Old 03-24-2013, 06:03 PM   #6026
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Should work fine both the 05 sti tranny and v8 ecu are inverted, you can log avcs advance using romraider and a tactrix cable or your tuner should confirm it is working before tuning.
Originally Posted by Dirtyhobo010 View Post
I have a quick question about the NPS and avcs.
Car: 02 wrx Transmission: 05 usdm sti 6 speed Engine: V8 ej207 w/ twinscroll Ecu: jdm v8 ecu with IAP wiring harness kit.
Question 1: Currently my NPS shows 1 in Neutral and 0 in other gears. Do I need to have this inverted for my avcs to work?
Question 2: Is there a way for me to log to be able to tell if avcs is functioning properly?
Thanks for any help. It is much appreciated.
lukeskywrx is offline   Reply With Quote
Old 03-24-2013, 06:44 PM   #6027
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Just run the carberry rom and SD. u can switch maps with the push of your defrost button or external switch! pretty sure it includes timing and fueling changes via the switch. Ecutek is horrible. No way to help u unless one of us has the program to look at it. they do make a 8cm hotside for the dom1.5xtr.
WhiteBgeye02 is offline   Reply With Quote
Old 03-24-2013, 06:46 PM   #6028
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Originally Posted by JulianDelphiki View Post
For future reference as well as my peace of mind, this is the IAT plug on V8s that needs to be unplugged correct?
Correct.
Psychoreo is offline   Reply With Quote
Old 03-24-2013, 06:57 PM   #6029
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
But do they make the 8cm housing in twin scroll?
The single scroll is 8 or 10 cm
Old 03-24-2013, 08:35 PM   #6030
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Originally Posted by Psychoreo View Post
Correct.
Why does it need to be unplugged? Mine seems to be running fine with it plugged in.
Dirtyhobo010 is offline   Reply With Quote
Old 03-24-2013, 09:35 PM   #6031
Psychoreo
Member#: 79643
2015 WRX STI
It throws a code when it's plugged in on the JDM ecu with WRX harness.
Old 03-24-2013, 09:39 PM   #6032
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
hmm... I will have to look into that. I havn't pulled the codes for my CEL light yet since I figured it was just o2 sensor.
Old 03-24-2013, 09:42 PM   #6033
Psychoreo
Member#: 79643
2015 WRX STI
"Running fine" but has a CEL?
Old 03-24-2013, 09:45 PM   #6034
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
I guess a rear o2 sensor being unplugged would cause my car to run horribly wrong. I better run out and get that fixed immediately......
It seems like it'd be easy enough to shut off the CEL in ecuflash.
Old 03-24-2013, 09:56 PM   #6035
25rsti
Member#: 166324
Plug the rear o2 back in. Don't clear the code.
Old 03-24-2013, 10:00 PM   #6036
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
You don't need the rear O2 sensor on the 16 bit cars, it is not involved in fueling at all, just emissions. The 32 bit cars use the rear sensor for some fueling corrections, and unplugging it causes issues.
I haven't had one on my car for 6 years, no problems. Just turn off the rear O2 codes
Old 03-24-2013, 10:05 PM   #6037
25rsti
Member#: 166324
Ok, Just going by what I've read in multiple previous pages. No biggie. Duly noted.
Old 03-24-2013, 10:10 PM   #6038
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
I was talking about the code for the temp sensor being plugged in under the manifold.
Old 03-24-2013, 10:20 PM   #6039
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
if u pull LV the cel for the IAT sensor that is plugged in wont show up. its a fantom cel that appears but the ecu wont tell u what it is. I had this problem until someone on here posted 150 pages ago that it wont show up. so i unplugged it and bam. no more cel.
as far as the rear 02. ditch it. some guys use that bung for there wideband then.
Old 03-24-2013, 10:26 PM   #6040
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Thanks for the clear explanation. It seems like there should be a better place for EJ207 owners than just 1 thread that never ends.
Old 03-24-2013, 10:38 PM   #6041
stlnation
Member#: 321805
2002 Jdm v9 STI
No kidding. Its a joke to search a 500 page thread.
stlnation is offline   Reply With Quote
Old 03-24-2013, 10:53 PM   #6042
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well there is the ej207 info page but i use google.com/advanced_search to find stuff easier on any website. use nasioc.com as the domain and just type what u want in the search part on top.
Old 03-25-2013, 08:57 AM   #6043
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I have a different opinion about the rear O2 sensor.
I have done that research long time ago and did not keep records, so won't be able to go into many details at this point, but:
There are 3 categories of rear O2 sensor situations:
16bit WRX before '04, where it seems that it was confirmed that the rear '02 won't do much
16 bit '04-'07, where there was something about how not all the tables for that were available in Romraider and a conclusion about how it does nothing was rushed and shown to be not quite the case.
32 bit, where it has to do with fuel trims.
One thing that I recall a bit more clearly is that the part numbers for the rear O2 sensor changed.
Then there was something about the readings from the rear O2 and what they should be, which I recall was answered (probably can be found in a 2002 WRX manual since the part number for the JDM is the same with that).
Old 03-25-2013, 10:04 AM   #6044
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i do have to agree about the 32 bit tables and fueling. I recently tuned a 2012 wrx and the cruising afrs started to go wacky into the 13's and then back up. then it threw a code for the rear o2 sensor slow response. he put a new sensor in it and fueling was spot on again for cruising. i trust my wideband before a stock sensor anyways so for now i think i will leave the rear o2 in 16bit ecus as useless.
Old 03-25-2013, 10:50 AM   #6045
Klear
Member#: 312980
Unfortunately I am already EKUTEK'd and near as I can tell the 16-bit ECU cannot be unECUTEK'd. So my biggest worry is that I am going to have to switch the turbo. Can anyone with ECUTEK tune my ECU or am I locked into only the person who did it originally? FWIW I had no idea that ECUTEK would brick my ECU and it was not disclosed when the conversation was happening.
Klear is offline   Reply With Quote
Old 03-25-2013, 11:39 AM   #6046
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Which ecu are you running? If its just a usdm ecu it should be easy to find a replacement for a pretty good price.
Old 03-25-2013, 12:04 PM   #6047
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
It should read 0 in gear and 1 in neutral. Posted that about a 100 pages back... This thread is such a mess.LOL
Originally Posted by lil'redwagon View Post
i used to. i had to mess with the temp comp tables. i don't remember what the table was called, but it was a table that had coolant temp and an enrichment value.
Thanks Ill take a look. If you remember please post up
Mine has some hesitation on starting in the cold (around 30 degrees (E85)) and I idle around 900 when up to temp.
My dies...not a hesitation. Does it when its 50 out on pump gas.
Old 03-25-2013, 12:05 PM   #6048
Klear
Member#: 312980
Matching V7 JDM ECU
Old 03-25-2013, 01:29 PM   #6049
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Matching V7 JDM ECU
The ecu can be reverted back to stock by an ECUtek dealer
Old 03-25-2013, 01:40 PM   #6050
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
is this true now? last i read it was not possible with the early 16bits ecus.
Here is some correspondence from Ecutek in an older thread.
http://forums.nasioc.com/forums/show...5&postcount=20
fastnoypi is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
