#1476 |
Member#: 10854
Vehicle:2002 Sedan V8 ej207 Dom 3 XT-R, 400WHP |
^ that's why i changed my belt before the motor went in.
#1477 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
#1478 |
Member#: 46135
#1479 |
Member#: 22605
Vehicle:2002 JDM STI/WRX WRB |
Trying to decide on my turbo, just wish there were more people out there using some of the twin scroll options so we could compare. I've narrowed it down to these two.
GTPS05T-73HTA which is a 54lb/min thrust bearing Blouche SC46 (TS polka pickle) that is 47lb/min Garrett BB CHRA I've been leaning to the Blouche due to all of the great results over on scoobynet. But the larger GT Pumps turbo is interesting as well, especially after watching this vid (not sure if its the TS model or SS) Decisions decisions ![]() |
#1480 |
Member#: 97984
Vehicle:2002 MBP WRX Wagon EJ207+VF37+4.11+DCCD |
Mine came with "25k" on it but taking a proactive approach, I just replaced the timing belt, idlers, water pump + thermostat, and accessory and AC belt right off the bat. It cost an additional $500... was it worth it? I dunno.
That $500 might include some other stuff that I bought at the same time as well. I bought a gates racing belt (and everything else) sourced for me by Rallispec in NJ. I'm not sure what PN they gave me, but I trusted they'd give me the right parts for my JDM motor. It's worked without a hiccup thus far (knock on wood). But I'm guessing this gates belt falls under the same 60k schedule. |
#1481 | |
Member#: 244358
International
Vehicle:1996 impreza orange & black |
i think i'm gana get one of these but i can't decide on the power level cuz i don't know if they power rate at crack or wheel i must find out some how cuz if it's on wheel it's my choice of a turbo i sent them but no answer now for the 2nd week http://www.litchfieldimports.co.uk/l...roll_turbo.asp |
#1482 | |
Member#: 22605
Check out this thread on them. http://bbs.scoobynet.com/scoobynet-g...oll-turbo.html From what I've seen, they are nearly identical performance with the Blouch apart from the few turbos which are larger and in turn have a lot more lag. |
#1483 | |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 WRX Wagon |
Have you considered the Tomei TS? http://www.tomei-p.co.jp/_2003web-ca...m7760TS-e.html |
#1484 | |
Member#: 22605
#1485 | |
Member#: 46135
They looked like extra black connectors in the harness. |
#1486 |
Member#: 221364
Vehicle:2002 Wrx EJ207 Ver 8 Wrb Dccd 5 speed now! |
I'm looking at the kelford 264 cams for my ej207. What kind of difference is there untuned?Where did you buy them
#1487 |
Member#: 22605
Another option is the Moore Performance setup with EVO turbos. Very tempted by this but the price is high considering everything that needs to be done. I haven't been able to find solid numbers, but $2-3k is my guess. But damn would a EVO 9 turbo on E85 be awesome. Bout to call them to get a better idea on pricing.
#1488 | |
Member#: 107179
Vehicle:2003 WRX, S400SX FMW MBP |
The car felt great even with significant AVCS problems so I can't imagine they are hurting any of the motor's grunt but I can't give you any sort of valuable information yet. These pictures will help you understand why: Passenger side intake cam pin: ![]() Passenger side AVCS cam gear: (sorry, this one is a bit blurry) ![]() Both sides were messed up (though passenger more significantly) due to the owner of the now deceased shop using an impact gun & 120 psi compressor to tighten the cam bolts. We finally discovered this 2 weeks ago, which is why the car is currently down, but the car has been running static and unchangeable AVCS (28* passenger, 4* driver) since initial start. So, I am sure the car is going to feel drastically better even though it felt smooth, believe it or not, and strong already. It did hyper-lope at idle though, haha. |
#1489 |
Member#: 50586
SCIC
Vehicle:2004 凸(ಠ_ಠ) |
Hey what kind of gas mileage are you guys getting with the EJ207? I'm currently getting about 14MPG commuting to work and staying off boost as much as possible. Just want to know if that's normal or if I should get retuned?
#1490 |
Member#: 205280
Vehicle:2012 Jeep Wrangler Bright Silver |
My version 8 with the jdm 6 speed gets over 20 when.Im being nice.
#1491 |
Member#: 26568
NESIC
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
To my surprise this 2.0 is a thirsty beasty when compared to the ej205, on which I normally average over 25mpg. With this setup, I'm at about 20mpg with mixed driving. Its much torquier down low, revs faster, builds boost quicker, so all these things add up to more fuel being used. Could also be my tune as well, my open loop transitions mirror the jdm rom, which puts you into open loop much much sooner than the stg2 accessecu rom i ran with the ej205.
#1492 |
Member#: 226571
Im currently doing an ej207 v8 swap to my bugeye and would like to know what stock boost i should be looking out of the v8 jdm computer thank in advance
#1493 |
Member#: 10854
for gas mileage, i'm usually between 16-19mpg.
#1494 |
Member#: 26568
NESIC
#1495 | ||
Member#: 50586
SCIC
Thanks for all the replies looks like I will be needing a re-tune, I imagine that my car is running rich since the previous owner had it tuned to his specific CAI, and me having a different brand CAI. My wideband shows it's running between 14.4-14.8 during highway cruising just not sure about how it's doing otherwise. |
#1496 |
Member#: 158579
Vehicle:2002 Boxster 94 Legacy Rally Car |
I'm getting 27 mpg on the hwy, 24-25 normally, and 20 if I am hammering it a lot.
#1497 |
Member#: 120237
Vehicle:2004 WRX WRB |
I picked up a V7 Ej207 for $1,000 knowing the heads were sticking come to find out the shortblock is all rusted too. Im waiting to hear back from the machinge shop but, Im looking for some help building this thing please chime in on parts and my options. My goals are a reliable 400whp and decent spool on e85. I have the turbo and stuff all figured out .82 rotated 3076r.
I dont want to take shortcuts on the motor build. I was going to do the heads with SuperTech .5mm bigger inconel exhaust valves SuperTech .5mm bigger black nitrite intake valves SupetTech dual spring Ti Retainers I want your guys help with the shortblock. Im even considering an ej22t shortblock. I want the most reliable and well built set up without going insane with stuff i dont need because after all I only want 400whp on e85. Thanks in advance, Taylor |
#1498 |
Member#: 46135
Amazing:
I'm waiting to be tuned, for now have cam2 100 in the tank. I've looked at Ecutek Delta Dash and the multiplier is at 8. Knock correction went to 3.5 |
#1499 | |
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
The valves are a big mistake in my opinion. Leave it all stock. There is no advantage of the valves. Clean up the heads, Check everything out and use them. Same with short block. You can get some forged pistons while you are there. stock rods are fine but if you want, Get some decent rods as they are cheap. Stock bearings are fine. 400whp is low for that turbo and E85. 450 would be easy. 500 is doable. In short, Clean up the heads, Pistons, rods, bearings, New oil pump, Belt,tensioner and all idlers. Slap her in and enjoy C |
#1500 |
Member#: 15505
TXIC
Vehicle:2002 JDMV8 STI Wagon |
I average about 19.8 mpg overall with the lowest being 16.6 mpg and highest being 22.7 mpg. Only mods are catback and detuning for 93 octane fuel.
| Thread Tools | |
| Display Modes | |
| ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain | 2 | 02-26-2011 07:29 PM |
| Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain | 10 | 06-03-2010 04:53 PM |
| JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
| 08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
| Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain | 21 | 10-17-2005 01:56 AM |
