Old 01-27-2012, 04:25 AM   #2426
mohawk24
Member#: 293644
2002 wrx
wrb
i been doing alot of research on doing a 207 swap in my bugeye 1 thing that i cant find is if any years v7-v9 have a 1.1-1 transfer so i can use my 3.54 or do i need to just find a r160 3.90 n swap the r&p into my r160 so i keep my lsd
thanks
rob
mohawk24 is offline   Reply With Quote
Old 01-27-2012, 06:52 AM   #2427
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
The motor has nothing to do with that its the trans aslong as your trans is 3:54 you can use a stock 3:54 r160
mrxr250rider is offline   Reply With Quote
Old 01-27-2012, 07:22 AM   #2428
mohawk24
Member#: 293644
2002 wrx
wrb
i guess i was misunderstood is there a jdm trans that has 1.1:1 like the usdm 06-07 jdms i found have a 3.90 fd but cant find the info if they r 1.1:1 or they r 1:1 center diff
Old 01-27-2012, 11:47 AM   #2429
Clark Turner
Member#: 178047
02 WRX STI Spec C
The tuner forgot to change somethings in the ecu. Send me the Rom with a log and I will fix it.
C
Originally Posted by unkachabull View Post
Hey I have a weird problem for you guys.
Currently in the process of tuning my recently swapped 207 v7. Did all the maf scaling etc. Then I did 3rd gear pulls and the Tuner dialed that in. 3-7200k rpm not one problem. So I was told to start doing 4th gear pulls.
First pull to 7k cut out at 6500. Tried it again and it won't go past 6500. Installed new spark plugs 1 step colder ngk and gapped them to .026. Car still will not go past 6500. Any ideas? It doesn't feel like fuel cut but more of a rev limiter....
Clark Turner is offline   Reply With Quote
Old 01-27-2012, 11:50 AM   #2430
Clark Turner
Member#: 178047
02 WRX STI Spec C
The JDM 6mts I have worked with have all been 1.0 to 1. Its possible later JDM units up to current are 1.1. to 1. I honestly do not know but V7 and V8 are 1.0 6mts. The US car had a 1.0 6mt in 04 and some 05 later, They changed to 1.1 to 1 with a 3.54 rear. This make swapping into a WRX a snap as the WRX has 3.54 rear end.
Either way, You can swap the transfer gears in the 6mt without removing the trans and you can swap the ring and pinion in the rear end without removing it. So you can match it up one way or another.
C
Old 01-27-2012, 12:28 PM   #2431
biodude
Member#: 271720
Originally Posted by mrxr250rider View Post
Yes ngk one step colder iridium gapped to .026 like you reccomended. Previous owner said it was tuned to 21. I'm peaking at around 19-20 now with no misfires.21 will pull fine but will mis underload like as it has the wrong plugs or gap. but fine with little load wot.which obviously isn't right and can't daily drive it like that. How do I go about sending a log? Feel free to email me [email protected]. I appreciate the help
If you dont have the means to pull the ROM and a log, let me know. We can meet up sometime. Im not far from you
biodude is offline   Reply With Quote
Old 01-27-2012, 04:21 PM   #2432
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
That would be great thanks a lot man ill def let u know
Old 01-27-2012, 06:02 PM   #2433
Deraj_53
Member#: 115139
Chapter/Region: HIIC
1998 2.5 RS
EJ207 Version 8 swapped
All JDM transmissions are 1:1 as referenced in this comprehensive chart here:
http://spda-online.ca/modules/tinyco...ite/tc_28.html
Deraj_53 is offline   Reply With Quote
Old 01-27-2012, 11:26 PM   #2434
mohawk24
Member#: 293644
2002 wrx
wrb
thanks guys for ur assistance i saw that chart on my research just didnt know if there was any variations you guys r great
Old 01-28-2012, 11:37 AM   #2435
JDM_Thompson914
Member#: 307835
hey guys i picked up a freshly swapped v8 into a bugeye back in june, just getting onto nasioc. since ive bought the car ive installed a manual boost controller and GFB 50/50 bov and a tune from phatbottimike. its a COMPLETE 2004 swap. so ive been having a small oil leak coming from what i think is the pan but its hard to tell, it gets everywhere. whats a common issue that this could be? im still learning a lot on this car, i had to jump on it for the offer i got so i never got time to study before hand.
JDM_Thompson914 is offline   Reply With Quote
Old 01-28-2012, 11:49 AM   #2436
Quadsbc
Member#: 170415
2002 Hardware store
bumper clips, that is all
Hard to say where the leak is without being there in person or good pictures.
