Old 04-01-2013, 05:38 PM   #6126
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Originally Posted by JulianDelphiki View Post
Whats BS is that I have to either pay 900$ for a twinscroll Dp or wait 2 weeks for a 500$ one. That is upsetting. Im this close to taking the stock jdm dp and this crappy hks usdm dp and having a shop hack something up. That approach will most likely lead to the angles being off and it wont bolt up properly but Im going to run the risk.
Efi has done this using the IA performance flange and invidia dp's a hand full of times. Works well
Psychoreo is offline   Reply With Quote
Old 04-01-2013, 05:46 PM   #6127
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Im just impatient. Also 500$ for some pipe is unbelievable. Supply and demand is a mofo.
JulianDelphiki is offline   Reply With Quote
Old 04-01-2013, 05:46 PM   #6128
stlnation
Member#: 321805
2002 Jdm v9 STI
When I ordered my motor I asked for a dp that matched my wrx exhaust. Got a v9 motor and the dp booked right up
stlnation is offline   Reply With Quote
Old 04-01-2013, 05:52 PM   #6129
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
It can be had a little cheaper than that if you shop around and get price matched. I paid $450 shipped.
I think that's a reasonable price to pay for a quality made DP that is the proper size and fitment for a setup that is not even OEM (TS turbo + USDM catback).
WRXt4cy is offline   Reply With Quote
Old 04-01-2013, 06:01 PM   #6130
Psychoreo
Member#: 79643
2015 WRX STI
Stock or aftermarket? Mine came with the catted stocker
Old 04-01-2013, 06:57 PM   #6131
stlnation
Member#: 321805
2002 Jdm v9 STI
Stock downpipe with and cat. It also has a square looking cat at the end of the dp. Fits perfect I was so happy I didnt have to deal with the dp issue others do
Old 04-01-2013, 07:04 PM   #6132
25rsti
Member#: 166324
V9 downpipes are USDM length.
Old 04-01-2013, 07:14 PM   #6133
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Mine came with a catted stocker too. Heres the plan though, I have a HKS flat face crap DP(3in ID) laying around and I just finished hacking the JDM stocker(its 2.5in ID). Im no metallurgist, will these two metals weld nicely? If so, Im off to find a competent welder. Pics of the 'hack job'
Old 04-01-2013, 09:27 PM   #6134
25rsti
Member#: 166324
I need a V7, V8 or Spec C V9 ecu!!!
Old 04-01-2013, 09:34 PM   #6135
amroof
Member#: 211224
2005 Saabaru
Who knows
Well my hodge podge bs 207 is now running. Must have unicorn blood or something seeing its the second one.
amroof is offline   Reply With Quote
Old 04-01-2013, 09:37 PM   #6136
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
u can buy a jdm style upper 1 ft of a downpipe off ebay for like 90 dollars. thats what i did. if the elbow is bolted up and the rest of the exh is a shop shoudl be able to get it pretty darn close. we got mine laying under a car on jackstands tacked up in 20 min and it works great. its 3" too. no reason to pay someone 500 dollars for a damn down pipe. waste of money!
WhiteBgeye02 is offline   Reply With Quote
Old 04-01-2013, 09:47 PM   #6137
RealDealTarheel
Member#: 142447
**** Texas
So I take it that there's already cheap down pipe options for anyone who has a JDM length exhaust already?
RealDealTarheel is offline   Reply With Quote
Old 04-01-2013, 09:57 PM   #6138
navydub
Member#: 242585
2005 Saabaru
Agreed.
I'm running this thing mated to a 3" USDM downpipe at the flange.
http://www.avoturboworld.com/avoshop...roll-p-10.html
Granted, I bought it used. Someone else did all the hard work!
navydub is offline   Reply With Quote
Old 04-01-2013, 09:59 PM   #6139
stlnation
Member#: 321805
2002 Jdm v9 STI
You could order aftermarket used dp from a importing company. Or order new from any jdm company
Old 04-02-2013, 02:12 AM   #6140
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Where did you get that sexy DBC manifold to DBW throttle body adapter plate? Is that custom? Whoever designed that must be a genius.
PM me if anyone needs one of these throttle body adapter setups or adapters for USDM rails to JDM manifold.
Old 04-02-2013, 02:18 AM   #6141
kpluiten
Member#: 120273
06 WRBWRXWGN
This. And then this again. It's the easiest and cheapest option and I have no clue why everyone chooses more expensive options and acts like the downpipes are impossible to make/find.
The formula is deal simple!
1) Buy Kinugawa/Tamak twinscroll bellmouth piece on eBay for $100
2) Use old USDM catless aftermarket DP or order an el cheap unit off ebay
3) Take the two to any semi-competent welder/exhaust shop and have the put the two together for $30-50.
