Old 04-25-2013, 11:22 PM   #6451
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
Originally Posted by SnowBRDGod247 View Post
I've heard it can handle 400whp as a daily driver and stay reliable. This is from wicked... It can handle more but I'm assuming it gets less reliable obviously. The 1.5xtr will get me right to or just under 400 which is why I'm interested super strong little motors.
That's very interesting.. Im still debatin to build this motor or buy a 205 and then build it
SubieSnacks02 is offline   Reply With Quote
Old 04-26-2013, 07:06 AM   #6452
SnowBRDGod247
Member#: 319756
2002 Audi S4
Just from my recent experience if you have a 207 and avcs there's no question IMO I actually opted for this motor as opposed to a built 205 which would have came out a 2.1 stroker. (Sti crank) would have been sweet but 400whp is enough for me and at half the cost this motor can handle it stock.
SnowBRDGod247 is offline   Reply With Quote
Old 04-26-2013, 07:22 AM   #6453
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
I have a V7 with cams+springs and a million other mods. In the past I have driven some high HP cars, but I must say that 400whp in my car will feel unreal. At this point I'm not sure how much more I want.
vogun16 is offline   Reply With Quote
Old 04-26-2013, 07:59 AM   #6454
25rsti
Member#: 166324
Don't push it. Get that dyno tune with a little more boost and timing and THEN make a decision if you want more.
Old 04-26-2013, 08:50 AM   #6455
SnowBRDGod247
Member#: 319756
2002 Audi S4
Haha I agree w you! I'm mid 3's right now and just the way that this motor pulls w the extended power and and 8200 redline 400 should be more then enough. Over 400 is general non stop issues too and I drove a buddies Evo 8 a week ago with 440whp and really didn't feel that fast... And he has issues all the time.
Old 04-26-2013, 11:33 AM   #6456
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Unless you will be running e85 or meth I don't think you will see 400 with a 1.5. Pete at efi logics has the same turbo on a 207 340whp. I will be going with a 3076,dom3 or fp red for around 400whp on efi's dyno if I upgrade
mrxr250rider is offline   Reply With Quote
Old 04-26-2013, 12:28 PM   #6457
SnowBRDGod247
Member#: 319756
2002 Audi S4
Idk my shop uses a mustang and can get you damn close to 400 my tuner is running the 1.5 on his 207 waiting to see his results and ill let you know. I have heard efi runs very low and that must be a pretty conservative tune as I am around those numbers w a 42 or 43lb turbo that 1.5 is a 49lb per minute it can easily get 380 hp with the right tune... Especially when you can rev so high.
Old 04-26-2013, 01:05 PM   #6458
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
At this point you're just discussing semantics. A 400 WHP turbo that's a 340 WHP turbo an a different dyno is still the same turbo and isn't going to be any faster just because you have a sheet that says 400.
It may be a 49 lb/min wheel, but the whole design of the 1.5XTR is the smaller turbine wheel vs the 2.5XTR... which means the hot-side is going to hold you back from achieving that 49 lb/min from the compressor.
Go to the EFI Logics dyno database. Look up what various turbos are doing in terms of power. See how the 1.5XTR compares. See if that fits with your expectations. A turbo will achieve about the same peak HP on a 257 and 207, just the shape of the curve will be different. The 207 will have less torque and peak power will be higher RPM and broad. 255/257 will have higher torque peak, earlier power peak, faster rise and fall of the power. But peak HP on the two engines will be very close... so just use the dyno database and look at how turbos stack up to other turbos. Contrary to popular belief, there's not a whole lot of magic to turbos.
Concillian is offline   Reply With Quote
Old 04-26-2013, 03:44 PM   #6459
SnowBRDGod247
Member#: 319756
2002 Audi S4
Good info and you are correct a turbo will only flow what a turbo is going to flow... Doesn't matter what motor it's paired to as you said that just controls where power is made. All dynos read different and every tuner is not the same either. Some mess w things that others don't not saying that is a good thing. I am from CT originally close to efi they are a great shop and great guys who do great work. But there dyno database is not the only one in the world people's dyno sheets are always different w ppl claiming more power etc... This is why I simply use the 400 as a "reference number" I go by what I am looking for and what suits my needs. I was just re stating things I was told that make sense based on other dyno sheets I have seen. Also the 1.5xtr may NOT hit 400... But it is well over a 350whp turbo IMO from what I have seen. I do think it could get one close that's all I was saying. It's not a huge turbo by any means thanks for all the info too!
Old 04-26-2013, 08:19 PM   #6460
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
FYI I dyno'd at 398 hp with the Dom 1.5XTR on e85 on the 207 with a front mount. 22-23 psi or so
We tried pushing it farther, but there wasn't much power gained adding more boost than that. 22-23 psi seems to be the sweet spot for that turbo.
