Old 09-30-2011, 10:16 PM   #1901
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Originally Posted by i2cou4u2 View Post
I don't know how I lived without it!!!
Couldn't have said it better. I have had mine for the past 2 1/2 years and I have never once regret having a 207
kayen is offline   Reply With Quote
Old 09-30-2011, 11:07 PM   #1902
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Just got mine back yesterday, block and heads completely refreshed. Its going to be to tough to baby it from scratch though the break in process, after close to 10 dependable years of smacking redline.
fastnoypi is offline   Reply With Quote
Old 09-30-2011, 11:23 PM   #1903
jam007
Member#: 174706
2008 LGT-B
I love this motor, it purrs at idle and just feels solid.
jam007 is offline   Reply With Quote
Old 09-30-2011, 11:53 PM   #1904
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
About the rear O2 sensor in an EJ207, I know Clark posted at one point that it has it's use in a 16bit application.
Mine is offset out of the pipe, part of the Prodrive midpipe. It still is functional, it's moved out of the stream with a longer bung.
I was reading the voltage from it at idle and the graph is wavy, between close to 0 to .9 volts.
I know that for EJ205 it's supposed to be stable .3-.4 volts.
Maybe we can get an input about what it's supposed to be for the EJ207?
I've read before that on '02-'03 cars it does not do much. I've read that on 32bit cars it can affect the fuel trims.
I'd like to get some info about EJ207..
Edit: The testing procedure for the EUDM EJ207 is to warm it up to 158 degrees (coolant), then rev it to 2-3000 rpm for minutes, then do a reading.
Apparently, it's supposed to fluctuate in reading. If it's got constant 0.2-0.3 volts, they want you to start checking the harnesses.
I guess mine may be fine..
Old 10-01-2011, 12:05 PM   #1905
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Intersting, I don't have mine. I'd like to know if it's needed also. I only have the one in my downpipe.
LIQUIDSK8S is offline   Reply With Quote
Old 10-01-2011, 01:54 PM   #1906
Clark Turner
Member#: 178047
02 WRX STI Spec C
Its a 1 volt switching 02. Its normal for it the voltage to go up and back.
C
Clark Turner is offline   Reply With Quote
Old 10-01-2011, 01:56 PM   #1907
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
C
Isn't it just for emissions?
Old 10-03-2011, 12:44 AM   #1908
i2cou4u2
Member#: 246455
2004 WRX Wagon
For everyone running the ej207, what oil is everyone running in their motor? I am running Castrol Syntech 5W-30 full synthetic with a Fram oil filter. It has only seen about 700 miles with that oil in it. Does anyone have any experience with that oil?
Thanks
Tom
i2cou4u2 is offline   Reply With Quote
Old 10-03-2011, 05:44 AM   #1909
Mohammadov
Member#: 110160
2005 STI+JDM V7 Swap
Thanks
Tom
am running K&N Oil filter and 10-W60 Liqui Muli.
Mohammadov is offline   Reply With Quote
Old 10-03-2011, 08:42 AM   #1910
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
That is pretty thick, hopefully you live in a place like Arizona that is super hot.
Old 10-03-2011, 09:43 AM   #1911
Mohammadov
Member#: 110160
hehe,i live in Middle East..Jordan.yes its very hot in summer.
but it also works good in winters.
been using since 2007
Old 10-03-2011, 10:01 AM   #1912
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Yeah I would say it would be quite hot in Jordan haha. How are Winters like in Jordan, still must be decently warm? Atleast compared to Michigan they must be.
Old 10-03-2011, 10:51 AM   #1913
Mohammadov
Member#: 110160
Jordan's winter temp average is 50F..maybe warm for u?
Old 10-03-2011, 10:58 AM   #1914
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
yeah that's warm in comparison, as average for us is around the upper 20F.
Old 10-03-2011, 03:07 PM   #1915
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
Shell Rotella T6 year round with a Purolator Pure One filter.
lil'redwagon is offline   Reply With Quote
Old 10-08-2011, 01:24 AM   #1916
i2cou4u2
Member#: 246455
2004 WRX Wagon
Has anyone noticed a ticking sound coming from their EJ207 from the drivers side of the motor? Not super loud, but definitely louder than the passengers side.
Tom
Old 10-08-2011, 01:26 AM   #1917
Clark Turner
Member#: 178047
02 WRX STI Spec C
valve lash is probably out. If its a V7, then its likely number 3 cyl scuffed. I would have to hear it.
What oil you running?
Old 10-08-2011, 03:15 AM   #1918
i2cou4u2
Member#: 246455
2004 WRX Wagon
It is a V8 engine. I am running Castrol Syntech full synthetic 5W-30 oil. Has about 800 miles on it. I am going to change the oil tomorrow to a better oil and most likely 5W-40. If a valve is bent...would it make a ticking sound like that? Also what do you mean a cylinder is scuffed?
Thanks
Old 10-08-2011, 05:09 AM   #1919
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Gotta say I love my ver8, granted its fully built but 20-21 psi out of my s200sx-56 makes ~450whp. It spools so.nicely and has so much down low torque. Also doesn't hurt that it can take a 2011 cbr600rr in the 1/4 mile, lil more and I will be in the 10's. Not using the avalible FFS :-)
seanathanq83 is offline   Reply With Quote
Old 10-08-2011, 11:15 AM   #1920
Clark Turner
Member#: 178047
02 WRX STI Spec C
V7s are known for scuffing the cyl as the Cyl to wall clearance is to tight using Forged pistons. Its a low to mid range noise clack clack clack at idle
A TICK or high pitched sound could be a valve out of lash or it could be timing belt tensioner has gone. This will also make a tick.
Good choice in oil.
Thanks
Old 10-08-2011, 09:54 PM   #1921
i2cou4u2
Member#: 246455
2004 WRX Wagon
Good choice in oil.
Clark,
I live on Southern California, do you think I should change from 5W-30 to 5W-40?
Old 10-09-2011, 03:48 PM   #1922
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
The subject of oil periodically comes up in this thread.
I have decided to try to help out.
I have the owner's manual for the 2005 EJ207 equipped cars, including the spec C. The manual, like all is for all impreza range and... obviously is in Japanese.
I could not find a way to post a PDF file on photobucket, so took a photo of the screen and will post that.
I will provide a base translation, if others can go further into details, do that.
This is only an owner's manual ...
Old 10-09-2011, 03:49 PM   #1923
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Here's a relevant page about temperatures and oil, similar with the one in the US manual
The lower temperature index for oil is for "Other than a turbo car"
Old 10-09-2011, 03:58 PM   #1924
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Says:
Center section "engine oil", to the left
5th row from top "Subaru motor oil" SM 5W30
6th row from top "subaru Motor oil" SM 0W20 (Use possible only besides a turbo car )
7th row from top "Subaru Motor oil" SL5W30
8th row from top Freedom
9th row from top ELF 10W-50 Les Pleiades
I hope this helps.
Old 10-09-2011, 04:05 PM   #1925
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
So 0W20? Is recommended for the EJ207? Seems too thin to me
iNfEk is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
