Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-13-2012, 05:08 PM   #2226
RealDealTarheel
Member#: 142447
06 Outback
Thanks!
RealDealTarheel is offline   Reply With Quote
Old 01-13-2012, 07:07 PM   #2227
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
They are the same
jhenry1983 is offline   Reply With Quote
Old 01-14-2012, 04:42 PM   #2228
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
gapped my plugs down to .026 like clark reccomended. was boosting 18psi fine. adjusted my actuator some more boosting around my where im tuned for at 21 and now im and its misfiring again. maybe my plug need to be gapped down even more?
i still have to play with my actuator some more and see where the sweet spot is without misfiring
mrxr250rider is offline   Reply With Quote
Old 01-14-2012, 04:54 PM   #2229
Clark Turner
Member#: 178047
02 WRX STI Spec C
You should not be adjusting the actuator. Not sure why you decided to do that. I would set it back to 10 psi where it should be by hooking a line direct.
C
Clark Turner is offline   Reply With Quote
Old 01-14-2012, 05:25 PM   #2230
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
C
i have an avo adjustable actuator. it works by adjusting the arm. the stock one is non adjustable and works through the ebcs. the only difference is the stock actuator would peak at 21 then taper down to around 15. the avo you set to your peak boost and it holds to redline. theres a hose that goes straight from the actuator to the turbo.
the actuator is not my problem its the high boost misfire. i want to beable to boost 21 like im tuned for. gapping the plugs to .026 did seem to help allow it to boost a little more without misfiring. do you think they need to be gapped down more?
Old 01-14-2012, 05:29 PM   #2231
Clark Turner
Member#: 178047
02 WRX STI Spec C
No. You dont understand. You should not be adjusting that actuator to raise and lower boost like that.
C
Old 01-14-2012, 05:34 PM   #2232
azscooby
Member#: 115297
2002 ej207 vf34
I'm about to swap a v8 into my 2002 wrx sedan.
I have everything ready to go except for the turbo.
Initially I was set on selling the vf37 to recoup some of the costs of the swap. I was then planning on using either my existing td04 (with 19t wheel upgrade) or going with a 16g variant. However, it sounds as if this turbo will run out of steam rather early, and would work against the strengths of this motor.
I'm now either going to do a 16g variant (hoping for 16gxt-r to be released) or stick with the vf37 and just cough up the extra money.
This is a daily driver and so quick spool is my main goal, and could sacrifice top end if need be. At the same time I'd like to see at least a small improvement in top end over what I've got now with my ej205.
Any input on these three options?
1. TD04 with 19t wheel upgrade (cheapest option since I already have it)
2. 16g variant, also cheap option. Would you go with biggest 16g? (evo III, or 16gxt-r?) Quick spool but might run out of steam up top?
3. vf37 - most expensive option, but might get me the results I'm looking for. I would have to fab up custom pipes for this option. (Though the guy I bought the ej207 from said my motor was from a late v8 and said it had the longer dp...true?)
Again, this is mostly a DD, though I would like to get into some
NASA events on the future
Any input would be greatly appreciated.
azscooby is offline   Reply With Quote
Old 01-14-2012, 05:41 PM   #2233
Clark Turner
Member#: 178047
02 WRX STI Spec C
Please dont put that Td04 on the JDM engine. That would be upsetting The EVO3 16G is cheap and works great. More then the VF for sure. Not sure if its worth any outlay of money though. The 18G is not my favorite so forget that. That leaves you at the best but most expensive of all. The ATP GTX3071 bolt on. It was made for that motor and is flat out awesome.
C
Old 01-14-2012, 06:02 PM   #2234
azscooby
Member#: 115297
2002 ej207 vf34
How is the spool on that turbo?
It's still stock location right? Ball bearing I assume?
What makes it such a good match with the ej207? Would you choose it over the vf37?
Not at all familiar with that turbo at all, but will research now.
So the evo III is an ok option? (I believe the 16gxt is its successor, since you can't really buy them new anymore )
Again, not looking for a dyno queen, need daily driver suitability.
