace a bunch of exhaust valves inconel is the way to go.
fastnoypi is offline   Reply With Quote
Old 03-20-2013, 02:13 PM   #5952
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
v9 is 06-07, right? Are these the same years that USDM cars had bearings with less lead and spun a bunch of bearings in the 2.5L turbos?
Could be a worldwide enviro-lead-reduction thing.
What oil were people running? I hope not xW30 energy conserving oil, then spinning 8k.
Concillian is offline   Reply With Quote
Old 03-20-2013, 02:17 PM   #5953
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
v9 was 05-06 for JDM, equivalent to USDM 06-07.
kayen is offline   Reply With Quote
Old 03-20-2013, 05:07 PM   #5954
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Originally Posted by fastnoypi View Post
copy your injector and fuel tables over on the usdm ecu and turn off all tgv related codes. It will be drivable but you will pass. If you come across fuel pump related CELs, you'll need to flash a different year usdm rom.
NJ inspection just looks for any cels and looks for specific obd2 feed back to pass. The JDM ecu does not reply back on a few tests that the state computer queries about which cause you to fail.
Sorry, I shoulda said I'm well aware of everything I will have to flash to make it pass. My only concern is: How many cars can one ECU go on? I can borrow one but I dont want the owner to be bricked outta his ECU after I do. Or if I buy a used one do I have to make sure its only been plugged into 1 car??
Old 03-20-2013, 05:51 PM   #5955
25rsti
Member#: 166324
No you can plug them into as many as you want. You do however want to make sure it's for your year, model and correct transmission (auto/manual) You can get other to work but getting to to fit your exact criteria would be best scenario.
Old 03-20-2013, 06:46 PM   #5956
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by 25rsti View Post
He spun a bearing.
wasnt me that spilt the beans now stl!
WhiteBgeye02 is offline   Reply With Quote
Old 03-20-2013, 07:09 PM   #5957
25rsti
Member#: 166324
Didn't think it was a secret if someone mentioned it before I did. Plus, what's the big deal? I spun my bearing a few weeks before he did. New crew!!!
Old 03-20-2013, 07:28 PM   #5958
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
My V8 comes in tomorrow. First I've got to replace/modify a few things(timing belt, broken cover, 3port bcs, dp, etc) but will need an etune next week until a tuner travels my way(FL) . Who is the recommended e-tuner for these ej207s?
JulianDelphiki is offline   Reply With Quote
Old 03-20-2013, 08:13 PM   #5959
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
stimikey should be your only option. i am in class. will get you tracking when i get home.^
Old 03-20-2013, 08:26 PM   #5960
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
That was who I was gonna go with(heard great things), if only I could get him to make a FL run again. No rush on the tracking, just wanted to know it shipped as my V8 comes in tomorrow and I want to complete the swap over the weekend.
Old 03-20-2013, 09:53 PM   #5961
Paul
Member#: 56203
00 RSTI Coupe
Thanks
Car is a 2000rs with V8 motor and V7 6-speed. I know I want a MT ecu but would a specific year be better?
Old 03-21-2013, 12:01 AM   #5962
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Also searching this thread and the engine management section, there is conflicting views. Can/has anyone used the Vag com cable to flash in an 02 with a V8? Ive been logging for years with it but cant use the AP anymore.
Old 03-21-2013, 07:10 AM   #5963
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Care to share details on your engine fail, how long did it run after install, what oil, any idea as to why it failed, was your car on an e tune ?
D-Rodman is offline   Reply With Quote
Old 03-21-2013, 07:25 AM   #5964
25rsti
Member#: 166324
I only drove it just under 100 miles. A little over 80 of those miles was my commute to the tuner. Two pulls on the dyno and then in between the 2nd and 3rd pull on idle the 'tick' emerged. We quickly shut her down. Fortunately for me, the damage stayed at the block. Heads were perfect when I opened everything up.
I was running Castrol Sythentic blend I forget the weight right now. I was unable to find any T6 locally till after my engine failed
On the total 100 miles I drove her I baby shifted and never past 3300rpms. All on the jdm ecu. I put 5 gallons of 110 octane for the first start up and 20 miles. When I was going down for the tune I filled up with Sunoco 93.
Old 03-21-2013, 08:41 AM   #5965
D-Rodman
Member#: 110078
05 saabaru artc gr
Thanks for the info, sorry to hear, guess you are rebuilding it. Did you find the engine was clean inside like it was well taken care of by the previous owner ? I was terrified my engine would also die on the EFI logics dyno when it was getting tuned. I now realize they flash a safe baseline tune before they start pushing the motor. I guess anything is possible despite all the best efforts to avoid issues and things do go wrong at times with this old engines. The best of luck to you sir.
Old 03-21-2013, 09:00 AM   #5966
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I think there could be another common variable here
I think the oil pickup that is used on version 8/9 jdm motors is the same part code for the one on usdm Sti motors.
During the shipping process it could cause more strain on the oil pickup possibly leading to a failure when the motor starts to be tuned.
Just a random idea I had at work.
Gigs90 is offline   Reply With Quote
Old 03-21-2013, 09:05 AM   #5967
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
It is the same part. The pickup tube(killer b) should be on everyone's initial replacement list along with the timing belt.
Old 03-21-2013, 01:48 PM   #5968
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Installing my killer b oil pickup, or attempting to and once I removed the manifold noticed that there is some liquid in the header in the back two cylinders. Maybe bad valve seals, maybe cleaning solution got in there thru a leak, maybe the vendor poured oil in the back two to make the compression test come out a little better.....How alarmed should I be?
Old 03-21-2013, 02:03 PM   #5969
WRick
Member#: 86107
it looks like it's coming from the head gasket...
WRick is offline   Reply With Quote
Old 03-21-2013, 02:12 PM   #5970
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
It wasn't the 06-07's that spun all the bearings right away. It was the 2009 WRX's.
Old 03-21-2013, 02:15 PM   #5971
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
I actually see the oil/liquid in the head on the valves. I tried to take a pic but it comes up crappy .
Old 03-21-2013, 05:07 PM   #5972
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Ok, checked/changed the plugs and the same two cylinders that had oil in the exhaust had oil on the plugs. Im guessing valve stem seals. Not a huge deal, hopefully. Pic, front(go on the back of the motor) two plugs have oil on the business end.
Old 03-21-2013, 06:33 PM   #5973
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well there is one way to see, throw it together and see what happens. since most vendors offer a 30 day warrantee get it in the car and run it asap. if there is something wrong you are then within the time period to get
Old 03-21-2013, 06:45 PM   #5974
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
My vendor offered a 60 day. I'm going to do the timing belt and then throw it in.
Old 03-21-2013, 08:12 PM   #5975
eqlized_aero
Member#: 88699
2015 TS EFR7163 818S
V9 Spec C Type RA 92x
Here is an example twin scroll downpipe jig using some scrap wood. It's based off of a V9 downpipe (USDM length) and makes it very easy to build a 3" downpipe with the ebay stainless elbow.
eqlized_aero is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
