#1451 | |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 WRX Wagon |
LOL! I think you misunderstand, it's not about his auction price, but the 13K for a used ej207.
#1452 |
Member#: 10854
Vehicle:2002 Sedan V8 ej207 Dom 3 XT-R, 400WHP |
there you go. i got mine from an importer in canada as well. (but they ship to united states addresses from virginia.) also with a 30 day warranty and a start up warranty. the warranties are a good thing considering you can't easily do a conventional compression test on a motor with it out of a car. a leakdown test can be done, so i'd ask them to perform one before shipping out. they probably won't though, or they'll tell you they performed all those tests before pulling the motor, but don't have the results from that motor. that's why a startup/30day warranty is important. i got mine from J Spec Auto for $3900 with *NO* intercooler, just the motor, harness, accessories, ecu, turbo, and downpipe. i already had the 6 speed in my car before the motor, but i think i paid around 3K for the 6 speed swap. the last thing i'd mention is that i'd stay away from motors with signs of aftermarket tinkering. things like, aftermarket intercoolers, intercooler hoses, pulleys, a block-off on the bov hose, etc. gauges are ok, depending on which ones. i'd stay away from a motor that had bungs welded in the headers, for example, as that would imply that the motor was tuned. but things like oil pressure, and boost gauges are ok with me. these are pretty stout motors that can be driven hard, but they're sensitive to a clean tune. basically, you're looking for an unmolested version of the motor - same as if you were shopping for a used sti here in the states. |
#1453 |
Member#: 10854
yeah, and i'd also stay away from anyone who bickers with you in the pre-purchase communication stage. you need good communication from someone who you're giving a lot of money too. and especially if you have a warranty issue.
#1454 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
JDMracingmotors, talk to Wali.
#1455 | |
Member#: 82745
SCIC
The communication went like this. I asked for a leak down test of all the cylinders, and he said he paid 13k for just the motor, so the engine is fine and it doesn't need a leak down test. Also, he's not going to provide one. Then i said, a regular used EJ207 never sells for anywhere near 13k. That's when he hangs up on me. Would you have confidence in giving this shop/vendor $5,999 plus shipping for that motor and trans? |
#1456 | |
Member#: 107179
Vehicle:2003 WRX, S400SX FMW MBP |
#1457 |
Member#: 15822
Vehicle:1999 WRB GM6 2.12cc V9 Type RA |
please do
I am very interested to see how the cams compare to stock ones |
#1458 |
Member#: 107179
Well, I don't know if I'll be able to give you the comparison you're looking for then because I went from stock ej205 heads to v7 heads and the Tomei cams at the same time. From talking to one highly knowledgeable engine builder he doesn't feel these are that much larger than the stock ones. We will see how it turns out - the turbo is an HTA Green so it should be a decently quick and fun ride.
#1459 |
Member#: 101474
Vehicle:2004 "Insert Something Witty Here" |
Anyone have a suggestion for a vendor for an E-tune for a ver8?
#1460 | |
Member#: 122654
NESIC
Vehicle:2002 v8 STI w/ GT30R 2013 GTR Premium |
Have you talked to local tuning vendors such as DSG and EFI? I know EFI has my map and could tweak it for your setup. The main issue with your swap is the stock motor's timing, which is based on RON 100+. Worst case scenario is you drive your car absolutely out of boost to a tuner for a proper tune. I'd recommend my tuner but I don't know if he is tuning on a regular basis anymore. Gerald. |
#1461 |
Member#: 101474
I plan on having my final at EFI. I need something for the 2.5 weeks before the tune and the 236 mile drive to EFI.
It's cheaper than towing. |
#1462 |
Member#: 10854
get in touch with Clark Turner. he seems to be the authority on the ej207. he can definitely send you a tune that'll get you to your tuner.
