Old 04-27-2013, 03:27 PM   #6476
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
Originally Posted by Psychoreo View Post
Stock downpipe?
Nope, turbo back, walbro, Perrin fmic, grimmspeed ebcs, etc.
96SubyImpreza is offline   Reply With Quote
Old 04-27-2013, 03:36 PM   #6477
Xissix
Member#: 85985
Thanks 96Suby, popped them in, hooked up the battery and fired right up, no more CEL! Good feeling having it done now.
That ECU plug was a pita, until I tried using a good sized needle, that made it much easier, that and pulling the lock clip (oops).
Xissix is offline   Reply With Quote
Old 04-27-2013, 03:53 PM   #6478
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Nice. I think I saw a picture of your car. The red one? Beautiful.
I hit 271whp/287wtq on that dyno with stock downpipe, evo2, walboro, USDM STI ic, and grimmspeed EBCS. I'm picking up a front mount soonish.
Psychoreo is offline   Reply With Quote
Old 04-27-2013, 04:34 PM   #6479
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
Awesome!!! That's a great feeling man. Yea that lock clip is a bit odd. Absolutely great, congratulations.
Yes sir that's her, thank you very much.
That's great numbers for a stock downpipe. Due to the size of my intercooler I'm losing quite a bit of spool, I see full boost around 3800. Mikey said due to the adjustments he was able to make with timing because of the front mount I did see a nice gain from it though. He also said I gained ~200 rpms with the ebcs. Holy torque by the way.
Old 04-27-2013, 06:22 PM   #6480
Psychoreo
Member#: 79643
2015 WRX STI
:torque flex:
Yea it feels really good. Mikey stepped out of the car looking puzzled.
"Car pulls hard, but you're making about 5-10whp less than what I normally see for a stage 2 ver8."
"Well, it does have the stock downpipe. :shrug:"
"Wait, stock downpipe? Nevermind you're about 15 above where you should be!"
When I get around to it, the fmic and downpipe will go on. I honestly wouldn't mind a bit of delay in power to 3800-4200. As it is right now, it'll push 19psi at 3300rpm in any gear, and just goes.
Old 04-27-2013, 08:34 PM   #6481
Xissix
Member#: 85985
Thanks! Bittersweet at the moment, had an axle to fix while I had the car in the garage and having issues getting it out of the hub, so haven't gotten to test drive it yet. Looking like it may be a few days as I need to get a new hub now (20 ton press on the axle won't push it out of the hub...).
Old 04-28-2013, 02:39 PM   #6482
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Does anyone have a quick rough cold startup idle with the V8s? I have a quick 5sec hiccup(sounds like a miss) every cold start and then runs great/pulls strong after those first 5 secs. Really strange.
JulianDelphiki is online now   Reply With Quote
Old 04-29-2013, 07:03 AM   #6483
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Mine does something similar to that also
Old 04-29-2013, 09:10 AM   #6484
Psychoreo
Member#: 79643
2015 WRX STI
When idling or driving?
Mine does this too when driving.
Old 04-29-2013, 12:10 PM   #6485
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Idle. It only does it on an initial cold start for 5 secs, i.e. if the car has sat for a day or two. Then its perfect. Warm startups are fine. Im cleaning the IACV/replacing the gasket and seeing if that does anything for it. Its very strange though, it feels like its going to stall, and then it idles beautifully.
Old 04-29-2013, 12:26 PM   #6486
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
Mine does it too, and yes, it sounds like a misfire.. Mine does it one time on a cold start and then Everything's fine
SubieSnacks02 is offline   Reply With Quote
Old 04-29-2013, 12:47 PM   #6487
Psychoreo
Member#: 79643
2015 WRX STI
Weird. Yea if mine sits for a day or two and I start it and drive right away, the first 10 sec or so it feels sluggish. Immediately after that it's perfect.
Old 04-29-2013, 12:49 PM   #6488
207STi
Member#: 197062
1998 Swapped Impreza
black
Alright guys I have completed my v7 ej207 build and have finally began tuning. Everything is going much smoother than I expected besides some avcs issues. I am throwing a p1308 OCV (oil control valve) Solenoid Signal Malfunction code. My avcs solenoids will not advance past 4*. Does this sound like an avcs wiring problem or a problem with the solenoid itself? I need to triple check my wiring again, but the car is across town at a fiends garage at the moment.
207STi is offline   Reply With Quote
Old 04-29-2013, 12:55 PM   #6489
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Try switching the solenoids.
Old 04-29-2013, 01:21 PM   #6490
207STi
Member#: 197062
black
assuming they are not specific to the drivers side or passenger side heads?
Old 04-29-2013, 01:36 PM   #6491
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Nope. They are the same part number. I switched mine out when I was diagnosing my avcs troubles. Takes 10mins if the 'green brackets of death' are already removed.
Old 04-29-2013, 01:38 PM   #6492
207STi
Member#: 197062
black
Oh I hacked those bastards a long time ago. I'll swap the solenoids and report back. Thanks for the suggestion!
Old 04-29-2013, 02:21 PM   #6493
Whoracle
Member#: 301075
2003 Impreza WRX
You start and then drive right away? Wow, maybe im just paranoid because of how much I just put into this motor, but I usually let it get up to operating temp before i drive it. At the very least I let it warm up for 2 minutes if I need to leave asap.
Whoracle is offline   Reply With Quote
Old 04-29-2013, 02:23 PM   #6494
Psychoreo
Member#: 79643
2015 WRX STI
Not as in
:start:
:vroom:
:drive away:
I usually let it idle a bit before hand but, no, it's absolutely not up to standard operating temp.
Old 04-29-2013, 02:27 PM   #6495
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
F that. I usually start it up, go inside, and sit in the a/c for 5mins then go on my way. And I live in FL. I did the same with my sti, my roommates call me paranoid but I'm not applying any throttle before my idle oil pressure drops to 20psi.
Old 04-29-2013, 02:53 PM   #6496
25rsti
Member#: 166324
Driving around on a usdm ecu SUCKS!
Old 04-29-2013, 05:23 PM   #6497
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Lol that's me! Turbo timer greatly helps this! Start the car set the timer for 5 minutes, go inside, when the car shuts off time to go! Lol I don't even get in my truck which I use daily and start up and go. My ver8 has had a 3076 24lb 93 octane set up on it now for years.
Trey
treystoys is offline   Reply With Quote
Old 04-29-2013, 06:14 PM   #6498
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
How much psi? Do you have a turbo inlet,intake and headers? Just curious cause my v7 did a bit better also tuned at efi. Thinking about pushing it even more with bigger intake,injectors, and 23psi
mrxr250rider is offline   Reply With Quote
Old 04-29-2013, 07:53 PM   #6499
WRick
Member#: 86107
Anybody install a crawford AOS on one of these things ? Kinda had to guess through the install....
Anyone have pics of their engine bay with this installed ?
WRick is offline   Reply With Quote
Old 04-30-2013, 11:44 AM   #6500
Mr.Vanbuskirk
Member#: 354562
I love my version 8 swap, paired with a 07 6 speed i think its perfect
Mr.Vanbuskirk is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
