Old 11-29-2011, 10:25 PM   #2051
i2cou4u2
Member#: 246455
2004 WRX Wagon
Originally Posted by RexWagonWA
I too would recommend Maxwell Power in Marysville, WA north of Seattle up I-5. They have the experience, plus you can get a Dom tune!
Sounds good!!! I will give them a call and get in for the tune.
Thanks
i2cou4u2 is offline   Reply With Quote
Old 11-30-2011, 01:28 AM   #2052
i2cou4u2
Member#: 246455
2004 WRX Wagon
What is the maximum octane that is available up in Washington state at most all gas stations?
Old 11-30-2011, 12:17 PM   #2053
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
Anyone seen any dyno graphs/tuning results for the JDM EJ207 with the Dom 1.5XTR?
I've found a couple that make the turbo look fairly attractive, but they've been highly modified UK Ej207's w/ cams.
Basically, im still on the stock VF30 and just stage 2 with a hybrid MBC/EBCS to prevent overboosting (was getting it a fair bit on the highway and this fixed it).
I've got Maddad headers, DW 750cc injectors and an HFS-6 waiting to go in to the car in the spring but since I'll be making a trip to the tuner anyway, I figured Id get'er all done and upgrade the turbo as well.
I gave Blouch a call and talked to someone about the 1.5XTR. They said I could expect peak boost around 4000rpm. That's basically where my VF30 tops out right now (yay for elevation!) but Im hoping to see some graphs... y'know, as proof.
As for goals... 340-360whp would be great but if I have to give up a significant amount of spool for it (too far north of 4k) then ill go a different direction.
Zaider is offline   Reply With Quote
Old 11-30-2011, 12:38 PM   #2054
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
You should be getting peak boost on the VF30 by about 3,500 RPM if there are no leaks. I had a Ver7 EJ207 that was factory from the valve covers in with stock headers and some porting on the intake mani. 20PSI at 3,500 in 4th on an EBCS.
Then I switched to a 257 and a blouch 1.5xtr and found full boost was roughly 3,400 (23psi in 4th, same EBCS, different cams) but obviously YMMV. I had the 10cm and 3" inlet, but I'd probably do the same on the 2.0. Maybe the 8cm....not sure.
subydude is offline   Reply With Quote
Old 11-30-2011, 12:46 PM   #2055
Zaider
Member#: 154281
MBP
Its been tested for leaks... there were none. Maybe its the elevation (~3500ft)? Maybe its our crappy 91 octane?
Zeev 91 remap 526958 by airboy123, on Flickr
Zeev 91 remap boost 526958 by airboy123, on Flickr
Tuned for 19.5psi in 4th (JDM 6-spd) on the Prodrive EBCS. The Hallman MBC was added in hybrid after and is basically only there as a clamp.
Im thinking the 8cm is the way to go for the 2.0L. I've seen a bunch of testing on the Dom 1.5xtr on the 2.5L and it looks great there... great spool.
Old 11-30-2011, 01:34 PM   #2056
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
92 oct
blakjak00 is offline   Reply With Quote
Old 12-04-2011, 02:56 PM   #2057
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Me >
NJ MVD> Hi There. Got Catalytic converters?
JDM ECU > Konichiwa!
NJ MVD> wtf? Fail.
Me > that sucks
Well, I failed NJ MVD inspection yesterday . Passed everything but the overall emissions because of JDM ecu not communicating OBD system readiness. State inspection definitely tightened up last time I got the v7 ecu to pass in the state.
Only stuff that communicated readiness were -fuel system, comprehensive component??, O2 sensors and O2 sensor heaters.
fastnoypi is offline   Reply With Quote
Old 12-05-2011, 07:49 AM   #2058
Special
Member#: 145585
2002 S202 [email protected]
Yellow
Hey, do any of you guys know if the V7 Thermostat is the same as the USDM Thermostat?
Thanks
Mike
Special is offline   Reply With Quote
Old 12-05-2011, 08:04 AM   #2059
i2cou4u2
Member#: 246455
2004 WRX Wagon
Thanks
Mike
When I did my Ver.8 swap I used an OEM USDM WRX thermostat and it is working great. I have around 3k miles on it with no overheating issues.
Tom
Old 12-05-2011, 09:36 AM   #2060
Special
Member#: 145585
Yellow
Hey, and was that thermostat for a particular year model or are all of them the same?
Thanks
Mike
Old 12-05-2011, 11:09 AM   #2061
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
21210AA030 with gasket
21200AA072 on it's own, just thermostat, for V7.
