Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 11-05-2011, 11:17 AM   #2001
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Originally Posted by secguy View Post
im a little tight on money right now it would be way to expensive to get the v8 twin scroll the jdm intake mani and jdm parts. its just the heads and shortblock assembled.
you really dont need all of that twinscroll stuff, although it is really nice.
Use what you have, single scroll turbo, exhaust manifold and intake manifold. Just delete your tgvs in your risers. Then get a tune. I still recommend a jdm ecu to take advantage of your heads.
fastnoypi is offline   Reply With Quote
Old 11-05-2011, 11:50 AM   #2002
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Hey I have a guy who had ( dont know if he still does) a ver8 ecu, and bother one he gave me the the model number I just never looked also ver7 will work as well hit me up for help I just spent more time than any person should on my whole engine swap fiasco
seanathanq83 is offline   Reply With Quote
Old 11-06-2011, 03:54 PM   #2003
i2cou4u2
Member#: 246455
2004 WRX Wagon
Has anyone had any success/experience with an aftetmarket turbo inlet pipe one their Ver.8 ej207? I was thinking of installing a Perrin inlet pipe.
Thanks
Tom
i2cou4u2 is offline   Reply With Quote
Old 11-06-2011, 05:14 PM   #2004
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
Thanks
Tom
I've got a Perrin inlet pipe on my V7 ej207 if that helps. No issues.
Zaider is offline   Reply With Quote
Old 11-06-2011, 08:13 PM   #2005
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Aps hard inlet here. Works nice.
Old 11-06-2011, 09:14 PM   #2006
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Early Perrin inlets were like 3ply thin. So the had problems. Most are now thicker including Perrin. Also avoid samco with the straight end near the turbo. As it has fitment issues around the tgv area.
Old 11-07-2011, 02:55 AM   #2007
i2cou4u2
Member#: 246455
2004 WRX Wagon
Nice to know, thanks for the info. Will I need another tune for the inlet pipe?
Old 11-07-2011, 08:55 AM   #2008
ssssly
Member#: 268627
05 SpecC/FFR818
Keep an eye on ebay for a JDM v7 STI ECU. You can find them for under $200 if you are patient. Just keep in mind that it is DBC so don't get a DBW intake mani.
I wouldn't suggest a v8 STI ecu unless you are running a turbo that can push 1.4bar or you have a MBC to dial it down a bit.
Have had success running 04 USDM ECUs with ej207s. You will loose the AVCS but they still run great, are relatively cheap, and easily tunable.
Also most JDM v7 and v8 WRX ECUs are DBC single AVCS. Haven't tried them on a dual AVCS ej207 though.
ssssly is offline   Reply With Quote
Old 11-07-2011, 09:13 AM   #2009
ssssly
Member#: 268627
05 SpecC/FFR818
Originally Posted by Clark Turner View Post
1. bad idea
2. Worse idea then the first
3. Never tested those cams. The stock cams do not have much lift. Kelford is my choice
4. Cosworth guide on timing belt.
5. Not recomended. Only option is a maf hack which really detracts from the drivability. Utec allows you to keep the JDM ECU and AVCS cams, AEM, link plug inm and then Ditch the AVCS, Get JUN 272 Cams.
C
detracts from drivability how?
Old 11-09-2011, 08:11 PM   #2010
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
What makes the v8 ecu specific to having a turbo with at least 1.4 bar? That's not stock boost levels is it?
I figured you'd need a tune no matter what due to the jdm timing.
langsbr is offline   Reply With Quote
Old 11-10-2011, 10:59 AM   #2011
ChestyPuller
Member#: 293281
ver8 doesn't have TGV's. It's one solid piece.
The samco one will fit fine.
ChestyPuller is offline   Reply With Quote
Old 11-10-2011, 11:01 AM   #2012
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
v7 doesnt have TGV's either. They are just risers with no TGV motors. Had a samco and it fit fine as well.
