Old 03-24-2011, 05:32 PM   #1401
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
No imobilizer on a JDM V9, right?
Edit: I found out later that there is no immobilizer on this version, for a Spec C. I also saw a regular Sti V9 with immobilizer feature. The first sign is that it will not release the fuel pump for priming.
Old 03-24-2011, 11:45 PM   #1402
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
I am liking the sound of the 207 more and more. The ease of wiring into my 05 WRX makes this very appealing.
Now I just have to decide on what to get, v7 or v8...
I am thinking a v7 Spec C if I can find one.
181stLeader is offline   Reply With Quote
Old 03-25-2011, 10:57 AM   #1403
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
if you have a transmission that can handle lots of power down the line, than i say get a V7 and than get a nice turbo like a gt3076 somewhere down the line.
If you don't have the transmission and funds for the larger power output and looking for a great daily driver that you can have installed and forget it about it, than the V8 already comes with the twinscroll setup vf37 is a great option, great transient boost response etc.
scoobystas is offline   Reply With Quote
Old 03-26-2011, 12:54 AM   #1404
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
im running a V7 in my 05 wagon. i am due for inspection in two weeks. anyone in Jersey here tell me how to get my car thru inspection????
gingertooth is offline   Reply With Quote
Old 03-27-2011, 02:28 PM   #1405
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
V7 ecu may or may not pass. V8 is guaranteed to not communicate. Find a local with a USDM 05 ecu and just use the "force pass inspection" option before flashing it.
Old 03-27-2011, 02:33 PM   #1406
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
v8 ECU here. Passed in Indiana yesterday. Read just fine.
fellstar is offline   Reply With Quote
Old 03-27-2011, 02:37 PM   #1407
jemiesranova
Member#: 278003
2011 Subaru Impreza
blue
hard work once it ....
jemiesranova is offline   Reply With Quote
Old 03-27-2011, 08:45 PM   #1408
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
maybe its just Massachusetts than. I worked at a dealer and the tech tried everything and he couldn't get the inspection machine to communicate with my ecu. Guy with screenname "crazymikey" used to drive a wrx with a ver7 swap and told me his ecu would communicate and he passed mass inspection with it.
But just to be safe, have usdm ecu handy. You can even pick one up at a junk yard or something along those lines.
Old 03-27-2011, 10:55 PM   #1409
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
i passed maryland inspection with my V8 ecu. and i'm keeping my usdm ecu just in case. but upon thinking about it, what happens when the car has a ia performance avcs wiring kit installed, and you plug in the usdm ecu? does it read any kind of error or anything? or can i just drop it in and use the force readyness function. i'm not really that concerned since i already passed and it good for two years, just wondering i guess.
lil'redwagon is offline   Reply With Quote
Old 03-28-2011, 09:56 PM   #1410
nedalrabadi
Member#: 244358
1996 impreza
orange & black
ok
i damaged 2 pistons on my jdm v8 swap
any good piston choice other than stock ?
nedalrabadi is offline   Reply With Quote
Old 03-28-2011, 10:16 PM   #1411
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Look, take a look in the built engine forum. All kinds of power, right?
But then take a look at how long those engines last, they have polls.
Average: 20-40 000 miles.
Now take a look at how long the EJ207 last.
If you don't care how long the engine lasts, build yourself an EJ257, for whatever power you want.
If you want an engine that lasts, leave the internals alone and stay within the generous power availabillity that the EJ207 has.
From what I'm reading, it seems that it is much more difficult to build for reliabillity and some power than to build for power.
The only way that is somewhat proven is to stay with a factory unit.
Reliabillity has everything to do with the conditions at engine assembly, and factory assembly line conditions are hard to beat.
So, in your case:
Get a factory pre-assembled 207 short block, as per the link the guy posted 2-3 pages ago. That is your best bet for a reliable build and to limit the involvement of local shops.
Old 03-28-2011, 10:33 PM   #1412
nedalrabadi
Member#: 244358
1996 impreza
orange & black
So, in your case:
i know what you mean
but i can't afford a block right now and the ej257 isn't available were i live
i'll try to get new internals from the factory, but they aren't forged,
plus are very expensive
so i thought i could do for a while with the after market internals ( the best i find )
i'm looking for an answer about the best of the worst
Old 04-02-2011, 08:43 PM   #1413
ovat83
Member#: 264454
2005 FP RED STI
HI ALL,
I have a 2004 JDM v8 EJ207 STi With FP Red , 1000cc DW , HKS UPPIPE , EWG 38mm , Twin pumpers + more in progrees and should be finished with in the month.i will post dyno results onces tuned so everyone here can get an idea.IMO with the factory VF35 that was on there and only a gutted 3'' DP and TBE was better than any 2.5L i raced against and won.Once my boost came on it stayed on untill 7-800-8000ish and the car still had more in it.I would never go with the 2.5L even if i rebuilt it due to once you split it it will never have the same reliability as a 207 Forged steel piston / rods,forged aliminium crank shaft.
ovat83 is offline   Reply With Quote
Old 04-03-2011, 12:27 AM   #1414
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Originally Posted by ovat83 View Post
HI ALL,
Did you have a vf35 or vf37?? I'm pretty sure the vf35 came with the Australian ej207 and not the JDM 207. When you say you held boost to almost 8k, how much boost we talking like 13lbs??
