Old 03-17-2011, 08:28 PM   #1376
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
what does say on the ecu as well???
gingertooth is offline   Reply With Quote
Old 03-17-2011, 09:30 PM   #1377
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Originally Posted by kbaldi_29 View Post
what version ecu are u using? V7 or V8?
tried 2 different v7 ECUs
Jubert39 is offline   Reply With Quote
Old 03-17-2011, 09:48 PM   #1378
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
the last 4 digits say F481 i believe...
Old 03-18-2011, 06:07 PM   #1379
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
That's the same digits mine has which was a V8 ecu
murrdogg24 is offline   Reply With Quote
Old 03-18-2011, 07:00 PM   #1380
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
I'll check my ecu as well.
Jubert: Please don't take this offensively, but are you sure the ecu's you have match the motor? They may be from something else.
arco is offline   Reply With Quote
Old 03-20-2011, 01:57 AM   #1381
drag_star
Member#: 230997
Im building ej207 to a 2.2 stroker setup . At the moment this what I have :
CP Piston 93 mm (Stroker piston)
Carrillo Pro-SA con rods
RCM 79mm billet crank
RCM 14mm head studs & Head dowels
ACL bearing
Aeromotive fuel regulator(converting to parallel setup)
800cc Sard Injectors
Garret GT3076R
Im sending the block to Darton sleeve for the honing & sleeve kit .
What are the max hp that this setup capable of ? Any inputs and suggestion on the route I'm going is much appreciate
drag_star is offline   Reply With Quote
Old 03-20-2011, 01:34 PM   #1382
Clark Turner
Member#: 178047
02 WRX STI Spec C
Little turbo. 450 to 500hp
C
Clark Turner is offline   Reply With Quote
Old 03-20-2011, 03:07 PM   #1383
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
yes, positive. I actually tried 3 different JDM ecus
a V7 limited, a regular v7, and a v8 ecu... im convinced its not my ECU. it has to be something funky with my wiring...
Old 03-20-2011, 03:45 PM   #1384
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Is V9 downpipe USDM length ?
Old 03-20-2011, 04:09 PM   #1385
Clark Turner
Member#: 178047
02 WRX STI Spec C
I already told you how to fix the flashing cel.
C
Old 03-20-2011, 05:24 PM   #1386
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
C
is this to me? and what?
Old 03-20-2011, 09:48 PM   #1387
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Unplug your PCV connector. The JDM motor does not use it and your 04 has it. Sometimes you could also have a Loop back plug put in the connector if you have an aftermarket inlet pipe.
ok so i assume u meant this...
heres the thing... i know the 04 wrxs have this PCV connector, but i didnt think the jdm motor/hanress had it???
i didnt take the intercooler off to check, but it didnt look the same as my 04 wrx usdm setup.
I have the v7 complete engine (engine harness + ecu) and getting the CEL.
here is the pic:
^so thats the v7 motor... shouldnt the gray plug be visible in that pic?
for example, on my brothers 04 wrx, its clearly there:
see pic:
^thats the gray plug ur referring to that i need to disconnect right? well is it located in a different spot on the v7 motor?
(i just didnt want to take the tmic off to check, cus the tmic is a PITA to put back on)
Old 03-20-2011, 09:57 PM   #1388
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
This is called vent sensor in the APS literature.
Old 03-23-2011, 11:15 PM   #1389
moonme1017
Member#: 238535
2004 04 WRX
Flat Black
Clark,
I read earlier how you said the 68HTA is a step backwards, i'm not arguing, however, I have already purchased one and it arrived yesterday. I'm curious as to why it is a bad decision, and will send it back if i am able, however, i think i am stuck with it now. Also, where can i find a good tuner for tuning my motor once i have installed all of the upgrades, I don't know of many places that will do Open source tuning.
Thanks.
moonme1017 is offline   Reply With Quote
Old 03-23-2011, 11:31 PM   #1390
Clark Turner
Member#: 178047
02 WRX STI Spec C
The Reason i say that is performance and power. When I modify a car and tune it, I want it to make more power so the car is faster.
As for the guy with the flashing cel, You have to remember you are running an 02/03 style ECU on a 04 WRX car. The 02 does not have that sensor at all. Unplug it.