#1463 |
Member#: 101474
#1464 | |
Member#: 264454
SCIC
Vehicle:2005 FP RED STI Blue |
Hope this helps |
#1465 | |
Member#: 97984
Vehicle:2002 MBP WRX Wagon EJ207+VF37+4.11+DCCD |
#1466 |
Member#: 46135
Glad to help. I got a bit of help yesterday, because I could only read numbers off that material.
The timing belt replacement interval is at 100 000 Km, making it 62 000 Miles. |
#1467 |
Member#: 122654
NESIC
#1468 | |
Member#: 101474
#1469 |
Member#: 218308
Vehicle:88 Rx7 2500hd |
#1470 | |
Member#: 50586
SCIC
Vehicle:2004 凸(ಠ_ಠ) |
That's weird why so soon on the EJ207? The EJ205 says to change at 105K miles. I'm guessing the belt and pulleys only needs to be replaced, not the water pump? |
#1471 |
Member#: 185030
AKIC
Vehicle:2013 STi SWP Ltd. Slowest STi evaaaar |
I heard that these motors are on beast mode from the factory.
#1472 |
Member#: 50586
SCIC
#1473 | |
Member#: 46135
I recall from a Lotus Forum that Lotus had to meet a regulation when selling cars here in US that the timing belt must not need to be replaced more often than 100 k miles. They could not do that, so the owners of Lotus Esprit got free belt replacements by the dealers upto 100 k miles. With this in mind, I went to see what differs between the US and JDM assemblies, knowing that the JDM revs more and the US lasts longer. So I found all the parts in the timing belt assemblies. The part numbers for my 05 spec C match 05 US WRX part numbers, except: The water pump has the same part number with 08+ GR body style WRX, not Sti. The reason here is that my spec C comes with no oil cooler, but radiator, therefore you need a pump without the third water outlet, that goes to the cooler. The 08+ WRX came with no cooler. So, the only thing left and the only thing different in part number is the belt itself. The JDM belt has a different part number than anything sold in US. But the translation that japanparts has is timing belt and label. In the Spec C owners manual (in Japanese), there is the drawing of a car and two little arrows. One pointing at the timing belt area and one pointing to a small label on the underside of the hood. Now, if this were to be considered by Subaru a "Timing belt and Label Kit",you could possibly just have the same old timing belt like in US, add a replacement mileage label and then change the part number, confusing everyone. But when I spoke to a friend that is parts manager at the dealer, he told me that Subaru part kits always begin part numbers with X. This does not begin with X, so it is not a kit. Then I went to look at the Sti pink timing belt. This has the same part number for all EJ207 and 257. But, some of the sites that sell to the US, give the replacement warning to replace this every 60 K miles. So, I've asked about this and got an answer that "it's a good idea to replace the pink belt at 60K". My theory, after all this: There is an "OEM softer" belt, for US that lasts longer, possibly meeting US timing belt regulations. There's an "OEM hard" belt for JDM and Sti pink for US that possibly supports higer RPM better, but gets replaced more often. Last edited by Vlad; 04-16-2011 at 05:24 AM. |
#1474 |
Member#: 174706
SCIC
Vehicle:2004 WRX WRB EJ207 6mt, 08 Spec B |
Vlad, I think we can all appreciate the research and time you put in for this information as I was wondering this myself.
#1475 |
Member#: 26568
NESIC
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
hmmm....what makes it even tougher for those of use with swaps, is when an engine is sent to you from canada or where ever, it may look mint but there is just no way of knowing how many miles are on it. I've driven close to 15k on mine, its from an 03 jdm sti...so in theory it could already have at least 60k. Could have a lot more, my wrx is an 03 and i've put 127k on the body. Who knows what sort of commute the original owner of my motor had.
| Thread Tools | |
| Display Modes | |
| ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain | 2 | 02-26-2011 07:29 PM |
| Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain | 10 | 06-03-2010 04:53 PM |
| JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
| 08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
| Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain | 21 | 10-17-2005 01:56 AM |
