Old 04-21-2013, 11:17 PM   #6426
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Originally Posted by lil'redwagon View Post
the banjo bolt coolant line at the top of the turbo tends to leak. and since it leaks onto the top of the turbo, it burns off immediately, so it just smells like burnt coolant, but rarely shows any signs of leaking. i'd check that banjo to see if it shows any white residue around it. if so, replace it, and you should be good.
Thanks man... checked it again today and looks like the smoke is coming from drips of oil splattering on the downpipe. Definitely not coolant, as the that line is dry, and the the liquid is dark/ greasy.
Torquey is offline   Reply With Quote
Old 04-21-2013, 11:42 PM   #6427
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
ah, in that case, check the oil drain tube on the back of the turbo. it's tucked up in there, and the stock clamp on the hose is a spring clamp. that tends to leak. it'll be a pain to do, but it's possible to wrap a hose clamp around the connection. usually there's over an inch of where the drain pipe gets covered up by the rubber drain tube hose, so you can usually just slide the spring clamp up higher on that intersection, and still have plenty of hose/tube to get the hose clamp around.
lil'redwagon is offline   Reply With Quote
Old 04-22-2013, 12:08 AM   #6428
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yeah but for us autox guys we need quick spool and 400wtq and 400whp all with full spool by 3200rpms would be tits! if i was drag racing then a 7163 would def be in order.
WhiteBgeye02 is offline   Reply With Quote
Old 04-22-2013, 12:15 AM   #6429
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Originally Posted by K1WRC View Post
From first hand experience with my friend's car, the BW 6258 EFR is going to spool just a hair faster than stock (vf 39/37) but hold quite a bit more in the top end. For example on E85 and on the stock turbo (vf39, 06 STI) he made 460tq and 360whp, but when he put in the 6258 on e85, he made the same wtq but 430whp... so yea HUGE powerband.
Highlighted is what I want for torque as low as possible for as long as possible.
ImNOrobo is offline   Reply With Quote
Old 04-22-2013, 03:20 AM   #6430
K1WRC
Member#: 64511
2003 WRX sedan
VF36 EJ207
6258 is really impressive. For autox it probably would be ideal
K1WRC is offline   Reply With Quote
Old 04-22-2013, 08:16 AM   #6431
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
The packaging is difficult with those.
they are already a long unit, twinscroll makes these even longer.
The 6 series seemed like it could be shorter but initially was not offered twinscroll.
Full race is looking for a really high price for their pipes.
The full race test result, that all are excited about, comes in contrast with the perrin test result and Perrin even left his article kinda open-ended, suggesting (to me) that there were things that he could not say..
In addition to all this, there are some articles suggesting that BW is preparing their next generation, which will have all the EFR plusses, in a short (normal to us) body.
When you think about it, the long assembly means extra weight and if they shorten it successfully, the unit may be even more performant.
Old 04-22-2013, 12:34 PM   #6432
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
dont forget that is with a ej257 engine. our engines rely on higher revs to make more power up top instead of down low torque. you could prob get close tho running 30psi down low and then taper it off to mid 20's the rest of the way up
Old 04-23-2013, 03:43 AM   #6433
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Sounds ok with me.
Old 04-23-2013, 06:58 PM   #6434
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Maybe this was mentioned, but it sounds like you have a broken CV boot. That usually leave grease spattered on the downpipe.
Old 04-23-2013, 07:40 PM   #6435
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
lol.. yep, that's exactly what it is! In a way I'm glad it's not the turbo lines. But that stink from burnt bearing grease is is quite bad too. Hopefully can get it repacked with a new boot.
Old 04-24-2013, 12:26 AM   #6436
amroof
Member#: 211224
2005 Saabaru
Who knows
Anybody ever run the power enterprise 1825 turbo?
amroof is offline   Reply With Quote
Old 04-25-2013, 12:17 PM   #6437
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
hey guys having some issues with my version 8. figured id post here because everyone is so knowledgeable.
currently I put my ver8 from my 95L into my 03 bugeye to use as my stage rally car since it was already caged and logbooked. ive gone over everything so many times and can't find anything to make this happen.
when the maf is plugged in it runs like crap. 40% to rich and then down to 40% to lean at idle alone. when we attempt to scale the maf so it will idle just so we can light test it on the dyno it has a very big problem zone that makes me wonder. as soon as I get any boost pressure immediately the ecu tries to remove 50% fuel. so needless to say I can't get it running correctly.
without the maf plugged in , it runs perfect. idles great afr sits at 14.7 so my tuner said he could scale the "backup tune" so to say so I could drive it, but keep an eye on the wideband and go easy on it.