C
Old 03-24-2011, 07:39 AM   #1391
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Also, even a V9 does not have this sensor, in a JDM car, although the USDM Sti 04+ have it.
Also, that info about the V9 downpipe being USDM legth is based on a one-off situation, mine is still JDM short length.
I only found on the web mention of one case of a long OEM JDM V9 downpipe and it looked like somebody had already modified it.
Old 03-24-2011, 07:50 AM   #1392
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
V9 dp IS usdm length
<---V9 Spec C owner
Hyper is offline   Reply With Quote
Old 03-24-2011, 10:19 AM   #1393
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
V9 spec C here too.
Did your downpipe come with that weird extra silencer box at it's outer end?
Mine looked normal and short. I will find out in couple hours for sure. I hope I'm wrong..
Is the thermostat for a different temperature for the JDM?
What's a normal temperature, idling in 40 degree weather?
I want to check it with the OBDII connection, to make sure what I'm running, to diagnose how healthy the engine is.
Does the Spec C get a different exhaust manifold, compared to a regular V9 Sti twinscroll?
Old 03-24-2011, 10:28 AM   #1394
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I think it did
I ditched it the moment I got invidia DP and cut the bellmouth part of the stocker
Spec C/RA difference is blueprinting, and few other bits like cams/turbos/IAT in manifolds...
headers/uppipe is identical to normal twin scroll, which is a beautifull piece
Old 03-24-2011, 10:41 AM   #1395
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
So far I came up with:
Ra has A/C, which mine has as well.
I thought that S203, 204 have blueprinting.
Turbo is VF36, which in the FAQ is mistakenly described as "Titanium compressor", while it is Titanium Aluminide turbine and shaft.
My exhaust manifold does not have the normal metal heat shielding, but is wrapped.
I read that once you remove the shielding, the twinscroll manifold looks just like a set of headers, but I have also seen headers that were said to be "spec C copies" and had no metal shielding.
I was wondering if they ditched the shielding for weight savinds.
I know of the temp sensor in the manifold
I thought that the Sponaugle table showed that the cams were the same with the Sti, but the heads receive additional hand porting.
Old 03-24-2011, 11:04 AM   #1396
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
VF36 is not titanium, it's just BB
VF42 has the titanium shaft you are referring to, which is found on S203/4 cars
previous owner could've taken stock HS off and wrapped it (which is pointless)
cams are purely speculation, I can not know for sure
we did compare V8 RA and V9 RA cams and profiles were different
Old 03-24-2011, 01:17 PM   #1397
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
Thumbs up Its all much easier than your making it. Put your hands on it and look closley.
Guys with issues using the JDM accessories see this post from this thread-
http://forums.nasioc.com/forums/show...postcount=1250
Folks wondering about the wiring details go to-
http://forums.nasioc.com/forums/show...1&postcount=21
If you know/own ej207's join the club linked below and share your knowledge-rather than add good tech info in a thread arguing a moot point.
http://forums.nasioc.com/forums/group.php?groupid=123
02 Scoob-TN is offline   Reply With Quote
Old 03-24-2011, 04:28 PM   #1398
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
C
not trying to beat a dead horse- when u say 02/03 ecu i assume u mean JDM... i understand the v7 were on the bugeyes that didnt utilize the PCV. Only the 04+ did i believe... but if im running a complete v7 motor, (which shouldnt have hte PCV) how am i running into this problem? there is nothing to unplug. unless im really slow and stupid, i just dont understand... The chassis and harness is the 04 WRX. as well as the stock 5 speed. the motor, ecu, jdm harness is ALL from the 02-03 v7 spec c- so isnt the pcv (or lack thereof) PART of the JDM engine? in which case i SHOULDNT have this problem? I tried to PM you clark- but says u arent recieving...
Old 03-24-2011, 04:37 PM   #1399
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
im a wiring tard... in one of the pics you say u have to repin the AC connector- right now mine is unplugged cus the USDM is just one wire, and the JDM is 3. Got any pics on how to do this?
Old 03-24-2011, 05:17 PM   #1400
02 Scoob-TN
Member#: 176010
No remote viewing ability here, post picks of what all you got and we can help point you in the right direction.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