Thanks Clark. I promise I won't put the td04 on!
Old 01-14-2012, 06:16 PM   #2235
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
C
The avo actuator is different from stock and you have to adjust the rod length to get the proper amount of boost your cars tuned for. The stock one works off the ebcs and is a different setup. I don't see how I could possibly be doing anything wrong when the instructions say to set boost my shortening and lengthing the rod. The cars running exactly the same as with the stock actuator but better. I just want to get rid of this misfire and boost 21 like I'm tuned for
Old 01-14-2012, 07:11 PM   #2236
pux888
Member#: 8356
02 STi swap
12 WRX limited
Is it me or is there an echo in here?
pux888 is offline   Reply With Quote
Old 01-14-2012, 08:37 PM   #2237
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
There is fail, because the issues are just repeating and they have been addressed several times in this thread.
All you have to do is go back, read and find the answer.
As far as turbos:
The XT has the machined aluminum wheel and the R has ball bearings.
Hopes are high in the twinscroll world that these are going to be a breaktrough, especially a 20GXTR TS.
I have read the 18XT thread (single scroll), these have been around for a little while and I'm starting to get a feeling that they're performing like the HTA.
At first there was a lot of hype, then, later, not so much. Not a downgrade and some still swear by it, but not a different, higher category either.
More recently, there is a 18gXTR thread. Thre seem to be mixed reviews there. Read it and draw your own conclusions.
The hype with Twinscroll for these may be associated with those articles that came out about Litchfield cars in UK.
When looking at UK dynographs, I see that it's cold a lot of the time, when the dyno is done and I remember that the fuel they have is certainly higher octane than 93 pump over here.
Also, there seems to be an inclination there to dyno in what is considered the closest to 1:1 gear. This makes sense from an engineering standpoint, but is one gear up from US.
I have the EvoIII 16g twinscroll 10sq cm currently. I like it and when the time comes, I am considering a TD06SL2 20G 10sq cm with the 3" inlet. I'm not excluding the 20gXTR TS, but I am waiting to see a bunch of graphs.
Old 01-14-2012, 09:00 PM   #2238
hamski
Member#: 216786
2006 WRX
SGM
Well, after 2 days checking as many posts as possible, I still can't find anything. Has anyone successfully swapped the EJ207 into a MY06-07 WRX?
Only problems I've seen come up so far is the lack of immobilizer, dive-by-wire to crive-by-cable conversion, and the AVCS wires, right?
hamski is offline   Reply With Quote
Old 01-14-2012, 09:36 PM   #2239
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
You could consider asking Wali about a V10 Ej207. Back when I talked to them, JDMracingmotors had one in stock.
It's drive by wire, but the swap would be a first. You could try it and document it..
Old 01-15-2012, 03:22 AM   #2240
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
wali doesnt work with them anymore supposedly he went back to school or somthing
Old 01-15-2012, 12:02 PM   #2241
azscooby
Member#: 115297
2002 ej207 vf34
Yeah, no Wali when I bought mine last week.
I worked with Robert, communication was horrible.
Had they not had good reviews I would never have purchased anything from them.
He talks over you and you cannot get a word in edge-wise, it was extremely frustrating as I literally yelled for over a minute into the phone to get him to stop talking and listen to me, but he kept on talking , either ignoring me or just didn't care.
I'm just hoping I don't have to deal with any warranty issues. If I do, I will try to talk to someone else.
Jury is still out, but hopefully it works out.
Old 01-15-2012, 04:30 PM   #2242
555
Member#: 20161
1998 Impreza ST
555
Guys, how do you source brand new EJ207 short blocks from USA?
555 is offline   Reply With Quote
Old 01-15-2012, 10:31 PM   #2243
amvegeta
Member#: 148342
What is the duration of the camshafts GC8 sti version 5 and 6? thank you
amvegeta is offline   Reply With Quote
Old 01-15-2012, 10:34 PM   #2244
amvegeta
Member#: 148342
I found that is 256 duration!!!
