Old 01-11-2012, 07:32 PM   #2201
ryeguy001
Member#: 201566
2002 EJ207 WRX
Mine is modded by Mines lol.......... no chance to get into it to remap for my 3076. The snail is just sitting in the box in my closet. I had to put it away so I didn't tear up lol.
ryeguy001 is offline   Reply With Quote
Old 01-11-2012, 08:07 PM   #2202
WRick
Member#: 86107
damned locked ecu
WRick is offline   Reply With Quote
Old 01-11-2012, 08:43 PM   #2203
ryeguy001
Member#: 201566
2002 EJ207 WRX
I know!!!!!!! I emailed them a couple times seeing what I could do about it. So far one person said I should be able to get into it........ Obviously not, that's why I emailed you!!!
Old 01-11-2012, 08:46 PM   #2204
WRick
Member#: 86107
Yeah I got into it ( but didn't if you work for ecutek and plan on suing me )
still a pita
Old 01-11-2012, 08:48 PM   #2205
ryeguy001
Member#: 201566
2002 EJ207 WRX
I just can't figure out if they chipped it or what. I have my OEM Ecu....... maybe Ill take that one apart too and compare them :-)
Old 01-12-2012, 10:56 AM   #2206
unkachabull
Member#: 241491
2005 wrx
v7 ej207- stimikey tuned
Does anyone have the part number for which plugs I need for the 207 v7. Looking for ngk 1 step colder. Is it the same as the usdm ej205?
unkachabull is offline   Reply With Quote
Old 01-12-2012, 11:05 AM   #2207
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Same part numbers for an EJ205
kayen is offline   Reply With Quote
Old 01-12-2012, 11:18 AM   #2208
WRick
Member#: 86107
Ngk 2667
Old 01-12-2012, 11:26 AM   #2209
unkachabull
Member#: 241491
2005 wrx
Awesome thanks guys!
Old 01-12-2012, 11:29 AM   #2210
ChestyPuller
Member#: 293281
anyone run the full race 1.5 scroll kit?
http://www.full-race.com/store/turbo...turbo-kit.html
I'm interested to see what it would make on an ej207.
ChestyPuller is offline   Reply With Quote
Old 01-12-2012, 11:32 AM   #2211
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
+1 gap to .025-26 if you have high boost. i threw mine in .030 as they came in box and i cant boost past 15psi without misfires.
mrxr250rider is offline   Reply With Quote
Old 01-12-2012, 03:41 PM   #2212
unkachabull
Member#: 241491
2005 wrx
Ya my tune if for 21psi so ill gap them.
Old 01-12-2012, 06:24 PM   #2213
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Same here regapping mine this weekend need to get rid of the misfires
Old 01-12-2012, 07:31 PM   #2214
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
What plugs are you 2 guys using?
jhenry1983 is offline   Reply With Quote
Old 01-12-2012, 07:42 PM   #2215
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
NGK BKR7E. V-Power Copper Plugs
Old 01-12-2012, 08:33 PM   #2216
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Are those the same as bkr7eix ? Those are the ones clark turner suggested and I just put in the other day before I flash the e-tune
Old 01-12-2012, 08:35 PM   #2217
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Use these they are iridium one step colder
Old 01-12-2012, 08:38 PM   #2218
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
No they are not the same. Yours are Iridium plugs and mine are Copper. They are both popular plugs. Coppers only last approximately 12-15k miles. You have to change them way more often. However the reason why I run Copper is it is a better conductor than Iridium.
Old 01-12-2012, 10:00 PM   #2219
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Ill keep that in mind incase im misfiring at my boost goals. thanks!
Old 01-12-2012, 10:32 PM   #2220
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
All good info these things are picky with plugs
Old 01-12-2012, 10:56 PM   #2221
evelfacilitator
Member#: 213345
04 wrx v7 jdm sti
white
Mine misfires only in colder weather but runs great during the summer.
evelfacilitator is offline   Reply With Quote
Old 01-12-2012, 11:23 PM   #2222
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I want no misfires lol
Old 01-12-2012, 11:28 PM   #2223
evelfacilitator
Member#: 213345
04 wrx v7 jdm sti
white
Yea so do i but i cant figure out why its doing it
Old 01-13-2012, 04:07 PM   #2224
RealDealTarheel
Member#: 142447
**** Texas
Does anyone know if the O-2 sensors on the USDM WRX are the same as on the V8 motors? That was one of the things that was cut when they removed the engine it seemed.
RealDealTarheel is offline   Reply With Quote
Old 01-13-2012, 04:42 PM   #2225
i2cou4u2
Member#: 246455
2004 WRX Wagon
I did my Ver. 8 swap into a 2004 WRX and I had the same problem when I received my swap. I used both o2 sensors from my USDM motor and I have had no problems at all through daily driving or tuning. As far as my experience goes, the USDM sensors work With the JDM ecu.
Tom
i2cou4u2 is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