Old 11-10-2011, 05:23 PM   #2013
Deraj_53
Member#: 115139
Chapter/Region: HIIC
1998 2.5 RS
EJ207 Version 8 swapped
My stock v8 is tuned to 23psi which is 1.6 bar
Deraj_53 is offline   Reply With Quote
Old 11-10-2011, 06:52 PM   #2014
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Default Really...
"tgv area"... Bottom of the intake near the turbo. Do you need me to spell it out any further for you. As all inlets need to turn near the turbo. Or have you never look at them before?
Also I didn't say all samco inlet Do you read? Only... the ones that are straight at the end with no bend. There are a few still out there. Most have the bend.
Old 11-10-2011, 07:20 PM   #2015
ChestyPuller
Member#: 293281
you said perrin inlet, then you said samco. I'm not a mind reader and your grammar is horrific.
I'd like to see a picture of the SAMCO you think won't fit.
Why so defensive?
Old 11-10-2011, 08:38 PM   #2016
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Why so defensive?
Grammer, yes I'm not on my computer. I don't claim to have the best grammer or spelling. But people generally understand where I am coming from.
If your going to correct someone have your facts. I didn't feel I needed to spoon feed people with in depth and exact detail. I figured it was understood by those who understand how these things work.
Old 11-10-2011, 08:39 PM   #2017
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Grammar.
Psychoreo is offline   Reply With Quote
Old 11-11-2011, 12:30 AM   #2018
ssssly
Member#: 268627
05 SpecC/FFR818
The stock boost for v8 JDM stis is 1.4-1.6 bar. Just about any stock JDM sti turbo (vf22, 34, 36/7) will run this fine. You will blow a vf39 or similar USDM turbo with a quickness though.
Old 11-11-2011, 12:46 AM   #2019
ChestyPuller
Member#: 293281
do you need a hug?
Old 11-13-2011, 08:53 AM   #2020
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Question for those that swapped the transmission as well as the engine:
Did you notice an additional drop in the front suspension when you were done? The 200lb would probably even out the sti springs.
Old 11-13-2011, 08:07 PM   #2021
Red MY01
Member#: 97715
Hi fellow EJ207 lovers,
I was just wondering where you buy timing belts etc, specifically the Gates timing belt kit with water pump. I live in Australia so we all got free 207s with our cars but I tend to buy most of the parts for my car from the States as your suppliers have more realistic pricing. Any help would be appreciated. Mine is a V7 EJ207.
Thanks,
Owen
Red MY01 is offline   Reply With Quote
Old 11-13-2011, 09:11 PM   #2022
ChestyPuller
Member#: 293281
I noticed it with the engine swap (ej205-->ej207). My snow tires rub a lot more this year in the front.
05 WRX with BC coilovers. Low mileage so I know it's not the coil overs.
I'm sure engine weight info is listed in here somewhere.
Thanks,
Owen
PM a few vendors on here and find one you're comfortable with.
Old 11-13-2011, 10:22 PM   #2023
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
I'm sure engine weight info is listed in here somewhere..
The 6 speed is said to be 200lb heavier than the 5 speed. I'm not sure that the 207 is heavier than the 205.
If you didn't swap the transmission, but only the engine, the difference should be minor.
The Sti springs account for the difference in weight of the 6 speed in the front, I think.
Old 11-13-2011, 11:28 PM   #2024
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Before I installed mine, i threw it on a bathroom scale, fwiw it read 185, no fluid, no, clutch, no starter, no axels. Its bulky heavy but not 200lbs heavier than the 5sp. I dont recall any additional sag up front on my bugeye when I installed it. For a while i had 04 Sti takeoff suspension with the stock 5sp then swapping to the 6sp.
Old 11-14-2011, 09:00 AM   #2025
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
From what I recall the 6 speed is approximately 80lbs heavier than the 5 Speed.
kayen is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