Old 12-05-2011, 11:31 AM   #2062
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Appears to be same, the part number even cross references to 1990 legacys to the 07+ STi in the dealer catalogs.
Old 12-05-2011, 03:46 PM   #2063
Woodenhorse
Member#: 263215
2002 WRX Wagon
Originally Posted by fastnoypi View Post
Me >
NJ MVD> wtf? Fail.
Me > that sucks
Up here in Canada I lot of guys need to do use ecutek to get JDM ECUs to pass emissions. Not sure what it is they do...but it seems to be common.
Woodenhorse is offline   Reply With Quote
Old 12-05-2011, 10:14 PM   #2064
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
I dont see how ecutek does anything to add anything to the ECU to pass emissions unless its the preferred tuning method up there to lean the car out enough for a tailpipe sniff test.
Some states here are stricter than others, AZ just looked for OBD2 connectivity and readiness, while there was a longer list of things to check by NJ. TX state inspection computer could not complete the test at all and kept dropping communication.
Old 12-06-2011, 03:16 AM   #2065
Woodenhorse
Member#: 263215
2002 WRX Wagon
No...I'm talking emissions with an ODB2 connection check...
My bad: http://forums.nasioc.com/forums/show...2210698&page=6
They didn't need ecutek....but they thought it made the difference....in the end it didn't matter.
Old 12-07-2011, 07:06 AM   #2066
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Thanks
Mike
I have a question about the S202:
Does it come with the regular unequal header single scroll, or does it come with a 4 into 1 equal length header, single scroll, from the factory?
Old 12-07-2011, 11:29 AM   #2067
nunez07c
Member#: 258027
Quick question:
My version 8 when I completed the swap. I noticed a CEL, P0365 camshaft position sensor B circuit (Bank 1). I have a replacement sensor, not new, but it came from my old engine, EJ205. i was wondering if I can use this on my EJ207 motor? or do I have to buy the sensor that is made for the EJ207?
thanks,
nunez07c is offline   Reply With Quote
Old 12-07-2011, 04:51 PM   #2068
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Originally Posted by nunez07c View Post
Quick question:
thanks,
does the CEL go away when you get on the throttle? if so, its your avcs wiring bugging out and your sensor is fine.
Old 12-08-2011, 09:38 PM   #2069
jun430
Member#: 301311
dont mean to hijack the thread.i'm a newbie here!
can anyone recommend a turbo for me..
currently driving a 05 GDA rex running on 2.0L type rs sti engine,forged piston,rod,bearing,etc.. done up head port n polish,,kelford cam,,etc.. autronic sm4 ecu with cdi..fmic,, external fuel tank,,methanol kit...previously is on aps ar56..
the previous owner took over changed to blouch 18g xt. i just bought the car over but i felt is under power due to the forged interior..
can anyone please recommend a turbo for me.. is fp black good enough??
i'm into drag!!
jun430 is offline   Reply With Quote
Old 12-09-2011, 12:07 AM   #2070
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
i'm into drag!!
Unabomber covered you on this.. on your other thread... in the same forum...
Old 12-09-2011, 04:41 PM   #2071
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
Wrong forum. Since you have a built motor/hybrid motor/whatever you want to call it, I think you should go here: Built Motor Forum
K.Linchpin is offline   Reply With Quote
Old 12-13-2011, 12:29 PM   #2072
i2cou4u2
Member#: 246455
2004 WRX Wagon
I am wanting to install a front mount intercooler on my Ver 8 motor, but I am not sure of how much there is to be gained on the stock VF37 turbo. It is running 19lbs of boost on 91 oct. I am looking to get 300whp and I was either looking to go water/meth injection or a fmic and another tune. I am currently at 280whp.
Thanks
Old 12-13-2011, 04:06 PM   #2073
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Thanks
You have the stock Ver. 8 TMIC? Then there is little to gain. Unless you are going for 380whp+ the stock intercooler setup is satisfactory.
Old 12-13-2011, 05:29 PM   #2074
i2cou4u2
Member#: 246455
2004 WRX Wagon
Thanks, I will just stay with the Ver. 8 TMIC then. What about the meth injection? Would I be able to hit 300whp with the meth injection on 91oct?
Thanks
Old 12-13-2011, 05:37 PM   #2075
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Hey guys do u think a 4.44 final drive will be too much for a daily driven ej207?
mrxr250rider is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
