Old 04-02-2013, 12:56 PM   #6151
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Originally Posted by 25rsti View Post
$535 plus shipping and service fee
Psychoreo is offline   Reply With Quote
Old 04-02-2013, 12:59 PM   #6152
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Originally Posted by D-Rodman View Post
Lets see the welding job you did on your down pipe master lukesky, show us your work, pictures please.
I didn't want to be waiting on my swap so I took the middle of the road approach to minimize down time on my DD
For the fastest install:
Buy this - http://www.ebay.com/itm/Kinugawa-Tur...2273c9&vxp=mtr
Buy a V-band
weld into existing system, this was done with a gasless MIG in my garage by mystical unicorn wrangler Amroof. it also appears my rear main tranny seal is leaking too, LOL.
lukeskywrx is offline   Reply With Quote
Old 04-02-2013, 01:03 PM   #6153
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Old 04-02-2013, 01:23 PM   #6154
White out
Member#: 46277
** LP640
Viper GTS
Does anyone know if the cam gears are the same on a ej207 as a variable intake ej257?
White out is offline   Reply With Quote
Old 04-02-2013, 01:23 PM   #6155
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
Translator....... Anyone?
SubieSnacks02 is offline   Reply With Quote
Old 04-02-2013, 01:25 PM   #6156
25rsti
Member#: 166324
It's an aftermarket Sard Catted downpipe.
Old 04-02-2013, 01:28 PM   #6157
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
Originally Posted by Modollenroc View Post
I'm sure this has been covered over 9000 times already but this weekend my version 6 207 swap will be done in my gc using the power fc as its ECU. The mechanic won't be able to get it tuned by this weekend and I am in dire need of transportation at this moment. How do I go about getting it to run without worrying about detonation? Or am I just going to have to suck it up,wait, and get a rental?
does the power fc have any tune on it at all? if it has a stock jdm rom, just put race gas in it and drive it gently. if it doesn't have anything at all, get a rental.
lil'redwagon is offline   Reply With Quote
Old 04-02-2013, 01:29 PM   #6158
Psychoreo
Member#: 79643
2015 WRX STI
It's a downpipe that's $535+
Old 04-02-2013, 01:40 PM   #6159
25rsti
Member#: 166324
Does anyone have any leads on a jdm ecu to help me out?
Old 04-02-2013, 04:33 PM   #6160
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
The 207 can handle ~45 of advance but the 257 are mechanically limited to ~30 so no they are not the same.
There has also been no confirmation that the 257 cam gear can trigger the cam sensor on the front of the driver side head that is on the 207.
Old 04-02-2013, 04:46 PM   #6161
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Buy a V-band
Thanks for the pic master lukesky, that is not the same as what was been discussed as you know. I'd like to se a picture of the welding job up at the turbo flange that combines a usdm bellmouth with a twin scroll flange. A Franken down pipe if you will, that would be relevant to the conversation. I also had made an extension to use a Jdm length down pipe work with a usdm axleback, much less complicated than up at the turbo flange.
D-Rodman is offline   Reply With Quote
Old 04-02-2013, 04:54 PM   #6162
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Photobucket is down right now, but I just got my Franken DP back from the welder and installed. I cut the stock V8 DP at the cat and had it welded on to the HKS DP I had laying around. I will post pics later. You can see the start of the job a few posts up(post #6133).
It cost me a total of 40$. Yes $40.
JulianDelphiki is offline   Reply With Quote
Old 04-02-2013, 05:15 PM   #6163
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Buy a V-band
of the driveshaft is not in all the way
WhiteBgeye02 is offline   Reply With Quote
Old 04-02-2013, 05:17 PM   #6164
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
didnt u just sell the one that came with the engine that died?
Old 04-02-2013, 05:19 PM   #6165
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Here you go D-Rodman. Pics of the 40$ twinscroll bellmouth....Uploaded to imageshack.....Its fairly self explanatory how I did this. Cut the stocker at the cat then used a steel slab and clamps as a makeshift jig and cut/marked accordingly. I used the Ej205 DP as a guide. Where I screwed up was having them weld it all the way around instead of just tacking it and checking the results. I had to saw the weld and move the dp to the left a fair amount but they re-welded it for free. The welding isnt show quality but with a heat shield it wont matter. Plus all this is in my 97 OBS that has a green engine bay and dark grey paint job. Function over form.
Old 04-02-2013, 05:24 PM   #6166
25rsti
Member#: 166324
Yup, and now the vendors selling V9s don't part with other motors ecus I ordered another V9 today. Hoping this one will end up better than the last.
Old 04-02-2013, 05:25 PM   #6167
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
and to think you could have been a dumbass and spent 500 dollars lol^ a little time and you saved yourself enough money to buy some larger injectors to go e85!
Old 04-02-2013, 05:26 PM   #6168
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yeah and ur v9 ecu coming might not even work if its an immobilizer one. have fun with that mess. i got one extra jdm ecu but i wont sell it since i might need it in an emergency during a bad flash or computercrash or something dumb.
Old 04-02-2013, 05:28 PM   #6169
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
I spent a 1/12th of the amount tomioka charges. Granted it is not a divorced or SUS, but it serves its purpose. I really need a tune though. Sitting in the driveway and turning the wheel making vroom-vroom noises is getting old.
Old 04-02-2013, 05:28 PM   #6170
25rsti
Member#: 166324
Yeah mine is 100% immobilized. S2 AL300. I had a V7 ecu lined up to buy today 30mins north from me and the seller sold it last night.
Old 04-02-2013, 05:58 PM   #6171
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well then tell them u want part of your money back since the auction doesnt include the ecu. or keep making them send you one back and forth until its right. if they dont call them out on here so ppl stop buying from them.
Old 04-02-2013, 11:27 PM   #6172
stlnation
Member#: 321805
2002 Jdm v9 STI
Over kill lol. Alot of japan yahoo auction people dont speak english and wont ship to US.
Try
Rhdjapan or nengun. Greddy also has a importing service for pretty much everything
stlnation is offline   Reply With Quote
Old 04-02-2013, 11:30 PM   #6173
stlnation
Member#: 321805
2002 Jdm v9 STI
Why don't all you people "needing" a downpipe solution just buy a high flow cat and bolt it in. The gap is for a cat anyways.
Old 04-02-2013, 11:45 PM   #6174
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
**** by the time they pay for a downpipe they coudl get a cheapo flux core welder and spend some time learning to weld and do it themselves!
Old 04-03-2013, 12:00 AM   #6175
stlnation
Member#: 321805
2002 Jdm v9 STI
Sure. I'm more of a purchase performance parts kind of guy as opposed to making them myself
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