Quadsbc is offline   Reply With Quote
Old 01-28-2012, 11:52 AM   #2437
JDM_Thompson914
Member#: 307835
ill try to grab some pics for you, just wondering if it was a common issue
Old 01-28-2012, 01:19 PM   #2438
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
If you can spray down the oil pan with brake cleaner and wipe it clean. Drive it a bit and check it again to get a better idea where it is
jhenry1983 is offline   Reply With Quote
Old 01-28-2012, 05:18 PM   #2439
JDM_Thompson914
Member#: 307835
okay im waiting for my new control arm to come so when i get it on a lift ill make sure i get at it well.
Old 01-29-2012, 11:58 AM   #2440
azscooby
Member#: 115297
2002 ej207 vf34
Is anyone running catch cans?
Would it be worth adding one to an ej207?
Just want to make sure this eninge goes at least 240k like the last one!
My ej207(second attempt) should be here Friday!
azscooby is offline   Reply With Quote
Old 01-29-2012, 03:03 PM   #2441
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
Not sure what people would suggest is better air oil seperators or catch cans. I plan on adding one when the 207 is on the road
Old 01-29-2012, 10:46 PM   #2442
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
my friend used a harbor freight aos from his breather tubes and it worked great. it was bright ass orange. its the kind for air compressors. about 6/7 inches tall. he emptied it at ever fill up. you would be surprised how much it caught from going into the silicone intake. if your car is having blowby issues then yes you need one because this misty oil will affect your tune and afr's.
if you do get a catch can make sure it actually has baffels in it and has good reviews. some places literally sell cans that are hollow but look sweet so ppl buy them the point is for there to be alot of surface area's in it so the oil hits the surface and sticks in the can rather than going into the intake tract.
WhiteBgeye02 is offline   Reply With Quote
Old 01-30-2012, 01:39 PM   #2443
mark342
Member#: 284693
1999 Impreza 2.5 RS
STM
All right, got the engine in and fired up......but I had to use a USDM WRX ECU to get it started.
I have a ver 9 engine swap and the ECU is acting like it's dead. I'm guessing it needs the matching immobilizer/key for it. Is it possible to get a new immobilizer and have the dealership sync it all together?
Or, can I get a ver 8 ECU that doesn't need an immobilizer? If I get that, will the pins match up the same as the ver 9 ECU? I feel like this option will be easier if it turns out that the ver 8 is pin compatible.
Thanks!
mark342 is offline   Reply With Quote
Old 01-30-2012, 01:44 PM   #2444
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Thanks!
Ver9 JDM EJ207's do not have an immobilizer. 16bit ECU's are not capable to use one. You may just have a bricked ECU
kayen is offline   Reply With Quote
Old 01-30-2012, 02:01 PM   #2445
mark342
Member#: 284693
1999 Impreza 2.5 RS
STM
Would a v8 ecu work fine (pins compatible)?
Old 01-30-2012, 02:43 PM   #2446
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Some v9 do have immobilizer. The wiring diagram for them shows both possibilities.
The way to know is to look at what is pinned in connector A.
If you were to have the immobilizer and key, you would still need the dealer to reflash a different portion of the memory than is available to tuning software, to make everything work.
My theory is that in v9, the spec C did not have the immobilizer due to weight savings.
This mostly because the guys that run V9 on the board are spec C.
The S204 had it for sure , as I saw the special s204 key sold in a package with the immobilizer, on yahoo.jp.
I have yet to learn if one can reflash an ECU with a different model year rom completely. I read that if they are compatible, a complete image of a different year can be flashed.
Old 01-30-2012, 04:04 PM   #2447
Clark Turner
Member#: 178047
02 WRX STI Spec C
90% of the time any oil in the intake tract is from overfilling the oil. Either Wrong dipstick (two lengths) or the car just has to much oil in it. If you keep it 1/8 to a 1/4 inch BELOW the line cold in the morning you probably do not need any kind of catch can.
I do not like systems that plumb to the oil fil cap and these WILL throw the tune off. I cap them off If the choice is mine.
The stock system works great unless, Its a serious road race car or its running over 25 psi of boost pressure.
Old 01-30-2012, 04:31 PM   #2448
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
what line do you use? i actually like to let my car warm up and i check it when i fill up every time. i use the warm fill notch on the dip stick to determine how much i need. i mean if its at proper levels when warm then it should be correct.
Old 01-30-2012, 04:50 PM   #2449
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
You can reflash a different model year completely on your ECU, but the ECU is only compatible with a rom "family", as outlined on Scoobypedia. Ex: you may lose AVCS if it is incompatible, due to NPS signal inversion intended for certain year trans, and other weird things happening.
http://www.scoobypedia.co.uk/index.p...patibilityList
There are some physical differences i've noticed when i've compared my v7 ecu to a v8 and s202 ecus that i've owned.
fastnoypi is offline   Reply With Quote
Old 01-30-2012, 05:11 PM   #2450
evelfacilitator
Member#: 213345
04 wrx v7 jdm sti
white
With this flash will it completely reflash the ecu back to stock no matter what tune is on the ecu? If so is this how the dealerships flash cars with ecutek back to stock roms?
evelfacilitator is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
