Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 07-17-2008, 02:16 PM   #176
Clark Turner
Member#: 178047
02 WRX STI Spec C
LOL. Yeah.. I know this personaly. I have seen them fly through the top of the block! LOL
CLark
Clark Turner is offline   Reply With Quote
Old 07-17-2008, 02:34 PM   #177
litowrx
Member#: 132418
2004 EJ207
are all EJ207 created equal??
i have a v8 STi, EDM...it uses a single scroll turbo unlike the JDM version...
the power diference is 265hp quoted for the EDM and 280ho for the JDM...
but are the engines the same?
thanks!
what can you guys tell me about v8 EJ207 STi motors?
litowrx is offline   Reply With Quote
Old 07-17-2008, 02:45 PM   #178
Clark Turner
Member#: 178047
02 WRX STI Spec C
Your motor uses small port heads. JDM motors use big port heads.
This subject has been talked about for 6 years. Do some searches and you can learn alot about the differences.
Clark
Old 07-17-2008, 05:13 PM   #179
litowrx
Member#: 132418
2004 EJ207
Clark
id love some help... ive search and search but couldnt find anythig
in general do you think is as goos as the jdm ej207?
Old 07-17-2008, 05:18 PM   #180
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
http://forums.nasioc.com/forums/show...m+vs+jdm+ej207
fastnoypi is offline   Reply With Quote
Old 07-17-2008, 06:09 PM   #181
Clark Turner
Member#: 178047
02 WRX STI Spec C
Your edm motor is not as good as the JDM STI. ITs better then the WRX motor though.
Clark
Old 07-17-2008, 08:21 PM   #182
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
what about v8 ADM to JDM sti engine internals??
wrxsti.l is offline   Reply With Quote
Old 07-17-2008, 10:54 PM   #183
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Originally Posted by Big_DeWeY View Post
I'll be able to tell you in the not so distant future
please do
mxpunk is offline   Reply With Quote
Old 07-17-2008, 11:36 PM   #184
GeneralTJI
Member#: 152680
I Parted out WRX
for my Pilots License :)
Where the hell did I get the idea 205 Rods are forged??
I need to start building that empty block very soon! lol
GeneralTJI is offline   Reply With Quote
Old 07-18-2008, 12:00 AM   #185
Clark Turner
Member#: 178047
02 WRX STI Spec C
ADM motors are also lower power and small port heads.
CLark
Old 07-18-2008, 04:10 AM   #186
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I thinks you guys need to view that "Head Ports Comparison" thread. hahaha
but I come close to the EJ207 with my setup. My 2.2L makes up for the AVCS. My EJ22T is allowed to rev to 7500rpms. I am still running the factory EJ22T oil pump. I run an EVO3-16G-8cm. Plenty of power and great spool. The boost map is set up aggressive with 50% throttle to hit 18psi of boost and slowly up as you roll onto the throttle all the way to 22psi peak with WOT. Really responsive tune with this boost/wastegate setup.
Next up would be an engine rebuild with STi rods, CP pistons, Spec C cams and valve springs. I won't be using AVCS, that's mainly for lower RPM torque. I have 2.2L already.
FuJi K is offline   Reply With Quote
Old 07-18-2008, 04:25 AM   #187
Clark Turner
Member#: 178047
02 WRX STI Spec C
Your motor sounds nice man.
I ran a Spec C V limited EJ207 engine for a few years. With various turbos and intercoolers. Final setup was a GT30R with FMIC with nitrous. That motor was so smooth that you could drive down the highway at 6000 rpm and not even realize you needed to shift. Its hard to explain. Just a super smooth, rev happy, strong motor that pulled to 8000 rpm.
You cant beat a JDM 207 engine. I wish I had mine back over my Current 2.5block with Spec C JDM heads and 40R.
Clark
Old 07-18-2008, 08:42 AM   #188
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
[quote=GeneralTJI;23023271]Where the hell did I get the idea 205 Rods are forged??
The USDM 2.0 ej205 has forged rods... The pistons are cast and of course the crank is also forged.
My jdm ej207RA motor (serial #ej207dw4ej) came out of an 02' sti limited car. I bought the entire drivetrain also.
The 02' jdm motors have a unique forged piston that was specific for the 02' motor only. The piston top has deep valve reliefs on both sides of the crown.The crankshaft has dual chamfered (beveled) bearing oiling holes and is a beautiful piece. The rods however are very similar in design to the ej205...
