Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-10-2013, 07:42 PM   #6301
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
notice any ticking at cold starts? my header to up pipe leak was small at first from the previous owner. really only noticeable on cold start up. now its bad and can be heard all the time.
i had it tuned with the leak,i never had any complaints but id say i lost some spool because of it and now it just sucks
edit: just looked at a log on efi's data base. i also hit full boost at 4k(prob due to header to up pipe leak). still made good numbers on 18psi. 298/264. my most recent log isnt on there from when i was retuned for 21psi but it put down 310/288.
mrxr250rider is offline   Reply With Quote
Old 04-10-2013, 08:53 PM   #6302
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
took the uppipe header and dp off. Didnt look like it was leaking(no soot on gaskets) and took the heatshields off(screw you subaru). Now to find some decent replacement gaskets
JulianDelphiki is offline   Reply With Quote
Old 04-10-2013, 11:46 PM   #6303
Whoracle
Member#: 301075
2003 Impreza WRX
Just picked up my bugeye from the mechanic, the 207 is amazing! I was wondering what people are using to replace their splitter/bellows or did you all just modify the stock one?
Whoracle is offline   Reply With Quote
Old 04-11-2013, 07:09 AM   #6304
25rsti
Member#: 166324
I have a JDM splitter and JDM hood scoop.
Old 04-11-2013, 07:38 AM   #6305
Mountain
Member#: 331271
03 WRX
JDM splitter and scoop is the only way to go
Mountain is offline   Reply With Quote
Old 04-11-2013, 09:40 AM   #6306
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
JDM scoop, USDM GRB intercooler, splitter/bellows made by me, using Subaru parts.
The JDM scoop compleetly feeds the GRB intercooler, with no room for louvers for the top of the turbo.
Old 04-11-2013, 01:28 PM   #6307
kyle.hoyer
Member#: 327892
01/2 RS, WRX, STI
BRP, PSM, SWP
That's interesting reading about to guys only hitting full boost at around 4. I have a V7 with 18g and don't hit full boost (18psi) until like 4. That should be normal right? You have me worried about leaks now and missing out on quicker spool
kyle.hoyer is offline   Reply With Quote
Old 04-11-2013, 07:00 PM   #6308
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
I took both heat shields off and seafoamed the bov vac line looking for leaks in the uppipe/header, none were found.
Here is a log to 5.5k. Full boost at 4.1k. AVCS appears to be working correctly also. Lmk
https://docs.google.com/spreadsheet/...UE&usp=sharing
Old 04-11-2013, 07:16 PM   #6309
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Whitebugeye. What does wgdc have to do with it? I have an adjustable waste gate actuator. It's set to 18psi. Would that cause a slower spool?
Old 04-11-2013, 07:41 PM   #6310
25rsti
Member#: 166324
Do any of you guys have any compressor surge?
Old 04-11-2013, 07:52 PM   #6311
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
I get some flutter when letting off the throttle in certain driving situations that some may call compressor surge.
Stock jdm bpv
Psychoreo is offline   Reply With Quote
Old 04-11-2013, 07:53 PM   #6312
25rsti
Member#: 166324
Same here. Trying to understand why, and maybe, fix?
Old 04-11-2013, 07:58 PM   #6313
Psychoreo
Member#: 79643
2015 WRX STI
Mine only seems to happen at higher boost/half throttle situations when I let off the throttle. It's not hurting anything so I don't worry about it.
Old 04-11-2013, 08:08 PM   #6314
25rsti
Member#: 166324
I've read that compressor surge is bad on journal bearing turbos like my VF37.
Old 04-11-2013, 08:10 PM   #6315
Psychoreo
Member#: 79643
2015 WRX STI
Real compressor surge or that little flutter?
Sure, it's not good. But it's not going to explode tomorrow. How often does it do it?
Old 04-11-2013, 08:14 PM   #6316
25rsti
Member#: 166324
Well, my car's down right now for wheel bearings so I haven't driven it 20 miles yet but it sounds like the same as your situation. So, not often.
Old 04-11-2013, 08:22 PM   #6317
Psychoreo
Member#: 79643
2015 WRX STI
I'd worry about other things then
Old 04-11-2013, 08:25 PM   #6318
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I think it happens to any wrx with a bpv in that situation. Not something to worry about.
Old 04-11-2013, 08:42 PM   #6319
25rsti
Member#: 166324
Hm, I thought it was any wrx/sti with a bov and the bpv cured it. Ah well, I guess if it's a normal thing with the 207 crowd I won't worry too much about it.
Old 04-11-2013, 08:55 PM   #6320
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I thought it was the other way around actually lol.
Old 04-11-2013, 08:58 PM   #6321
25rsti
Member#: 166324
Do you have the same symptoms?
Old 04-11-2013, 09:00 PM   #6322
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Yes with forge bpv. I just try to stay out of boost partial throttle unless its low boost
Old 04-11-2013, 09:10 PM   #6323
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well r u shooting for 18psi then? whats ur boost control setup?
WhiteBgeye02 is offline   Reply With Quote
Old 04-11-2013, 09:11 PM   #6324
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Apparently the lag I have is all the time and not just below 4k. If I coast to 4k then mash the gas it takes until 4.7k to fully hit. It sounds more and more like a preturbo exhaust leak but for the life of me I can not find it. How can I tell if the turbo is going bad?
Old 04-11-2013, 09:22 PM   #6325
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
did u do a compression test ever? i saw an engine with low compression spool a turbo super slow
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