4) ????
5) Profit.
Old 04-02-2013, 06:42 AM   #6142
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Because it is a "hack job" when you cut pipes up and weld them together. We all know that when you buy a nice expensive downpipe it was CNCd from a single pristine block of stainless steel forged billet designed using CAD.
I mean what kind of idiot would pay 200$ for some SS tube and a flange that are just hacked together using a TIG welder operated by a mere mortal. Sure it works the exact same but that's not the point.
lukeskywrx is offline   Reply With Quote
Old 04-02-2013, 06:45 AM   #6143
25rsti
Member#: 166324
Anyone have a jdm ecu for sale?
Old 04-02-2013, 07:28 AM   #6144
Modollenroc
Member#: 243499
I'm sure this has been covered over 9000 times already but this weekend my version 6 207 swap will be done in my gc using the power fc as its ECU. The mechanic won't be able to get it tuned by this weekend and I am in dire need of transportation at this moment. How do I go about getting it to run without worrying about detonation? Or am I just going to have to suck it up,wait, and get a rental?
Modollenroc is offline   Reply With Quote
Old 04-02-2013, 07:46 AM   #6145
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
no tmic, no fmic..i call wizardry!
fastnoypi is offline   Reply With Quote
Old 04-02-2013, 08:04 AM   #6146
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Mere mortal. Lol.
Old 04-02-2013, 08:55 AM   #6147
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
4) ????
5) Profit.
The casting has real thick walls at the lower end and necks down to below 2.6" inner diameter. So i cut it to the oval section and the circular equivalent diameter of the oval crossection rose to 2.7"
The cheapest ebay downpipe does not have the mounting bracket/ear in the horizontal section. I found that out the hard way. I bought an OEM bracket to weld it there, but my total price grew from around $90 to 110-120 for the downpipe and the bracket with shipping for both.
Most ebay 3" downpipes are 3" outer diameter. The one I got (cheapest), was around 2.7" inner diameter.
The bellmouth was welded into the oval pipe section so I was able to fit the Kinugawa bellmouth after quite some time hammering and busting my knuckles (i felt it was a constatnt reminder about working with stainless).
I don't recall the Kinugawa coming with any gasket, I think I bought a gasket and they don't sell just the one by the turbo, but a kit of two, whichever the second might be.
My rule of thumb is that you can re-use gaskets in the low-pressure section (after the turbo), but only if neither of the two components is replaced (meaning neither the turbo, nor the downpipe in this case).
IAP sells OEM and individual, best quality, but you get one for the price of two.
Now upto 150
Now keep in mind, with each step there is shipping and sometimes even tax.
Now I realized I did not have enough bungs. There is the one in the Kinugawa for the front TS OEM O2 sensor and the one in the ebay at the bottom for the rear O2 sensor.
I bought a S/S bung for my wideband
Now upto 180
I don't have in-house welding and spent quite some time finding someone willing to give a shot welding stainless.
Finally a guy from Midas told me to come in the weekend.
Let's add the Kinugawa bellmouth price at this point
$ 120+ shipping, let's call it $150.
Now upto $330
Now, in preparation for Midas, I had to mock up the misc segments.
I used steel weld, my favorite. 1 tube is around $10, I think.
Now upto $340
Midas did the welding for only $30, huge surprise for me, but left some pores in there, probably to make sure I come back...
Now upto $370
Add some consumables, such as a box of dremel cutting wheels and a set of stainless cuting blades for sawzall, I found that one blade was good for 1.5 cuts, meaning I had to go to the next blade at the second cut. And this had nothing to do with cutting the 2mm thick cast stainless of the Kinugawa, that's where the abrasive discs went.
Roughly $400 ...
At this point, I mocked up everything on my car and ...... It fit !!!!!!
Make no mistake, the 3D orientation of the bellmouth vs the rest of the downpipe is not that easy, I had to go under the car at least 3 times, to get the incline of the downpipe vs the incline of the bellmouth right, so I had every reason to open a bottle of Warsteiner when I saw that it fits..
Then I decided that I wanted to make it into a catalized pipe with a high flow metal substrate, cut the pipe wrong for the converter and shelved the project...
Old 04-02-2013, 09:00 AM   #6148
25rsti
Member#: 166324
Oh jeez. Sounds like a good experience. Save time, hassle and runarounds and buy something that's quality and known to fit. Unless of course you can do everything on your own with the tools and time.
Old 04-02-2013, 10:16 AM   #6149
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Lets see the welding job you did on your down pipe master lukesky, show us your work, pictures please.
D-Rodman is online now   Reply With Quote
Old 04-02-2013, 11:51 AM   #6150
25rsti
Member#: 166324
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