My original plan years ago was to stroke the motor (JUN 2.2 kit) but after tearing the motor down and inspecting everything I really liked what I had seen and decided to keep the shortblock as is with only a few tweeks. Since then I have beaten the living poop out of this motor and she still has the same compression #'s as when new.
The big port heads are now modified along with custom grind Tomei AVCS cams and I'm running an AVO 600 turbo with tial 44mm ext. wastegate. She is waiting to be tuned with my new HKS Vpro standalone ecu.
Tom
Thomas Ruble is offline   Reply With Quote
Old 07-18-2008, 12:41 PM   #189
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
how about an ej22 on ej207 heads?
Old 07-18-2008, 01:52 PM   #190
GeneralTJI
Member#: 152680
I Parted out WRX
Thats what I always understood.. but Clark says otherwise...
Old 07-18-2008, 02:00 PM   #191
Big_DeWeY
Member#: 37078
95 L
Blue-ish
id didn't think there were either. I'll find out in a hot second though...brb
Big_DeWeY is offline   Reply With Quote
Old 07-18-2008, 09:24 PM   #192
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I think it'd be awesome
but it's Clark's posts on how smooth the motor is, that I still haven't touched mine and will just run it till it fails (knocks on wood)
and moreover, that thing DOES take some serious beating... I've had tenths of times of 2+ bar trips
Hyper is online now   Reply With Quote
Old 07-19-2008, 12:00 AM   #193
redrex2002
Member#: 118915
2002 wrx
srp
i am trying to decide wether i want to stay factory or go built
factory option v7 ej207 and 20g
built option ej22 worked over to the 2.35l with v8 heads and gt52 maybe 30r
what do you guys think?
redrex2002 is offline   Reply With Quote
Old 07-19-2008, 01:03 AM   #194
litowrx
Member#: 132418
2004 EJ207
Clark
Thanks man... ive done some research about my engine...
i just have a question...do you have any idea of what type of injectors are fitted? are those the normal 565cc side feed pink injectors or these are top feed?
and one very last question and i swear i'll stop asking questions
im planning to upgrade my vf35 turbo next year... i want to get full boost no later than 4000 rpms...
i'll do 750cc deatshwerks injectors and big evo III 16g or td05 18g (td05 cause i have a EWG)
wich one is the better turbo? 16g or 18g...i think the flow almost the same but have no clue about wich of the 2 will make more power
thanks!
Old 07-19-2008, 01:06 AM   #195
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
if you want to enjoy your car right away and have reliable fun go with the v7/20g setup, you wont be dissapointed.
if you have a spare car while getting a built 2.35 powerhouse for more $$ then go for it.
Im currently running a v7 with an PE1820F, its been a great setup but not as happy as it could be on 91pump without injecting water/meth or moving back east with the better fuel.
Old 07-20-2008, 04:13 AM   #196
hally
Member#: 123652
2003 STi Built EJ257
APS SR55 380WHP@20psi
Clark
Clark,
When you say 30R, is that GT3082 or GT3076? What size turbine housing, .63 or .82? What rpm was say 20psi?
hally is offline   Reply With Quote
Old 07-20-2008, 02:57 PM   #197
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
thanks!
Nah dude, you can see the dyno plots from people who run 16g and 18g. 16g's were so overhyped at one point, with numerous people claiming they outflowed STI pinks and crap like that.
I have yet to see a 16g make more power than a vf series given equal conditions however.
18g's seem to make monster power on meth/high octane. I advise you take that route. I know of a guy with an 18g, fmic, meth on his 205 who basically makes the same power as STI w/ gt30r on pump. Pretty insane
verc is offline   Reply With Quote
Old 07-21-2008, 02:49 PM   #198
jmeltzer4
Member#: 73094
02 Subaru WRX
Who is selling EJ207's these days? Gruppe-S doens't seem to stock them anymore
jmeltzer4 is offline   Reply With Quote
Old 07-21-2008, 02:51 PM   #199
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Old 07-21-2008, 03:37 PM   #200
Clark Turner
Member#: 178047
02 WRX STI Spec C
I ran a 3076 with .82 turbine. Full boost around 4000 rpm or so. No letup in power to 7500 rpm or so.
The 205 rods are NOT forged. When you snap one off you can see for yourself
C
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