Honesty I wish I'd have bought the 2.5
simon021 is offline   Reply With Quote
Old 04-26-2013, 09:45 PM   #6461
Ryan2002WRX
Member#: 225439
Where does it spool at? I was thinking 1.5xtr with my built 207 eventually. I am running an hta68 and like the fast spool. Why do you wish you went to the 2.5?
Ryan2002WRX is offline   Reply With Quote
Old 04-26-2013, 10:59 PM   #6462
simon021
Member#: 157532
2002 MY03 EJ207 E85
22psi at 3400-3500 with a top mount and around 3800 with front mount.
The 1.5 doesn't hold as much power all the way out to 8k as I would have liked. The larger hotside from the 2.5 would be nice. I was expecting to trade some spool for some top end, but I ended up with the same spool and somewhat more top end. I drive almost exclusively highway miles so I'd gladly trade more spool for more top end. Especially with the 207
Old 04-27-2013, 12:15 AM   #6463
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
What is the torque you got with that tune? When does it start dropping off?
ImNOrobo is offline   Reply With Quote
Old 04-27-2013, 12:28 AM   #6464
Ryan2002WRX
Member#: 225439
See for me only reason I wanted to stay more hta68 or 1.5 is I do a lot of around town and back roads driving. Not much highway. For you sounds like the 2.5 will work out perfect.
Old 04-27-2013, 10:08 AM   #6465
simon021
Member#: 157532
2002 MY03 EJ207 E85
Peak boost was down on the dyno so I think it only made 360 or so but on the road with VD I typically hit around 400hp and 380 tq
Power starts dropping off up around 7500 or so
Old 04-27-2013, 10:17 AM   #6466
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
The 1 207 I saw with a HTA68 I wasn't really impressed with. I forget who actually bought that car (might have been you?) But it didn't make much more than my car with the stock VF22.
EDIT: This one
6 speed, Ver8, HTA 68, Headers, DW750's. Red is with the addition of a KS Tech intake
Psychoreo is offline   Reply With Quote
Old 04-27-2013, 11:59 AM   #6467
Ryan2002WRX
Member#: 225439
EDIT: This one
Lol yes that is mine haha. Car went down with a bad ringland. I am concluding that the poor power on the car had a lot to do with the ringland problem. That is why I want to see how it does fully built. If it still is not that great I was thinking upgrade. My goal is to keep spool as low as I can. That's why I was leaning to a 1.5?
Old 04-27-2013, 01:15 PM   #6468
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
if you're going to build it for more torque, are you stroking it? if you stroke it, you can get more torque from the motor down low, and run a larger turbo for more power up top.
lil'redwagon is offline   Reply With Quote
Old 04-27-2013, 02:17 PM   #6469
Ryan2002WRX
Member#: 225439
Well it's already being built at EFI. No it's not being stroked. Pistons, rods, bearings, valve springs. And a bunch of upgrades.
Old 04-27-2013, 02:57 PM   #6470
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
My version 7 just put down 300whp 260ftlbs on vf30 pump at EFI, and apparently I did a phenomenal job fabbing my own AVCS harness. Saved $200 too!!! This is such a sweet set up.
96SubyImpreza is offline   Reply With Quote
Old 04-27-2013, 03:03 PM   #6471
Xissix
Member#: 85985
^Nice, looking to hit similar numbers with same setup next week.
I'm wiring in my AVCS harness now (thanks whitebugeye!) but I have a wire color discrepancy on the E84 ecu plug. The pin 10/11 by ds1 instructions had the colors swapped from what my car is. Is ds1 correct and my wires were wrong from the factory?
Also, the pin 5 was YG, not GY, pin 4 and engine bay plug were matched to ds1.
Xissix is offline   Reply With Quote
Old 04-27-2013, 03:07 PM   #6472
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
Good luck!! And I followed the ds1 diagram, primarily the pin outs. I ignored colors.
Old 04-27-2013, 03:08 PM   #6473
Xissix
Member#: 85985
Ok, answered my own question on car and colors, my car is right (matches fsm). Do I follow the ds1 instructions for the pin move and ignore the colors in there, or go by color? I don't have a jdm pinout to reference.
Old 04-27-2013, 03:14 PM   #6474
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
I followed the ds1 instructions. The ecu pins are honestly the most difficult part of this, keep your head about you when you start getting frustrated.
Old 04-27-2013, 03:20 PM   #6475
Psychoreo
Member#: 79643
2015 WRX STI
Stock downpipe?
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
