Old 04-17-2013, 09:08 AM   #6401
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I never ran hybrid boost control, but with a Kinugawa adjustable actuator and a good spring, I really don't think a hybrid would add much.
My experience has been so far, that the stronger the spring, the smaller the per gear compensation needed.
This is all for twinscroll. I forget this minute if the V7 has per gear compensation in the ROM.
The twinscroll has a larger wastegate and needs more mechanical closing pressure, to oppose the larger exhaust gas gate-opening pressure.
Old 04-17-2013, 12:46 PM   #6402
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
the per gear compensations came with the v8 ecu, I am running them on my car with a 18 psi WG actuator (The Carberry SD rom includes per gear comps as well). They are really nice for being able to hit 24 psi in 2nd gear without overboosting badly in 4 5 and 6th.
I usually use 3rd gear as my zero point then add positive WG compensation for 1st and 2nd while 4th and 5/6th get negative compensation. It does take a bit of trial and error to get setup but not too bad.
My 18 psi WG actuator with a ton of preload can manage to hold ~16-17 psi on the top end
lukeskywrx is offline   Reply With Quote
Old 04-17-2013, 01:14 PM   #6403
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Is the stock wg activator good enough? Or would a stronger one like avo offer be better. I think the avo activator operates at 15 psi.
Old 04-17-2013, 01:28 PM   #6404
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The stock twinscroll actuator should be just above 12 PSI.
The Kinugawa is a very cost-effective upgrade. I run a 14PSI, but not on a IHI, on a Mitsubishi.
More is there to be had from a Stock IHI VF36 and 37, with a stronger spring actuator, also with adjustable preload, which the OEM does not have.
The AVO is quite more expensive than the Kinugawa, from what I recall and I'm not even sure they have a unit where you can swap springs, like the kinugawa.
I think Forge has an actuator, where the second port is actually functional and may be worth the extra $ to hook it up with a 3 port in an EWG actuator fashion, not that there's anything wrong with the kamak/kinugawa one.
Just be carefull with the VF 36/37. according to some, they don't live long time and with a strong actuator, while increasing performance, you will reduce their life even further.
Old 04-17-2013, 09:55 PM   #6405
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I have an avo wg actuator on my vf30 I have it set to 18psi. I love it! Also running an ebcs.
mrxr250rider is offline   Reply With Quote
Old 04-18-2013, 12:43 AM   #6406
Xissix
Member#: 85985
Originally Posted by Xissix View Post
Got my P1507 fixed, the IACV was stuck. Idle is nice and smooth now and revs as it should, idles down as it should, but between 1000-2000 rpm it shakes/vibrates a lot more than it should I am pretty sure. No bad noises, just vibration. Don't notice it under load.
Will no AVCS working cause this? No other codes on top of the ones I posted above, runs good otherwise.
Figured out the vibration, was an out of balance flywheel. Not sure how that even happens, machined square, from a running car. Second flywheel was good, running much better now.
Xissix is offline   Reply With Quote
Old 04-18-2013, 09:27 PM   #6407
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
its either that or it was warped somehow...
ur harness is in the mail^!
WhiteBgeye02 is offline   Reply With Quote
Old 04-18-2013, 09:40 PM   #6408
Xissix
Member#: 85985
Possible I guess, didn't look like it got hot, no idea how it could have gotten bent/warped.
Awesome, thanks!
Old 04-18-2013, 09:59 PM   #6409
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Awesome, thanks!
i just say warped because look how much vibration a bad rotor can cause. imagine your engine reving even faster. for a simple examble w/ a 25" tire it will rotate 850ish times a min if going 60mph. it shakes the car pretty hard when you hit the brakes going that fast if you have a bad rotor. now ur engine is idling at about that same rpm so a slight warpage or inbalance would cause the engine to flop around. i guess we will never know. def interesting tho. or something got behind the mating surface on install and cause it to seem off balance. small metal shaving would do it.
Old 04-18-2013, 10:24 PM   #6410
momotaro19
Member#: 339524
02 wrx
Vlad, can you elaborate on reliability of the TS turbos when boosting over 20psi? Where did you find the comments on short-lived TS turbos?
momotaro19 is offline   Reply With Quote
Old 04-18-2013, 11:52 PM   #6411
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
This is not in general about TS turbos, but only in particular about the IHI VF series TS.
In general, even with the single scroll, the opinions about long term reliability are mixed.
Once you add that stronger actuator and you increase the boost holding at high engine speed and spool faster, you accelerate the turbine more and possibly run it close to the limit rpm-wise, definitely increase the load and wear on the bearings.
I was reading on scoobynet I think, a while ago about those guys experience with VF 36-37 at the track and some thought that they are more likely to need a rebuild (as much as the vf36 even can be rebuilt) after 60-80k miles and couple sessions.
