Old 07-29-2013, 05:43 PM   #7151
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
Originally Posted by Psychoreo View Post
Noted. Have you used these?
Yup they work great, using them on my car now
Impreza WR Rex is offline   Reply With Quote
Old 07-29-2013, 06:44 PM   #7152
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
21mpg this tank.
Psychoreo is offline   Reply With Quote
Old 07-29-2013, 07:26 PM   #7153
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Maybe my roof rack is killin my mpgs
Jubert39 is offline   Reply With Quote
Old 07-29-2013, 08:52 PM   #7154
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
what are you guys using for oil? ive used castrol edge 5w40 and rotella t6 5w40.
i hear good things about brad penn only thing is it doesnt come in 5w40.
5w30 10w40 ect..
mrxr250rider is offline   Reply With Quote
Old 07-29-2013, 09:24 PM   #7155
Mountain
Member#: 331271
03 WRX
Motul 5w30
Mountain is offline   Reply With Quote
Old 07-29-2013, 09:54 PM   #7156
SubNub
Member#: 53603
2004 EJ207 WRX
21mpg this tank.
What kind of driving does that represent? I used to get 25mpg on my tuned EJ205 combined highway and city with some full throttle mixed in. I hope the EJ207 isn't much worse.
SubNub is offline   Reply With Quote
Old 07-29-2013, 11:54 PM   #7157
Psychoreo
Member#: 79643
2015 WRX STI
That was mainly highway with a few spirited pulls mixed in. I drove from NWCT to Queens and back
Old 07-29-2013, 11:55 PM   #7158
Fehnix
Member#: 300587
02 wrx wagon ej207
Ok I'm a little confused... The avcs wiring that was included with my swap has two connectors to the ecu. But the DS1 wiring guide only mentions one if them...
added: This is what was included. It doesn't look like the pins match up at all with the DS1 instructions.. I have no idea what to do with these...
edit again: So I feel pretty damn stupid.
http://forums.nasioc.com/forums/show...5&postcount=28
I was looking at the ecu plug backwards from the diagram! LOL It all makes sense now.
The wires given to me are the ones that need to be added in the DS1 instructions. It appears as though I can splice the wires from my usdm connector to these and then just run this whole harness. I would still have to modify the TGV black harness in the engine bay. But shouldnt be too hard:http://forums.nasioc.com/forums/show...1&postcount=58
Hope that helps clear up anyone else's confusion lol
Fehnix is offline   Reply With Quote
Old 07-30-2013, 12:13 AM   #7159
SubNub
Member#: 53603
2004 EJ207 WRX
I was wondering about this too when the supplier sent photos and "instructions" telling me to just use the same pin locations as the "AVCS harness" they send. I'm pretty sure you're still going to have to re-use your TGV wires on the side you simply re-pin. Then use the 4 wires plus ground pin from the provided harness to wire up the other side.
That's what I plan to do anyway. I haven't received my wire harness yet to compare the pin locations to my research.
FYI, you might need to do some additional work to make that 580 ECU run right. I've read something about the possibility of grounding out the #1 pin to make AVCS work. Just what I've read, hopefully someone else can chime in.
Old 07-30-2013, 12:30 AM   #7160
Fehnix
Member#: 300587
02 wrx wagon ej207
Oh geeze. I'm just confused as ever about this wiring crap. Idk what you mean by grounding it out. But I'll look into it.
If anyone can make sense of that, please let me know. I don't want to have to remove pins and replace them, etc, if I can avoid it. I'd rather not destroy anything lol In the mean time, I'm going to lose some sleep trying to figure this crap out.
Old 07-30-2013, 01:13 AM   #7161
SubNub
Member#: 53603
2004 EJ207 WRX
Sorry, I don't want this to be the blind leading the blind haha but it doesn't make any sense to me how they could suggest you can run AVCS from one engine connector when every wire reference shows 2 engine connectors, one on each side! I just wanted the "AVCS harness" so I could see how hard it's going to be to de-pin the connectors. If I can't do it then ill buy the harness I know works.
PM me and I'd be happy to collaborate on research. I'll be curious how everything goes for you since I'm right behind you.
Old 07-30-2013, 01:31 AM   #7162
Fehnix
Member#: 300587
02 wrx wagon ej207
hahaha yea we don't that. De-pinning seems to be the hard part. I believe the IAPerformance kit is just shielded wire and the pins. You just re-pin and go. I emailed IAP and also my engine distributor about a guide. Hopefully one of them will reply with something positive. Otherwise I'll try to figure this out and will definitely PM you if I make any headway on this.lol
Old 07-30-2013, 02:32 AM   #7163
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
with the talk of fuel mileage, we should be mentioning what transmissions we're on. i typically see between 16-20mpg tank averages with a jdm 6sp and a mix of rural/highway driving. when i switched transmissions from an '02 5sp, i saw a decrease of about 3-4mpg due to the shorter overdrive gear.
lil'redwagon is offline   Reply With Quote
Old 07-30-2013, 03:56 AM   #7164
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
So u swapped ur 6 speed out for an 02 wrx 5 speed?