Old 04-03-2011, 12:48 AM   #1415
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
VF35 was fitted on the UK STi models as well.
kayen is offline   Reply With Quote
Old 04-03-2011, 07:29 AM   #1416
gling
Member#: 122654
2002 v8 STI w/ GT30R
2013 GTR & M-Sport 335xi
Gingertooth,
It is hit or miss and it depends on the state. Take scoobystas advice and borrow a USDM ECU as a backup. Flash it with your JDM ECU's ROM and force readiness just to be on the safe side. You may try going in for inspection with the JDM ECU first and if it fails to communicate, then throw the USDM one on and go in again. It's worth finding out if the JDM ECU will pass in Jersey. That way, you don't have to keep swapping out your JDM ECU for the USDM ECU.
I have the same issue in Mass; the emissions equipment in this state will not communicate with the JDM ECU and I have to do what I just described above. However, I used to pass Ohio and Connecticut emissions just fine with the JDM ECU. Hopefully Jersey falls into the latter category in terms of emissions equipment and OBD II communication protocol.
I have not had any issues running the USDM ECU with regards to AVCS as brought up by lil'redwagon. Just stay out of boost and the motor should be fine. I've not seen anything that warrants concern based on my AFRs and/or knock when doing so. Then again, I only have the ECU on for at most a day before getting tested and switching back to the JDM version.
Scoobystas,
Good to see another fellow 207 running around in Mass Hope to see you around some time.
Cheers.
Gerald.
gling is offline   Reply With Quote
Old 04-03-2011, 11:02 AM   #1417
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Originally Posted by gling View Post
Scoobystas,
Cheers.
Gerald.
Yes indeed, i'd love to see and hear that GT30R rip to 8k
Old 04-03-2011, 11:15 AM   #1418
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Gingertooth,
Scoobystas,
Cheers.
Gerald.
i am in texas, and i have talked to my friend down at the local testing station and he assured me the jdm ecu would pass, we will see if he is right come july lol, my only concern with the usdm ecu is the fact that the cam sensors are completely different, how does it run propperly?? just with no cam signal, and since its such a short time it doesnt matter??
seanathanq83 is offline   Reply With Quote
Old 04-03-2011, 11:44 AM   #1419
jam007
Member#: 174706
2008 LGT-B
jam007 is offline   Reply With Quote
Old 04-03-2011, 11:47 AM   #1420
gling
Member#: 122654
Seanathanq83,
I'm not sure about the difference in cam sensors but was under the impression that they were the same. I've driven for more than 100 mi. on the USDM ECU before and have not had any issues. Good luck passing the emission test in Texas. Speaking of which, it'll be nice to compile a list of states that will pass JDM v8 ECUs. Thus far, we have:
Pass
1. CT
2. OH
3. IN
4. MD
Stinkin' 'lil f*kers
1. MA
Feel free to copy and paste the list to keep it alive.
Cheers.
Gerald.
Old 04-03-2011, 02:04 PM   #1421
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Who here have used Tomei AVCS cams?
we've all seen the nice "buy-me" graphs, but I don't know anyone actually using them
we had Cosworth avcs cams in a ej207 but I didn't like them at ALL... non-avcs jun cams ran in another car gave it much wider and better powerband, too bad they don't have avcs version
Hyper is offline   Reply With Quote
Old 04-04-2011, 06:52 PM   #1422
ovat83
Member#: 264454
2005 FP RED STI
Yep, i had the factory VF35 from the AU and uk models on mine and it held 14lbs -15 lbs at night when the temps were cooler untill almost redline.The response and mid range punch was unbeleivable and will be ''allot'' different to drive compared to the FPRED.The VF35 was a great combination to run with the EJ207.I definentely recommend it to any auto X fans out there and daily drivers.
-Ovat
Old 04-10-2011, 07:53 PM   #1423
legacy2003
Member#: 38338
2003 Outback Sdn H6
Quick question, since I don't want to read this whole thread: what spark plugs does a Ver. 7 STI EJ207 take? I am currently rocking the OEM JDM Densos and after 65k miles I should definitely replace them. What are the NGK counterparts that I could just pick up at an Autozone or something, one step colder?
legacy2003 is offline   Reply With Quote
Old 04-10-2011, 10:02 PM   #1424
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
denso ik22 or ngk bkr7eix
fastnoypi is offline   Reply With Quote
Old 04-10-2011, 11:35 PM   #1425
legacy2003
Member#: 38338
2003 Outback Sdn H6
^ Thank you very much!
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