Those guys were just buying replacement VF 36 and kept going. Seemed like their conclusions were based on already having seen several of them on the same car (they were buying used)
There was a video on youtube of a ej207 with a vf36 that was new. The guy shuts down and takes the camera under the hood. The VF36 rolled on those bearings audible for another minute, with the engine off.
My 36 did not do this when I had it.
May be some kind if a quick way to figure where in its life the 36 is.
I think the Mitsubishi and Garrett turbos are more reliable long term.
Old 04-19-2013, 04:49 AM   #6412
Modollenroc
Member#: 243499
I know this is off topic and somewhat of a boot question but the power steering and throttle cables that are supposed to go with the 207 can be any one from a usdm WRX or STi correct? Or does it absolutely need to be from a JDM vehicle?
Modollenroc is offline   Reply With Quote
Old 04-19-2013, 09:25 AM   #6413
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Just use the usdm power steering punp and AC compressor, throttle cables hook right up. You can use the Jdm alternator without any issues.
D-Rodman is online now   Reply With Quote
Old 04-19-2013, 09:38 AM   #6414
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
After what a freind told me who used to work at garret. It makes me wonder about there quality.
Old 04-19-2013, 04:25 PM   #6415
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Oh you're right.
There was a thread couple years ago from a guy that used to work at Garrett.
It was really heartbreaking as the guy posted all the details of what happened lately, the outsourcing, the reduction in engineering crew, the focus on profit and don't worry so much about quality, yes, it's been posted.
This is after ownership changed, I think.
And currently I tend to think that the parts are not made in US anymore, maybe only part of the assembly work, maybe not even that anymore.
Old 04-19-2013, 09:16 PM   #6416
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i think like everything else the turbo will last longer if you take care of your engine. aka more frequent oil changes and running oil cleaners to keep all passages clean. taking off the rear banjo bolt feed line and cleaning the filter in there once a year to keep plenty of oil flowing to the journal bearing vf37. i will agree that a ball bearing turbo should still spin once you get out of the car IF the car has just been driven and the oil is up to temp. thicker oil will slow the bearing roll down much quicker if you did it say on first startup. wearing out ball bearings also will reduce the after rotation once exh gas stops flowing.
Old 04-20-2013, 02:09 PM   #6417
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
My vf36 takes several minutes to spin down from normal operations, it also had zero shaft play either side to side or front back when I put the motor in.
Old 04-20-2013, 02:33 PM   #6418
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Perfect timing on all this turbo talk... my VF37 is starting to smoke 10k into the swap
time to go rotated?
Torquey is offline   Reply With Quote
Old 04-20-2013, 03:16 PM   #6419
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
u sure its the turbo??? instead of going rotated get one of those new BW 62/58 turbos! then post results so i know how it performs!
Old 04-20-2013, 04:54 PM   #6420
25rsti
Member#: 166324
hahaa Be the 207s guinea pig, please. =-)
Old 04-21-2013, 01:35 AM   #6421
Xissix
Member#: 85985
Anyone done any testing with the OBDlink MX tool and the JDM ECU (AF481) and had any luck?
Loving this engine, 27mpg average over 300 miles, no AVCS yet, sooo smooth.
Old 04-21-2013, 11:15 AM   #6422
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Well, for the past one week... every time I come to a stop after the car has sufficiently warmed up, I've been noticing a slight burnt smell. At first I didn't see any smoke, but the last few times i noticed whitish smoke out of the hood scoop. When I looked in there, It was coming from the "turbo area". I don't have a heatshield, just a PTP turbo blanket... yet to take it off for a closer look.
Does this sound like the symptoms of seals going out?
Old 04-21-2013, 12:15 PM   #6423
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Sounds like a pin hole in a coolant hose.
Old 04-21-2013, 12:48 PM   #6424
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
the banjo bolt coolant line at the top of the turbo tends to leak. and since it leaks onto the top of the turbo, it burns off immediately, so it just smells like burnt coolant, but rarely shows any signs of leaking. i'd check that banjo to see if it shows any white residue around it. if so, replace it, and you should be good.
lil'redwagon is online now   Reply With Quote
Old 04-21-2013, 08:52 PM   #6425
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
From first hand experience with my friend's car, the BW 6258 EFR is going to spool just a hair faster than stock (vf 39/37) but hold quite a bit more in the top end. For example on E85 and on the stock turbo (vf39, 06 STI) he made 460tq and 360whp, but when he put in the 6258 on e85, he made the same wtq but 430whp... so yea HUGE powerband.
Personally I think the 6758 or 7163, that should be released soon, would suit the 207's head flow and revving capability a little better.
K1WRC is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