things I have tried to fix the problem;
1. switching MAFs 3 times actually 1 used 2 new
2. checking for vacuum leaks at idle and under load
3. checking for unplugged or loose electrical
the only things I changed from moving it from 1 car to the wrx is;
1. stock wrx harness with correctly added avcs wires kit from iap
2. 34mm restrictor
3. machined cold side of vf37 to fit restrictor
4. put lock screws and an O ring so the restrictor is unmoveable and no air leaks
5.prodrive turbo inlet
any thoughts would be great, thanks
jhenry1983 is offline   Reply With Quote
Old 04-25-2013, 03:58 PM   #6438
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
2. 34mm restrictor
there was a car i was helping troubleshoot a while ago, the owner tried all the things you mentioned. I'm not sure if its the same thing but check out your front o2 sensor wires, if you left the o2 in the exhaust manifold during your swap, it is easy to accidently get the wires squashed against the frame rail and get some weird readings.
fastnoypi is offline   Reply With Quote
Old 04-25-2013, 04:04 PM   #6439
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
are you running the JDM ECU? if so, maybe you could try running the CarberryROM, which is a Speed Density ROM. otherwise, check front O2 sensor, (but if it runs well withouth teh MAF plugged in, then that sort of diagnoses that to be working), or triple checking for a vac leak under those conditions.
Old 04-25-2013, 04:09 PM   #6440
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
Hey guys,
I finally got street tuned on my V7 and boy am I impressed. Since I had the time, the car was equipped with GSC (S2)valve train and a twin scroll rotated 3076R. WOW does this thing pull incredible hard from 3600 to 8200. I can't wait to turn the boost up and get on a dyno for a 25psi run.
vogun16 is offline   Reply With Quote
Old 04-25-2013, 08:30 PM   #6441
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Unfortunately the v8 stock exhaust manifold doesn't have an egt or o2 sensor there. Its in the top of the downpipe. I'm using a wideband and it reads the same as the o2 sensor so it should be working.
I'm at a lose and my first rally is next Friday/Saturday. Only idea now is just wiring demons somewhere. Im under the assumption I'm using a stock 03 wrx harness , and I added the IAP harness avcs harness but it all checks out
Old 04-25-2013, 09:15 PM   #6442
SnowBRDGod247
Member#: 319756
2002 Audi S4
Hey guys
Just got my car back today w a v7 ej207 swap complete. Currently running a blouch 18gxt w full supporting mods and a road tune to 22psi looking to hit the dyno in the next few weeks. Only like 100 miles on the new engine and I am already addicted. I was not a huge believer that the differences between the 205 and 207 were going to be that huge but w avcs on the 207 this thing is incredible turbo spools much earlier and just pulls great all they way to redline. Paired w the v7 6mt I have I just love it. Awesome motor. I will definitely be putting another in my gfs Wrx when I get her one
SnowBRDGod247 is offline   Reply With Quote
Old 04-25-2013, 09:49 PM   #6443
vogun16
Member#: 93206
02 WRX....
Originally Posted by SnowBRDGod247 View Post
Hey guys
Good to hear, I saw your silver wagon at wicked while my car was getting a pre-tune inspection.
Old 04-25-2013, 10:12 PM   #6444
SnowBRDGod247
Member#: 319756
2002 Audi S4
Cool man! How did your visit go? I needs more turbo now lol!!
Old 04-25-2013, 10:24 PM   #6445
vogun16
Member#: 93206
02 WRX....
It was great. Tom fixed a small issue that I was too flustered to deal with and then M@ took the car for a street tune. The ride home was all sunshine and rainbows after I felt how much power it was making. Matt likes the 1.5xtr on his car, I went a little crazier with a 3076 but I honestly don't notice any appreciable lag.
Old 04-25-2013, 11:16 PM   #6446
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Originally Posted by vogun16 View Post
Hey guys,
Want! Sounds nasty
mrxr250rider is offline   Reply With Quote
Old 04-25-2013, 11:40 PM   #6447
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
Originally Posted by mrxr250rider View Post
Want! Sounds nasty
Keep us updatedd
SubieSnacks02 is offline   Reply With Quote
Old 04-25-2013, 11:57 PM   #6448
SnowBRDGod247
Member#: 319756
2002 Audi S4
Hahaha nice! Yeah I will probably step up to the 1.5xtr and follow in his footsteps in 6 months or so. Just did the engine and two months ago the full drivetrain swap w brembos etc and my 18gxt setup is less then a year old haha! But I will say for the 18g I am super impressed with this little thing at 22psi I was just out driving in the nice cool air and it really pulls pretty awesome now w avcs and the engine in general. Do you have the 207 as well? The lag on my 205 w the 18gxt even was annoying, that's completely gone now spools with me hardly on the throttle feels like the td04 again vs before haha.
Old 04-26-2013, 12:01 AM   #6449
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
What's the most hp a stock 207 block can handle? I heard 400hp...
Old 04-26-2013, 12:04 AM   #6450
SnowBRDGod247
Member#: 319756
2002 Audi S4
I've heard it can handle 400whp as a daily driver and stay reliable. This is from wicked... It can handle more but I'm assuming it gets less reliable obviously. The 1.5xtr will get me right to or just under 400 which is why I'm interested super strong little motors.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