Old 01-15-2012, 10:36 PM   #2245
ChestyPuller
Member#: 293281
ChestyPuller is offline   Reply With Quote
Old 01-16-2012, 08:54 PM   #2246
Freeze Plug
Member#: 234613
maybe someone here can help me. i bought a 2002 wrx wagon that has either a v5 or v6 ej207 installed. the PO used all of the ej205 stuff such as crank gear and pos sensor, cam pos sensor, knock sensor, and coils (since it was coilpack jdm). The USDM intake manifold wont bolt up, and it needs to for the USDM ecu to function properly. anyone gotten around this? I may end up cutting the flanges and runners off of the jdm manifold and merge them into the USDM manifold and weld them. might be the only option. the engine is already installed and only has 16k miles on it, i really dont want to tear it open and swap to ej205 heads
Freeze Plug is offline   Reply With Quote
Old 01-17-2012, 12:41 PM   #2247
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Its not surprising your having these kind of issues.
If your tinkering with the actuator your fighting your tune to provide more boost than it wants, and is a good way to get missfires.
I can not for the life of me see why changing your plug gap would be a good thing in this case. Typically for high performance you get a stronger voltage coil and overgap plugs to get a better fuel burn.
Lets put it this way...my stock USDM wrx hits 19.1 psi just fine on factory NGK plugs at factory gap, and they last 30k miles every time.
If your ECU is cutting boost its doing it for a reason, and you told it not to, and now you miss.
If your seeing high boost misses, at high rpm, I would check your fuel pump flow rate. Get a fuel pressure gauge plumb it into the system and make SURE you are not getting low PSI when everything is at open loop at high rpm/boost.
It makes a lot more sense than squashing your plugs.
The Phenx is offline   Reply With Quote
Old 01-17-2012, 01:31 PM   #2248
azscooby
Member#: 115297
2002 ej207 vf34
Ok, someone help me out....
I've got a "late" v8 coming my way, should be here by the end of the week.
By "late" I was told it had the usdm length downpipe and a few other things that the v9 has.
If it is usdm length, why wouldn't it (vf37) bolt right on to my greddy sp2 exhaust?
Couldn't I gut it and get the same, or similar results as an aftermarket dp?
It's going into a 2002 wrx sedan.
I've also found a dp on ebay fro kinugawa that says it will work, I emailed them and they say it will work.
http://item.mobileweb.ebay.com/viewi...id=71280010400
Are there other options I'm missing?
I'd really like to keep this as "plug and play" as possible. Don't want to have anything welded up or custom made if possible, same reason I'm buying the avcs wires from iaperformance.
Thanks in advance for any input.
Old 01-17-2012, 04:59 PM   #2249
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Actually my car is running perfect now that the plugs are gapped right(.026) and my actuator is set right. You guys really need to take a look at the avo actuator and understand how it works before you say im doing something wrong. It's a different design then stock and is much better.better boost response and holds to redline. the response was slow with the stock actuator and it peaked early and tapered down. im not messing with my tune at all just adjusting the actuator to hit the psi im tuned for without overboosting. this actuator doesnt run off an ebcs like the stock one theres a hose coming out of the actuator straight to the turbo and its adjusted by shortening or lengthening the actuator arm.
i think i may try copper plugs before i get tuned,they dont last aslong but are better conductors and less prone to misfires with high boost.
Old 01-17-2012, 05:59 PM   #2250
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
if your buyign a complete longblock with everything bolted on with an ecu you dont need the iaperf wire harness. you basically drop the entire engine in and put the jdm ecu in and start it up and tune it. ppl that buy shortblocks and use the usdm wire harness on a jdm engine require the use of the iaperf wire harness to turn there tgv wires into avcs wires basically. jdm cars dont have tgvs and those wires are instead used for avcs. something not found on usdm 02-05 wrx's.
your dp wont bolt up because its for a single scroll turbo. jdm twin scroll turbo's have different dp flange bolt pattern. the best option is to remove the heat shield from the stocker. cut it at a logical location like a foot from the turbo. cut the top of your dp off and weld on the jdm part you cut off. then it will be plug and play.
WhiteBgeye02 is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