Old 07-30-2013, 04:07 AM   #7165
Fehnix
Member#: 300587
02 wrx wagon ej207
Other way around...
Old 07-30-2013, 10:39 AM   #7166
EEkShh
Member#: 317977
Arent 2.5 conversions hella expensive? I've heard its so expensive its almost not worth it. I've heard some say youre better off doing a 2.0/2.5 hybrid
EEkShh is offline   Reply With Quote
Old 07-30-2013, 10:51 AM   #7167
SubNub
Member#: 53603
2004 EJ207 WRX
Don't do what? If you have the DS1 instructions you have all the guide you need. If you're distributor is Robert from JDM racing motors he'll tell you to put the supplied wires in the same pin locations on your harness but to my knowledge, this wont work cause you only need to add pins to the one ECU connector, not two like the harness provided and additionally, you still need the other engine connector pinned up too.
Anyway, you've essentially been supplied "shielded wire and pins," you just need to de-pin what you have and follow the DS1 instructions. You might even have enough conductors to add the unsheilded wires from that harness in place of re-pinning the TGV wires.
I'll PM you too.
Old 07-30-2013, 12:25 PM   #7168
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Originally Posted by Mountain View Post
Motul 5w30
Anyone else? I guess 5w30 is fine then. I've been running 5w40 castrol or rotella t6 like Clark recommends.
Would mind picking up a case of 5w30 brad penn,amsoil ect that way I can run that weight in both of my vehicles
Old 07-30-2013, 12:29 PM   #7169
Clark Turner
Member#: 178047
02 WRX STI Spec C
Then I'm losing out with this stock exhaust/intake.
22 AVG is pretty good. But on a steady trip with the car in tune, these engines will get 28 to 30 mpg. I had the 5MT trans at the time which helps. The 6mt is not only slower, Its reving higher at speed.
C
Clark Turner is offline   Reply With Quote
Old 07-30-2013, 12:33 PM   #7170
Psychoreo
Member#: 79643
2015 WRX STI
C
Yea my best was a trip down to NC where I averaged ~26mpg on the stock 04 5 speed. Basically every other tank I've had has been ~22mpg. Which do you feel is the bigger hindrance, the stock twinscroll down pipe or the stock intake/intercooler? (I should mention I'm on a UDDM STI top mount)
Old 07-30-2013, 12:40 PM   #7171
Clark Turner
Member#: 178047
02 WRX STI Spec C
5w30 10w40 ect..
I am not a fan of the rotella in these engines. This was first made popular probably many years back by Ron At axis. He used that oil on race engines that had very loose tolerances and pistons that slapped around in the bores and ran very rich AFR at high boost. I have seen this oil come out as thin as tap water after use.
I think 5-30 is to thin for the 207. I have seen way to many bearing failures with it. Keep in mind that alot of "special" oils will be at least one step lighter viscosity that advertised. Look up some UOAs of the oil in question. After being in thousands of cars with oil pressure gauges, I would run 10-30 winter and 10-40 summer. OR a good 5-40 is fine like Castrol. The lighter the oil, the less oil pressure you will have at redline on these engines. You CAN, Take the oil pump apart and shim it so it will run higher pressure with the thinner oil.
When you see the oil pressure run 90 to 100 with the heavier oil and then see the pressure 60 to 70 with the light weight oil, Then you will probably agree with me.
What runs the coolest oil temp and what does not burn off is what you should run. If you have to add oil in every tank, then switch brands. The Motul burns off and the Castol does not in my personal engine.
C
Old 07-30-2013, 12:42 PM   #7172
Clark Turner
Member#: 178047
02 WRX STI Spec C
I would say downpipe and optimizing the tune.
C
Old 07-30-2013, 12:50 PM   #7173
Psychoreo
Member#: 79643
2015 WRX STI
Thanks Clark
Old 07-30-2013, 01:50 PM   #7174
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
JR TUNED
Would any of this really make a difference if you keep the car in closed loop? I would think aerodynamics/wind, gearing, and weight would cause the biggest differentiation in mpg. Basically minimizing engine load...
PS - This episode of Mythbusters gives you an idea of just how much aero/wind can affect things:
Old 07-30-2013, 05:00 PM   #7175
Fehnix
Member#: 300587
02 wrx wagon ej207
So I just bought the last Purolator pure one pl14460 from sears. They said they won't be carrying it anymore and they are the only place in town that did. After this can I just use the pl14410 (sti) filter? It's much smaller...
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
